Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-16-2009, 10:44 PM   #1
out2kayak
CF Senior Member
Default Rear end
Just curious, what are folks using for a rear end when you have four digit HP numbers?
Thoughts?
-- Joe
out2kayak is offline   Reply With Quote
Old 08-17-2009, 03:06 AM   #2
qwiketz
CF Senior Member
qwiketz's Avatar
well, that would depend on what you wanted to do with the car. Most drag guys are at a live axle at this point.
qwiketz is offline   Reply With Quote
Old 08-17-2009, 11:16 AM   #3
neat
CF Senior Member
Send a message via AIM to neat Send a message via MSN to neat
There are some things you can do. Summers Brothers Racing makes some super heavy duty stub axles that would probably live under that kind of power. Some steel or chromoly half shafts would probably live as well. If you put in a new carrier from Toms Differentials, you'd have a pretty stout independent set up.
If you dead hook it on a clutch drop, under full power, I still think you'd probably break something. I think it'll hold up as long as you are resonable with it though.
neat is offline   Reply With Quote
Old 08-17-2009, 01:55 PM   #4
BrianCunningham
CF Senior Member
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
sums up what I'm doing.
Hopefully it will hold together.
I'm be going road racing so I want to keep the IRS
__________________
Polo Green 95 LT1 6-spd
383 LT1/Vortech Supercharger/AFR heads/Rod end suspension/Penske-Hardbar dual rate coilovers/Wilwood 6pot brakes
NCCC Governor/Membership/WebMaster: www.baystatecorvetteclub.com
BrianCunningham is offline   Reply With Quote
Old 08-17-2009, 02:43 PM   #5
qwiketz
CF Senior Member
qwiketz's Avatar
How much does one of these setups run when it's all said and done?
Also, isn't there another manufacturer of aftermaket case? Is it neuman car creations or something like that? I checked the tom's site and it says 2010 eta.
Old 08-17-2009, 03:35 PM   #6
BrianCunningham
CF Senior Member
The Newman rear, which does NOT bolt up to our cars is around $4-#5k
I just ordered the 31 spline subaxles @ $1,300
New guts for the rear ~$600
but that doesn't keep you from snapping off the front of the diff where the batwing connects.
There's a C4 in my tuner's shop that just did that.
The C3 stuff can be built to take it, after you stuff a 12bolt in and spend $4k
Old 08-17-2009, 04:15 PM   #7
neat
CF Senior Member
There are some home brew solutions to the nose snapping issue. If there is a cage in the car, supporting the nose of the case with an extension of the cage is a good option. I can also picture a way to support the nose of the case using the bat wing mounts, but I haven't really pursued it.
Another option is to remove the inner stub axles, outer stub axles, and half shafts; then replace the entire assembly with a CV joint. That still doesn't solve the case issue, but it might help to solve the problems outboard of the case. I don't know of anyone that has done this, but I think it would be possible.
Old 08-18-2009, 11:22 PM   #8
out2kayak
CF Senior Member
Interesting thoughts. Thanks for the ideas!
So.... Something that ran through my head was using a Moser M9 centre section with something like http://www.pstds.com/critical_link_drive_shafts.htm for the half shafts and drive shaft.
Will have to ask about Toms Differentials.
If you can't tell, I want IRS but I want it as darn near bullet proof as possible.
-- Joe
Old 08-19-2009, 10:33 AM   #9
BrianCunningham
CF Senior Member
I know of one forum member that replaced his diff with a quick change.
__________________
Old 08-20-2009, 06:53 PM   #10
mnstrlt1
CF Senior Member
mnstrlt1's Avatar
I've heard, from an old school c4 owner, that at one time there was a company that use to make an IRS ford 9" that was suppose to be "bullet proof". I haven't even taken the necessary steps to research this. But it does sound like a pretty cool option.
Although a live-axle rear-end is fun, I still prefer the IRS in the vette' myself.
I also was told by Bill (zfdoc.com) that you can extend the bump stops to prevent the axles from over-extending past fully horizontal. I guess he know's of a few c4 owners (none cf members) that run consistent 1/4 mile times with serious small blocks (in excess of 800lb/tq with NOS or FI) that use this method, and the IRS seems to live.
mnstrlt1 is offline   Reply With Quote
Old 08-20-2009, 11:27 PM   #11
AKS Racing
CF Senior Member
AKS Racing's Avatar
I have the extended bump stops, as well as the cradle to prevent ripping the D44 apart. I used to break on a yearly basis (average), but have not had issues in the last ~5 years. Knocking on wood....
AKS Racing is offline   Reply With Quote
Old 08-21-2009, 12:43 AM   #12
qwiketz
CF Senior Member
qwiketz's Avatar
aaron, can you tell us more about your rear and where to get one of those cradles?
Old 08-21-2009, 05:20 AM   #13
mnstrlt1
CF Senior Member
mnstrlt1's Avatar
Quote:
I second that! Never heard of a craddle, but had always thought about the idea of adding one. please include pictures!
Old 08-21-2009, 10:33 AM   #14
BrianCunningham
CF Senior Member
Quote:
me too
pics?
Any interest in selling a kit?
__________________
Old 08-23-2009, 10:30 PM   #15
out2kayak
CF Senior Member
Are you referring to http://www.dtepowertrain.com/dte_c5_diff_strut.htm? I have not seen anything for the C4....
-- Joe
Reload this Page Rear end
Tags
1992, 9, axles, c4, chevrolet, corvette, cv, drag, end, modifications, pictures, racing, rear, sheet, tech
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Parting a 2002 karshop C5 Parts for Sale/Wanted 801 08-29-2008 04:58 AM
New Side Stripe Ready To Ship mike76002 C5 General 70 10-08-2005 08:12 PM
Any chance of my '82 rear end not exploding.. SuprJames C3 Tech/Performance 152 07-03-2005 05:52 PM
parting out 74 convertible Jack Young C3 Parts for Sale/Wanted 39 05-13-2005 12:52 AM
New pics: NBM calipers, mcm hood, unique exhaust plate idea, black lower rear end Navy Blue C5 General 43 03-15-2005 05:52 AM
Photos of C6 next to Ferrari mszer C6 Corvette General Discussion 70 01-02-2005 06:29 AM
New external appearance poll for the C6 Scissors C6 Corvette General Discussion 137 10-14-2004 10:44 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
