Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-07-2009, 12:11 PM   #1
0EPP
CF Senior Member
Default 250,000 mile '94 Corvette with ProCharger D-1SC!
http://www.exoticperformanceplus.com/hotCars.php?car=73
We built the engine and installed the ProCharger 50 or 60k miles ago. This car is just amazingly solid!
EPP is offline   Reply With Quote
Old 08-07-2009, 02:15 PM   #2
HighMileage
CF Senior Member
Bob,
Wow. This is my kind of guy.
I am impressed he can keep it that noce with salt, road construction, etc
I have logged over a half million miles in 5 C4's:
1989: 43K (My first C4, under a cover and mint)
1986: 215K
1990: 190K
1992: 170K
1996: 1st supecharged car - looking for more power
>> I want to put over a 100K on a supercharged car, this give me confidence it can be done.
Driven daily in Chicago, including snow (Except my '89)
How much boost are you pushing on that car?
Heads/cam?
Any super charger head issues, oil changed earlier than 6K?
Looks like this would be close to 500RWHP on a Dynojet?
HighMileage is offline   Reply With Quote
Old 08-07-2009, 05:02 PM   #3
0EPP
CF Senior Member
Quote:
Originally Posted by HighMileage View Post
Bob,
1986: 215K
1990: 190K
1992: 170K
Heads/cam?
Wow, no wonder you have the name you do!
We're at about 8 psi after the intercooler, as the intercooler is fairly restrictive.
No supercharger issues at all, it has been great. Oil isn't changed any sooner than the recommended 6k miles.
472 rwhp/495 ft lbs of torque on our Mustang Dyno would normally be about 40 to 50 rwhp higher on a Dynojet.
We have a Compstar stroker crank, Compstar rods, Diamond pistons, a pretty good size Comp Cam and Trick Flow heads on it. Bob
Old 08-07-2009, 05:25 PM   #4
HighMileage
CF Senior Member
Bob,
As far as intercooler heat issues go, for a given horsepower level, wouldn't the intercooler flow restriction be the same for a good flowing car with heads and cam and 8 pounds be the same as a lower flowing car (stock heads/mild cam) and more boost?
It would seem that for a given power level, a given amount of air will be necessary. The fuel will follow to maintain the AFR. And the flow and mass flow through the intercooler would then need to be the same at a given power level.
Very impressive car BTW.
Old 08-07-2009, 10:52 PM   #5
gsdave
CF Senior Member
gsdave's Avatar
That's a nice car with good results, but....Its just a regular LT1 car. If it were in fact a ZR1 chassis, the rear of the car would be significantly wider than a LT1 or L98 car. I say this because it looks silly to publish such a claim on your website.
gsdave is offline   Reply With Quote
Old 08-08-2009, 07:16 AM   #6
0EPP
CF Senior Member
Quote:
Thanks. I'm not a C4 expert by any means, but it seemed to me that back in the day GM adopted the ZR1 rear wide body look to the standard C4 by the last several years of the ZR1 production. I seem to recall that they were claiming that this killed the sales of the ZR1 as it did not look any different than the standard LT4. I'm not totally sure, but I'll look into it. Bob
Bob,
It seems from what we encountered, that as we tried to run more boost we would see more before the intercooler, but the boost would be significantly less after the intercooler than what we were shooting for. We used and installed a lot of intercoolers on other cars and have never had this problem. I'll bet that if we went straight from the blower to the engine with the boost, and added a methanol injection kit, that the boost would be much higher. Bob
Old 08-08-2009, 09:37 AM   #7
gsdave
CF Senior Member
gsdave's Avatar
Compare this ZR1:
to this LT1. Look at the width of the bumper, third brake light on the hatch, etc. You can also see the difference in the width between the exhaust location and the side of the bumper.
The style is the same, but you cannot bolt a GM ZR1 bumper to an LT1 or L98 body because the quarter panels are wider on the ZR1.
Old 08-08-2009, 02:31 PM   #8
AKS Racing
CF Senior Member
AKS Racing's Avatar
The back end of the '90-'95 ZR-1 corvette is completely different from the doors back. The quarter panel skins are different as well to mate the traditional C4 front end to the wider rear of the ZR-1. The width of the ZR-1 is evident when you look at the license plate opening.
That car pictured on the EPP website is a regular LT1.
AKS Racing is offline   Reply With Quote
Old 08-09-2009, 10:40 AM   #9
0EPP
CF Senior Member
Thanks everyone, I went in and changed the wording on it. Bob
Reload this Page 250,000 mile '94 Corvette with ProCharger D-1SC!
Tags
1986, 1989, 1990, 91and, 94, c4, corvette, corvettes, corvrtte, d1sc, forced, induction, l98, procharger, supercharger
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
