Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-13-2010, 10:05 AM   #1
kenv
CF Senior Member
St. Jude Donor '10
kenv's Avatar
Location: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
Default popping in exhaust
I just got my Procharged `90 last month, & a problem it seems to have is when I jump on it, I hear popping in the exhaust. When I drive it normaly, it seems ok. I have to say, for all the stuff thats in this car (383, Trick Flow heads, ZZ9 cam etc.) I am not all that impressed with the performance. Mabey it needs a tune up after sitting for a few years. It is pretty cool though. Its the popping that has me bothered at the moment. Anyone know what this could be? This is my first FI car- Thanks, Ken
__________________
`87 yellow coupe (for fun)
`90 supercharged coupe (for more fun)
"EVERY DAY ABOVE GROUND IS A GOOD ONE"
The only thing that stops me from being rich is the lack of money.
Dogs are not our whole life, but they make our lives whole
kenv is offline   Reply With Quote
Old 08-13-2010, 01:46 PM   #2
mgroshong
CF Senior Member
Is it tuned?
mgroshong is offline   Reply With Quote
Old 08-13-2010, 03:30 PM   #3
BlowerWorks
Supporting Vendor
Support Corvetteforum!
Too lean ... need injectors, pump, tune and HELP ! LOL
BlowerWorks is offline   Reply With Quote
Old 08-13-2010, 09:56 PM   #4
kenv
CF Senior Member
St. Jude Donor '10
kenv's Avatar
Thanks for the replies. I have not had it tuned yet. I`m currently looking for someone around my area who is experienced in FI to look at it.
__________________
Old 08-14-2010, 05:00 AM   #5
mgroshong
CF Senior Member
I would suggest not driving it or at the very least not in boost till it is tuned. Very bad things can happen quicker then you think.
Old 08-14-2010, 10:41 AM   #6
lisoundsvette
CF Senior Member
lisoundsvette's Avatar
KEN
GIVE GREG FROM BLOWERWORKS A CALL
HE KNOWS C4'S.
1 201.891.4690
lisoundsvette is offline   Reply With Quote
Old 08-15-2010, 03:56 AM   #7
Coconut
CF Senior Member
Coconut's Avatar
Quote:
I don't know where you're at in FL, but I know there are experienced shops for Corvettes with DFI setups (great for boost) in Jacksonville, FL, Panama City, FL, & Mobile, AL (which is close to NW FL).
Coconut is offline   Reply With Quote
Old 08-15-2010, 10:07 AM   #8
Guitarguy
CF Senior Member
Guitarguy's Avatar
Quote:
realy? i called all around not to long ago and no one would tune a lt1. all they would offer is to dyno it to see curent HP.
Guitarguy is offline   Reply With Quote
Old 08-15-2010, 05:50 PM   #9
dizwiz24
CF Senior Member
1. Upgrade stock fuel pump to walbro 340 255 liter/hr w/ racetronix hotwire wiring.
2. are you using the FMU (that comes in the procharger kit) or do you have bigger injectors and a tune? If you are using the FMU, ditch it for higher lb.hr injectors (60 lb/ hr). You will then need to tune
3. get a base tune and an ostrich from Greg @ blowerworks. I got one of his base tunes. I can vouch its pretty good (at least the lt1 tune I got).
4. It doesnt stop here. Download tunerpro RT software from the tunerpro.net website. Then use tunerpro.net (website) to download the appropriate definition file (for my '93 its $DA2) to be able to read/modify the base tune you got from Greg @ Blowerworks.
5. I recommend getting a wideband O2 sensor and installing it so you can see what AFR's you are running.
This is a subject in itself, but you can datalog the wideband info through the A/C pressure sensor, that way its referenced to RPM, MAP, TPS, etc.
Elsewise you can just keep an eye on the readout at WOT (more easier said than done) to ensure you are at the appropriate 12.0:1 AFR.
6. If you dont get a wideband O2 sensor, I recommend taking it to a dyno and tuning it using their wideband O2 sensor.
You will want to mess with the power enrichment tables. If its not dialed into 12.0:1 AFR, you may want to make some changes. To make the appropriate changes, there are 2 power enrichment tables you need to modify.
a. PE (power enrichment) % change to AFR vs. coolant temp
THis table has the greatest effect on your WOT AFR
b. PE % change to AFR vs. RPM. You can use this to modify WOT AFR, at specific RPM's, in case its leaning out at higher RPM.
c. You also may want to adjust the % throttle position to trigger PE (power enrichment) mode. Some people have told me that this should be lower (lower % throttle to trigger PE mode) with boost to prevent the car from ever being lean when going into boost (like going up a hill, under load).
7. Part throttle stuff, SHOULD be controlled by your O2 sensors. So you shouldnt have to worry too much about tuning VE tables (because Greg's base tunes already have done that).
8. Consider ditching the procharger intercooler (its just a flow restriction, decreases your max boost) and adding meth injection. It keeps intake temps cool.
9. Once you get the tune dialed in, you can get a chip burned (from greg) to replace the Ostrich (that plugs into your chip socket).
10. Beware of belt slip if you are using the procharger bracket. This is especially an issue with P600b prochargers with the low step up ratio (3.10:1) and small diameter pulleys. Greg makes a fix for this.
11. Happy boosting and shutting down punks (and the occasional streetbike).
dizwiz24 is offline   Reply With Quote
Old 08-16-2010, 05:48 PM   #10
kenv
CF Senior Member
St. Jude Donor '10
kenv's Avatar
Thanks, but the FI in my post is for forced induction. I live in Pa. Sorry for the confusion
__________________
Old 08-16-2010, 05:52 PM   #11
kenv
CF Senior Member
St. Jude Donor '10
kenv's Avatar
WOW! Thanks for the info. I`m not afraid to admit it, but this stuff you are talking about is WAY over my head. I guss I`m just a 60+ year old dumba$$ when it comes to this stuff I`ll have to have someone look at it when I get some coin. ( even though I`m not sure how it all works, just having it is still way cool)
__________________
Old 08-21-2010, 11:14 PM   #12
Coconut
CF Senior Member
Coconut's Avatar
Default Accel
Quote:
Contact Accel for the shops they recommend for installs of their DFI systems.
Those shops can usually help.
Old 08-21-2010, 11:15 PM   #13
Coconut
CF Senior Member
Coconut's Avatar
Default Ok
OK. Not a problem. Good luck!
Old 08-21-2010, 11:18 PM   #14
Coconut
CF Senior Member
Coconut's Avatar
Default Wide-Band O2 Sensor
A wide-band O2 sensor is the only way to go when using forced induction.
Reload this Page popping in exhaust
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
