96 running rough. Service Soon light on. It is not the gas. Idles fine. but when
4th Gear
but when running and punch it, I get black smoke out of the rear. It is not responding well at all. Exhaust has a gas smell to it. I have 86000 miles and never had a tune-up. Thought is to change out the plugs and hope that fixes it. I really think I have an injector problem. Chould there be some sensors that are causing the fuel to run rich and that is the cause of the black smoke.
[Modified by Scooterpie, 4:35 PM 5/20/2002]
Re: 96 running rough. Service Soon light on. It is not the gas. Idles fine.
I know this sounds elementary, but is the air filter dirty? Injector balance, low fuel pressure, and restricted fuel filter could also be the cause, but I don't think the fuel filter being clogged would produce the black smoke. Also, like you mentioned, the ignition system could have deteriorating components. Good luck! :seeya
Re: 96 running rough. Service Soon light on. It is not the gas. Idles fine.Scooterpie)
Oh yeah, the O2 sensor would do it, but you would most likely experience idle problems with that. But you might check it out. You should put a scan tool on it, that might narrow it down some. :yesnod:
