C5 brake upgrade issue
Old 05-31-2011, 09:33 AM
bluepearl92
bluepearl92's Avatar
Default C5 brake upgrade issue
I ran in to an issue while upgrading the front calipers on my 92 this weekend and was wondering if anyone else has had this problem. I purchased the C5 adapter brackets from Pacific Northwest ZR-1, rotors and pads, and a used set of C5 calipers from the forum. When installing the caliper, the inside (engine side) of the rotor hits firmly against the caliper, to the point that you can't turn the rotor. It appears that the rotor needs to be spaced out about 1/4 inch to be centered inside the caliper. The brackets only fit one way, and I see no way to get the clearance needed without spacing out the rotor from the hub. Did I get some junk brackets, or am I missing something?
Old 05-31-2011, 09:48 AM
VetteMed
VetteMed's Avatar
Probably ought to check with the vendor to see if you got all the washers that are needed for mounting... of course, in the case of that particular vendor, it'll probably be weeks before you hear back... good luck.
Old 05-31-2011, 09:53 AM
c4cruiser
c4cruiser's Avatar
Are you using the C5 caliper abutment brackets? These are the ones that the calipers bolt to. You cannot use the C4 caliper brackets.
Old 05-31-2011, 09:56 AM
bluepearl92
Yea...it took me 4 months to get these brackets. I'm wondering if he sent me the wrong ones. What do the brackets for the early C4's look like? Would this cause the offset that I am missing?
Old 05-31-2011, 09:57 AM
bluepearl92
Yes, I'm using the abutment brackets that came with the C5 calipers.
Old 05-31-2011, 10:23 AM
tshirttom
tshirttom's Avatar
You will have a problem when trying to fit sawblades or other C4 wheels because my experience was the same...the caliper will hit the rim. You have the right kit but you will need to get spacers or upgrade your rims as I did.
Old 05-31-2011, 10:32 AM
bluepearl92
I have A molds on it, and they clear fine...no issues there from the front/side/back/etc. The issue is with the rotor contacting the caliper (the abutment bracket, actually) on the inside.
Old 05-31-2011, 10:38 AM
c4cruiser
c4cruiser's Avatar
He doesn't have that problem; the inside part of the rotor is hitting the inside of the caliper.
For the OP: did you get the washers with the custom brackets??
Installation instructions are here. There are pics of the adapter brackets in that link; do they look like what you received? IIRC, they are left and right specific.
Old 05-31-2011, 10:59 AM
bluepearl92
They look similar, but this picture here http://www.pnwzr1.com/images/Brakes/..._installed.jpg appears to have more of an "inset" to the caliper mounting area than the ones I have. What I received from them was the two brackets (painted black and no writing on them) and 4 bolts/washers (two bolts and two washers for each bracket). They are right/left specific, and I installed/removed/trial fitted/etc to make sure I was installing correctly. They really only fit one way that I could see. I won't have pictures until tonight of the brackets I have (at work right now).
Old 05-31-2011, 06:09 PM
corvette95
corvette95's Avatar
Use the caliper bracket washer from old c4 bracket behind the middle bolt (40mm bolt) so it doesnt hit the bracket then use bolt,washer,bracket,washer, nut on bottom larger bolt. You somehow you dont have the washers in the right places.
Old 05-31-2011, 07:49 PM
bluepearl92
I will look at doing that. So it will be OK to space the bracket out? That's not going to weaken the mounting point? Here are the brackets I received:
Old 05-31-2011, 10:33 PM
bluepearl92
But if I use the washers anywhere but BEHIND the rotor (to push the wheel/rotor out), it's going to push the caliper out more toward the wheel, and the rotor is already hitting the caliper. There is no way to space "back" the caliper so it centers on the rotor and doesn't hit it by using washers. Is that making any sense? It's like the adapter bracket needs to be thinner, or have an offset more toward the motor side of the car.
Old 06-01-2011, 06:03 AM
corvette95
corvette95's Avatar
I JUST went through this the past weekend, wish I could explain better via the board. Email me at corvette95@charter.net and I will give you my phone number and masybe I can help. You have to re-use your old caliper bracket washers. You DID get new C5 rotors didnt you?
Old 06-01-2011, 06:04 AM
corvette95
corvette95's Avatar
You new calipers will ONLY work with c5 rotors, your old 12 or 13 inch c4 rotors will NOT work
Old 06-01-2011, 07:49 AM
bluepearl92
Yes, got C5 front rotors. I'll be in touch, thanks a bunch!!
To C5 brake upgrade issue
Quick Reply: C5 brake upgrade issue
