Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-07-2009, 09:23 PM   #1
toofastlt1
CF Member
toofastlt1's Avatar
Default MAF relocation
So i moved my maf from a such throught to a blow through and my car started idleing really bad. what do you think would cause this? Here is a crapy cell phone vid to show you what i mean. http://www.youtube.com/watch?v=L1HLZ65nEM4
toofastlt1 is offline   Reply With Quote
Old 10-07-2009, 11:01 PM   #2
AKS Racing
CF Senior Member
AKS Racing's Avatar
Idle surge from incorrect tune. Many of the SC'ed applications are set up with the MAF on the pressure side of the head unit vs the vacuum side. Proper dyno tune, and the surge should be handled.
AKS Racing is offline   Reply With Quote
Old 10-07-2009, 11:38 PM   #3
toofastlt1
CF Member
toofastlt1's Avatar
when i plug the bypass valve it stops surging. does that mean its too rich at idle
Old 10-08-2009, 02:54 PM   #4
AKS Racing
CF Senior Member
AKS Racing's Avatar
Where is the bypass valve located relative to the MAF? You can not bypass metered air (as in air that has passed through the MAF) back in front of the head unit, and expect the car to run decent.
The bypass inlet would have to be located prior to the MAF and discharge the air to the inlet of the blower. Even when doing in this manner, there is still a concern with reversion (air backing up) through the MAF.
Please provide details as to where the inlet to the bypass valve is in relation to the MAF location, and also include relative proximity between the bypass and the MAF.
Old 10-08-2009, 05:26 PM   #5
toofastlt1
CF Member
toofastlt1's Avatar
the bypass valve is between the blower and the MAF so it hasn't metered the air yet. the Bypass is about 10 to 12 inches away from the MAF
Old 10-09-2009, 03:33 PM   #6
toofastlt1
CF Member
toofastlt1's Avatar
sorry its only about 5 or 6 inches away. I still need help. could it be the tune?
Old 10-18-2009, 07:45 AM   #7
rtracy
CF Senior Member
rtracy's Avatar
From my experience when ever you move the MAF from vac to pressure side your tune will differ. If I remember correctly I saw more air being read on the vac side.
rtracy is offline   Reply With Quote
Old 10-18-2009, 08:37 PM   #8
toofastlt1
CF Member
toofastlt1's Avatar
so do you think its all in the tune?
Old 10-22-2009, 12:45 PM   #9
Mo_Bandy
CF Senior Member
Mo_Bandy's Avatar
If you have the MAF on the pressure side of the SC it could be the turbulance of the air is causing the MAF to keep trying to correct... I have always found that the having the MAF on the vacuum side worked better... The only time I really had to do anything was when I went to the 8 rib I had to reprogram the MAF in the ECM so it would not set the over reference error.
I added a length of wire to the connector and ran the MAF and relocated it right behind the air filter just as it would be in a stock scenerio... As you probably know, as long as you are in closed loop the engine will compensate to get you to ~14.7 AFR once you are in open loop then it is up to your tune to get you to the probler AFR from there...
Hope this helps!
MO
Mo_Bandy is offline   Reply With Quote
Old 11-01-2009, 06:22 PM   #10
toofastlt1
CF Member
toofastlt1's Avatar
hey thanks
Reload this Page MAF relocation
Tags
c4, maf
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
F/S L98 fuel rail, K&N filter, stock air box, MAF, stock 48mm TB pablocruise C4 Parts for Sale/Wanted 15 11-08-2003 05:21 PM
Has MAF draw-through been tried on ATI? blu00rdstr C5 Forced Induction/Nitrous 22 08-30-2003 02:05 AM
MAT relocation question dbwade36 C4 Tech/Performance 10 09-15-2002 01:14 AM
MAF screens??? rocky5 C4 Tech/Performance 9 04-09-2002 02:35 AM
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
