1.6 Rocker & spring recommendation
I have a 94 LT1 automatic coupe. The motor is stock but I have a D44 rear with 3.45 gears and a vigilante 3200 stall with a PCM for less tune.
Thinking of adding 1.6 rockers and springs as a mod and would like to know reccomendations for each (part numbers would be great!).
Also am looking at long tube headers.
Thanks!
Thanks!
I Installed 1.6 rockers On my Buddy's Stock 95 you could feel the difference!!!!!
it's a preference... I would stay away from aluminum rockers!!!!
we installed Comp Cam roller tip rockers on the above car...
I personally have stainless steel pro comp roller rockers Identical with comp cam only half the price$$$$$$$
some people say they have had problems with pro comp....
they just had polishing compound all over and needed to be cleaned....
I know they are heavy duty
I have not had any issues yet.. I had my 1.6 installed on a .540 / .570 lift 500hp
engine..
LT headers for a LT1 me to WHY are they so damn expensive for C4's????
engine..
Thanks!
Thanks!
http://www.vetteweb.com/tech/vemp_07...rms/index.html
Here is another combination that will work using mostly GM parts and very budget friendly.
G M Perf. Parts. LT4 valve springs (16) Part # 12495494
LT4 valve cap (retainer) set of 16 Part # 12495492
LT4 valve key (keeper)set of 32 Part # 12495503
LT4 valve spring shims (10 pack, 2 required) Part # 10212809
Valve cover gaskets (2 required) Part # 10108625
Valve seal set (16) Fel Pro Part # SS72861
Scorpion Self aligning roller rockers SCP1036
......... With a stock engine you can bolt on the 1.6's with the original springs ... the ratio difference only gives an additional valve lift of around .020" ... you will feel the difference in performance .....
Jake
Run 1 Run 2 Run 3
60' 1.881 2.045 1.831
330' 5.697 5.897 5.682
1/8 8.903 9.120 8.931
1/8 MPH 76.93 76.53 76.16
1000' 11.638 11.868 11.689
1/4 13.907 14.160 13.996
MPH 99.77 99.00 96.89
Did not get up on the converter in the 2nd run.
Feels like we are losing at least a 1/2 second if not more.
1.6 "Self- Aligning" roller-rockers & LT4 springs are the way to go.
I measured the retainers on my 94 LT1 and they were the same as the new LT4 retainers I bought.
I would recommend new 10 degree keepers, too. Jegs is a good source for all.
