Quote:
Originally Posted by gsdave
Have you tried taking it to a machine shop and to have the bores sleeved?
Yes, that was my plan. But I also have a few other issues. The unit I have is BD-11. I ordered new custom built ceramic hybrid bearings and a new impeller shaft. Well the impeller shaft is different because it is for an improved model BD-11A. This means my impeller will not fit it, so I am into buying a new impeller and related washers, nuts, and shims. The old design is no longer made. My impeller can not be made to fit the new shaft. The money pit keeps getting deeper. I spent $315 for the bearings and another $230 for the Impeller shaft. Add the machine work and new impeller and I thinking I might be better to fine a good used BD-11A and rebuild with my new bearings.
Another issue is the bores are so distorted and I can find no one to give me an exact measurement for center to center and the bearing bores.
