Lt1 NOS on a l98
Lt1 NOS on a l98
I have a great deal on NOS that is on a Lt1. He has the nozel bled into his air intake tube. The only difference i can see so far over the L98 kit is
*The solenoids seems to be better
*The plate that goes onto the TB.
I am thinking about bleeding the valve in after the MAS AF and before the TB
I am kinda nervous about it. I am going to be consirvative and only run a 100 shot.
I am going to upgrade my fuel pump from stock.
I do plan on running 2 10lb tanks into a 4 way with a gauge to monitor the combined pressure of the tanks.
On paper this seems like it wont kill me and should not hur my motor....on paper
Thoughts?
Its a stock l98 (1985) NO Cat
Eliminated the air pump and Ac
Thoughts?
Cruising
The difference really is you would be trying to run a "dry" setup. I'm not really nitrous savvy. but I have the NOS setup on my 91 and it's more than just a plate. it sprays fuel (from the rail) and NOS at the same time. I think if you just go dry it will run too lean.
shamdave.
dont monkey around with NOS. It will leave you disapointed.
The cars out there winning today are blown. Turbo's / superchargers are beating up on NOS cars in the big leagues.
The issue with NOS is that you make more power on a full tank of NOS than you do a half tank.
So if you tune for full tank of NOS, you will run rich when spraying at a half tank.
Heres the key statement:
Even if you are using a bottle heater to ensure you are spraying at the same PSI, you will still make less power with anything less than a full tnk.
I have heard of new NANO nitrogen assisted pushers, but I dont hve any experience
Skip the NOS and save up for a blowersetup. Talk to grg@blowerworks.
If you dont want to take my advice, then be sure to run a 'wet' setup (sprays raw fuel at the same time asnitrous). I ran an NX wet100 shot for years without incident. Tht same motor is running a blower/meth injectin now.
Itd be a good idea to upgrade fuel pump to walbro 340 255 l/hr pump with racetronix harness.
This becomes must if you evr go above 100 shot.
Good luck.
Good luck.
shamdave.
Good luck.
Good luck.
My DD is a 02 F150 Harley Davidson with the 5.4 SC Motor. It makes just over 650 at teh rear wheels and is pushing 19 psi via the blower. I run an Alky Control Meth injection system on it to ensure octane is always high tto avoid detonation. The M1 mix is 70/30 so my effective street octane under boost is about 107-108. The other advantages of the meth are the colling that occurs at the IAT as well as the nice fresh cleaning it does to the valves. I had my heads off a few weeks ago to up the cams and the valves were baby butt clean with about 10k on them.
NOS is a great seat of the pants hit but one wrong thing and boom goes the block.
