Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-08-2009, 10:24 PM   #1
PAINTER MAN
CF Senior Member
Send a message via ICQ to PAINTER MAN Send a message via AIM to PAINTER MAN
Default The Powerdyne lives again
Well it has been about 5 weeks of not being able to drive the vette. When my Powerdyne had bearing failure, I found quite a mess inside. Three of the four bearing bores were damaged. I had a machine shop enlarge the bore and and install steel sleeves with bottoms. I also upgraded the impeller shaft and impeller. I also replaced the four bearing with ceramic hybrid bearings. I found a place called Performance Bearings in Arizona that hand builds bearings.
I reassembled it today and installed it on the car. After it ran awhile I had to make another adjustment. I had to disassemble and add a shim under one of the bearings to remove some impeller shaft back and forth movement.
It is now back on and seems to be working fine. Quite an ordeal.
PAINTER MAN is offline   Reply With Quote
Old 08-09-2009, 12:48 PM   #2
tequilaboy
CF Senior Member
tequilaboy's Avatar
Good work.
Next time that I need to rebuild mine, I want to go with the upgraded impeller shaft to prevent the tracking washers from ever coming loose.
It would be nice if they would also offer an impeller sprocket with a reduced number of teeth to increase the internal step-up ratio, but this would also require a special belt and could lead to a new set of problems.
I'm happy that there is strong aftermarket support of these blowers, so I won't complain.
tequilaboy is offline   Reply With Quote
Old 08-09-2009, 07:59 PM   #3
PAINTER MAN
CF Senior Member
Check out this web site for ceramic bearings.
http://www.performancebearing.com/dragracing.html
Old 08-16-2009, 09:59 PM   #4
miker2
CF Senior Member
miker2's Avatar
just got back to michigan from a trip to glacier national park.we were 78 miles from anywhere when an impeller bearing failed and the impeller locked up. internal belt did not break ---darn.the serpentine belt slipped and squealed. only had a cresent wrench and a screwdriver for tools but was able to remove the impeller nut and that freed it enough to drive. when the shaft got hot it would spin the impeller and grind it against the housing. impeller is shot. i think i can epoxy the housing to smooth it out.does anyone have specs for shimming the impeller ?
miker2 is offline   Reply With Quote
Old 08-17-2009, 04:49 PM   #5
PAINTER MAN
CF Senior Member
I was told to shim the impeller between 10 to 15 thousands. This was told to me by Supercharger Rebuilds. This allow for a little wiggle room if you do encounter a bearing problem.
928 Motorsports say you can shim it to 6 thousands for added boost.
I measured the distance by loosening the impeller on the shaft and measuring the movement before it hits the scroll.
There is a used impeller for sale on Ebay at the present time.
Old 08-17-2009, 05:38 PM   #6
miker2
CF Senior Member
miker2's Avatar
thanks for the shimming info. i'm the current bidder on the ebay impeller.
Old 08-18-2009, 07:52 AM   #7
PAINTER MAN
CF Senior Member
Good luck on biding.
Old 08-25-2009, 07:49 AM   #8
PAINTER MAN
CF Senior Member
Quote:
Did you get your Powerdyne repair yet?
Old 08-25-2009, 09:56 AM   #9
miker2
CF Senior Member
miker2's Avatar
i didn't get the impeller. i stopped at 290.00 and it went for 300.00. still looking. but i got lucky on a new radix and will install soon. the powerdyne will be sold.
Reload this Page The Powerdyne lives again
Tags
bearing, bearings, c4, calculator, corvette, failure, impeller, powerdyne, removal, remove, rpm, sale, shaft, shim, supercharger
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
