Quote:
Originally Posted by AKS Racing
The McLeod twin disk is the end all clutch for the ZF cars. I run this clutch in my '87 with the ZF, and can attest to it's strength after many 9 sec passes.
However, you may be needing a different set-up, as you are probably running the DN4+3 in your '87.
Aaron
My car did have the doug nash 4+3 in it, but that expired many moons ago. I bought and installed richmond's 6 speed replacement for it. So the bellhousing and clutch are still the 10 3/4" setup used with the DN. Does Mcleod make a setup that will fit the bill.
Chris
