timing 1990 L98 ?
Old 10-18-2010, 06:49 PM
Joe
Joe's Avatar
Default timing 1990 L98 ?
The book says the info is on a sticker under the hood , nope
I can't rember, think it was 8 degree BTDC
Anyone Know`for sure ? 1990 L98
Old 10-18-2010, 09:08 PM
TPI BOY
TPI BOY's Avatar
on my 91 it's 6*
Old 10-19-2010, 10:25 AM
Lemme
Lemme's Avatar
St. Jude Donor '10
I think the sticker is on the radiator on the drivers side. Talks about emissions in general.
Old 10-19-2010, 07:38 PM
Joe
Joe's Avatar
On mine shows how to thread the serpentine belt
Old 10-19-2010, 08:02 PM
Joe
Joe's Avatar
Originally Posted by TPI BOY
on my 91 it's 6*
That should work !
90 and 91 are the same animal
Thank you very much , if we can get it running correctly we have a new old stock Paxton Super charger to install , made for a 90 or 91
Old 10-22-2010, 11:30 AM
Joe
Joe's Avatar
spent 1/2 the day trying to get this done , used 3 diffrent kinds of paint to mark the balancer mark , Dam , had #1 cylinder on the wrong side
Old 10-22-2010, 04:07 PM
EastCoastHD
EastCoastHD's Avatar
With that said,
Prior to setting the timing, did you disconnect the EST bypass?
Old 10-22-2010, 11:30 PM
Lemme
Lemme's Avatar
St. Jude Donor '10
Here it is on the drivers side of the radiator on my 87
Says 6 deg BTDC and 0.035" plug gap
Old 10-25-2010, 03:32 PM
MyFirst90coupe
MyFirst90coupe's Avatar
My 90 L98 says 6* BTDC
You must unplug the EST as someone said.
Old 10-26-2010, 08:34 PM
Joe
Joe's Avatar
Yup we did , can,t figure it out , getting very bad fuel milage , no codes , black smoke and back firing , out of real side pipes ,well I did find a vacum line off under the throttle body , black smoke seems to be gone but running like poop ! Might need new plugs now
No sticker on my 90
Old 11-25-2010, 11:16 AM
90C4sRule
Support Corvetteforum!
90C4sRule's Avatar
I have a pictures of the stickers but I can't attach them to this reply. I will put them in my corvette pictures.
To timing 1990 L98 ?
Quick Reply: timing 1990 L98 ?
