Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-18-2009, 09:57 AM   #1
Flame Red
CF Senior Member
Flame Red's Avatar
Default How to remove pulley from ATI 600b
Wanted to get the collective experience of the hive. I know it is a real PITA to remove the pulley from an ATI 600b. I tried to do it years ago and bent all my gear pullers so I gave up.
But now I will be ordering a new set of pulleys from BlowerWorks so I better be able to get-r-done.
How did you guys successfully get it off? I don't have a torch, just propane and heat gun. I have an air impact wrench, but I don't think I could get it in there.
Any tips to make sure I do not ruin the seals would be appreciated!
Thanks in advance
Flame Red is offline   Reply With Quote
Old 11-18-2009, 10:37 AM   #2
AKS Racing
CF Senior Member
AKS Racing's Avatar
Thanks in advance
For some reason, the first pull on a P600B always requires the use of a torch. And no matter who supplies the next pulley (Blowerworks, ATI, ASP, ect), they all come off fairly easy after that. I have never had to use a torch on any pull but the first.
Aaron
AKS Racing is offline   Reply With Quote
Old 11-26-2009, 10:24 PM   #3
dustmann
CF Senior Member
dustmann's Avatar
Aaron is the man!!! I was lucky. All I had was a heat gun. It did take what felt like 5 minutes to heat up and then the pulley just slid of with out any effort. Of coarse it was very hot so I put it on the ground and sent my new pulley on it for a few minute and then it slid right on too. Thanks for all your help Aaron. I do not now if you remember my blower blown up. Greg from BlowerWorks told me to send it back to ATI and I did.They fixed it fast for $1019.00. Said the oil line filter was blocked and burned up the bearing and bent the impeller. Then 3 weeks later my alternator blown up and two part went through the hood. 1 new alternator, 1 new belt and 4 days at the body shop to fix the hood. My luck has to turn around...
dustmann is offline   Reply With Quote
Reload this Page How to remove pulley from ATI 600b
Tags
1984, 1996, 600b, ati, corvette, fix, heat, line, oil, p600b, pulley, remove, supercharger
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
