Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-30-2009, 10:40 PM   #1
mnstrlt1
CF Senior Member
mnstrlt1's Avatar
Default chain driven blower?
Anyone every consider a chain drive setup for blowers?
There seems to be a good amount of issues with traditional belts and cog driven applications.... why not use something like a timing belt chain, motor cycle chain, or similar to run the blower off the crank? this would also offer some serious pulley width benefits.... am i crazy? Totally ridiculous idea? Plausable?
mnstrlt1 is offline   Reply With Quote
Old 10-30-2009, 11:28 PM   #2
AKS Racing
CF Senior Member
AKS Racing's Avatar
Do a search for Tony who ran the BBC with an F1 in the early C4.
He ran a 530 m/c chain (same is what comes on L bikes), and had great concerns with the safety of using a chain drive in this application.
AKS Racing is offline   Reply With Quote
Old 10-31-2009, 03:51 AM   #3
mnstrlt1
CF Senior Member
mnstrlt1's Avatar
Search on this forum or on google, or some other search engine?
Any details? Please share?
I imagine that it could be dangerous if it give way, but bike chains seem to hold well.... I also figured that vibration would end up being a serious issue as well.
pictures would be appreciated.
what was Tony's full combo? a Big Block with an F1 sounds TASTY!
Old 10-31-2009, 08:59 PM   #4
93VettePilot
CF Senior Member
93VettePilot's Avatar
Interesting idea. I've heard alot of horror stories about blower guys breaking the snout off their crankshaft with cogs. A chain would not be very forgiving on the blower internals and crankshaft.
Steve
93VettePilot is offline   Reply With Quote
Old 11-01-2009, 07:20 PM   #5
toofastlt1
CF Member
toofastlt1's Avatar
I think it would be a great idea. you wouldn't have to run the chain very tight. You would use chain slides insted of a tensioner. just set it up just like a motorcycle
toofastlt1 is offline   Reply With Quote
Old 11-02-2009, 04:55 AM   #6
mnstrlt1
CF Senior Member
mnstrlt1's Avatar
Quote:
My thoughts exactly. The chain doesn't have to be tight. just needs "slides" to keep in in check...
the only issue I can think of is vibration? Off throttle load on the blower, etc... but it would allow for a dedicated drive assembly IN-FRONT of the pulley assembly instead of sandwiched between the crank pulley and opti-spark (of course this relates to LT-x cars).
anyone with a chain driven bike that cares to share their opinions on vibrations, etc?
lol... maybe a clutch on the headunit sprocket would allow the blower to "free wheel" (like a bicycle) when off throttle?
Old 11-02-2009, 12:20 PM   #7
AKS Racing
CF Senior Member
AKS Racing's Avatar
I own and race a bunch of heavily modded L bikes. I will say that when a chain gives way, the only place the chain goes is down and back. So the damage is minimized. The bikes are putting between 190 and 275+ HP to the chain. At this level a 530 o-ring chain doesn't last terribly long. I would be really concerned as to what happens when the chain breaks under the Vette hood. I am not terribly concerned about the vibration, just about breakage.
BTW, late model L bikes use a slipper clutch that is somewhat similar to a "freewheel".
Aaron
Old 11-02-2009, 02:37 PM   #8
mnstrlt1
CF Senior Member
mnstrlt1's Avatar
Aaron
I'm not concerned about the damage caused by the chain only because a "cage" can be build off the existing blower bracket to minimize damage if the chain gives... i.e. think along the lines of the "old school" bicycles that would have a cover over the chain for debre, but also for safey if the chain gives up. Also along the lines of the the cover that the 03-04 cobra's use to keep the belt from damaging the underside of the hood.
Old 11-02-2009, 09:26 PM   #9
toofastlt1
CF Member
toofastlt1's Avatar
Aaron
275hp? there is no way a blower is needing even close to that. you would just oil the chain and change it when you change your oil or maybe every other time. they aren't that expensive.
Old 11-02-2009, 11:08 PM   #10
RRRR
CF Member
It was done about 9 or 10 years ago on the mustang shootout cars. If I remember it started killing the internal blower gears. Called them chainsaw blowers
RRRR is offline   Reply With Quote
Old 11-02-2009, 11:52 PM   #11
mnstrlt1
CF Senior Member
mnstrlt1's Avatar
i think on extreme applications the supercharger takes about 100hp to opperate. Of course, I don't believe this is the case in our application. Typically it's something like 30hp-ish
RRRR- can you provide us with more information? Possibly pictures?
Vibration and sudden off-throttle is my only real concern with this configuration
curious to know if the sprockets can be "zero-balanced", possibly even the chain?
Old 11-03-2009, 06:34 PM   #12
toofastlt1
CF Member
toofastlt1's Avatar
what about how fast the chain will spin. 6000 rpms. at that speed i dont think you will be able to keep it lubed
Old 11-06-2009, 05:32 PM   #13
RRRR
CF Member
[quote=mnstrlt1;1572026431]i think on extreme applications the supercharger takes about 100hp to opperate. Of course, I don't believe this is the case in our application. Typically it's something like 30hp-ish
I will look at my old pictures if i have any. I got rid of all my mustang mags and stuff a few years ago.
I do know that it was a procharger sponsored car in what was Pro 5.0. Used like a 630 prostock drag bike chain.
Old 11-11-2009, 12:51 AM   #14
Brand-X
CF Senior Member
this seems like a lot of trouble to cure belt slip (some of which is a good thing), considering there are cog, 8-rib, and 12-rib conversions out there that work well on our cars. what is the risk/benefiit factor I'm missing?
Brand-X is offline   Reply With Quote
Old 11-11-2009, 05:15 PM   #15
mnstrlt1
CF Senior Member
mnstrlt1's Avatar
Quote:
Well, the only benefit I can see is the lack of belt split, with a clutch mechanism on the blower head unit, it would allow the head unit to "free wheel" when you let off the throttle. so it shouldn't be to harsh on the head unit.
It would also save A LOT of precious room in the crank pulley area. The 8-rib (which I run) is relatively close to the opti, the 12-rib (from what i've read) requires shaving the cover of the opti to clear. these are in VERY close proximity.
the chain (which i am picturing a motorcycle chain or timing chain) would be much narrower, possibly allow the user to place it in front of the current crank pulley, rather than sandwiching it behind (like the current belt driven setups do).
It would also be much more durable.
Again, don't know if it's worth it. Just late night ideas I wanted to get out onto the forum. hopefully someone more talented and inclined than I can tackle this concept.
Old 11-11-2009, 10:25 PM   #16
qwiketz
CF Senior Member
qwiketz's Avatar
I believe tony actually had a f2 if I remember correctly or maybe that was toward the end.
qwiketz is offline   Reply With Quote
Old 11-12-2009, 09:09 PM   #17
AKS Racing
CF Senior Member
AKS Racing's Avatar
TonyDee64 has not posted on CF since 12/30/2008.
There may still be info on his chain driven blower if you worked the CF search....
Old 11-12-2009, 11:43 PM   #18
freedog81
Junior Member
I think with a overrunning clutch on the blower this would be a great idea. The chain on my bike is a 525 and it lasts about 10,000 miles and I am sure the bike sproket turns at least as many rpm's as the Vett engine. I don't understand why this is more popular than it seems to be but I guess there has to be a reason?
freedog81 is offline   Reply With Quote
Old 11-13-2009, 04:03 AM   #19
mnstrlt1
CF Senior Member
mnstrlt1's Avatar
Quote:
Finally, someone that has bike experience and can relate the two! lol...
Old 11-14-2009, 01:47 PM   #20
93 ragtop
CF Senior Member
93 ragtop's Avatar
Let me start by saying that I have no experience with this, but, in my mind, I find this statement doubtful.
My reasoning in this is as follows. Assuming a car motor used a 7in sprocket on the crankshaft, and a bike used a 3.5 in sprocket off of the transmission going to the rear wheel.
Again assuming the car had a redline of 6,000 rpms, for the chain to travel at the same speed would require the bike to run 12,000 rpm in high gear, assuming a 1 to 1 ratio of the transmission.
Now in the real world, the cars sprocket would probably be closer to 8 in and this is going to make it even worse.
As someone stated earlier, I would be worried about lack of lub, and heat build up.
Again, I dont have any direct experience with this, its just my opinion.
__________________
93 Automatic White Vert. 4.09 gears, Yank 3000 converter, Hot Cam, ported heads, Exotic Muscle LT headers, magnaflow mufflers Meziere water pump, and professionally tuned by Alvin and it passes emissions!!
My best run 11.82 ET at 116.52 mph. and 1.66 60ft.
My wifes best run 11.71 at 117.31 mph.
362 rwhp
379 torque
93 6 speed White Vert. 383 with a rear mount 85mm turbo. water to air intercooler, 6 pt. rollbar. Gen. 7 dfi. and many more extras. No numbers yet!!
93 ragtop is offline   Reply With Quote
Reload this Page chain driven blower?
Tags
4441, blower, chain, d1, drive, driven, drives, f1r, f3m, f3r, mustangs, photos, procharger, reverse, step
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
which paint gun do you use? NSTG8R C5 General 21 07-24-2005 07:24 PM
ASP will make me a cog drive, but warns me not to! DAVE396LT1 C4 Forced Induction/Nitrous 18 07-31-2004 01:26 AM
4,743 miles in a Sting Ray roadster (long) LouieM C1 & C2 Corvettes 53 06-14-2004 04:07 PM
cog drive setup? Soulja_350 C4 Forced Induction/Nitrous 12 10-04-2003 01:29 AM
Electric water pump gains POLOVETTE 94 C4 Forced Induction/Nitrous 9 08-31-2003 03:45 PM
If not for a C4, then.....? TexCorvette C4 Tech/Performance 25 10-28-2001 10:52 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
