LT1 Supercharger Question
I would like to supercharge my LT1, but I continue to see concerns over the bottom of the motor. I would like to run a vortech system, but if you run lower boost (say 6-7 psi) do you see problems in the long run on the bottom end?
I know if you go higher, you need to build up the motor, but will the stock bottom end be ok with lower psi?
I'm running at 9psi. It depends on your driving habbit just as much as a spot on tune. If you've got a safe tune, you should be fine. if you're even running slightly lean and recognize knock, kiss it good-bye.
Otherwise, if you're not flogging it every second you should be fine. With the meth injection, it adds another level of safety (if you plan to go above 6-7psi).
Thanks for the feedback. I plan on a tune and was hoping it would be a dyno tune, but in SC there just isn't much in the way of tuning that I have seen. The kit comes with a tune from pcmforless.
The kit has an intercooler option, but at such low psi, I hear it may not make much of a difference until up get up to higher pressures....
Hi There - just my opinion but a basic low boost kit (5-8 psig) is not a problem with your bottom end. Smokey Yunik always said a small block Chevy cast crank was good to 600 HP.
The problem with any performance package is detonation. If you do not detonate you'll live long and prosper (Clint Eastwood?) ?
It always comes down to experience and knowledge and support for a successful project. You either learn the hard way or you pay another for their experiences - no ??
BR - greg
Greg, thanks for the advice. I agree, on the detonation, I am going to insure I update the fuel system, injectors, tune etc to make sure its done right.
Hi Painter Man, good to see some people respond !!! Did you see the recent Josie Whales re-run where Clint & Chief become blood brothers?
greg
I do remember that part in Josie Whales. But do you remember in Star when Spoak does his hand thing and says, "Live long and prosper"? The proper response is "Peace and long life".
Hey Chris - how can you not love Clint ??? And PainterMan I think you are right. Just in my old age I get confused - LOL !!! Anyhow I'll have to go back to the Clint scene and see what he said for sure now. I won't be able to sleep until I know !!!
greg
When you said, SC, did you mean South Carolina? There are several reputable tuners here in North Carolina that could take care of tuning the car if that is what you are looking for.
PCM for less is based in Charlotte, I'm sure they would be willing to work out an in person dyno tune.
There's also several shops here in the Raleigh area that are quite qualified. Staples Auto Engineering, Mayhem Motorsports, Blazing High Performance, Ryan's Performance Machines, and a few others.
Maybe you could jet up here for a weekend and get your car dialed in?
Well I checked - in spirit I'm OK - but in fact I am so wrong!
Yes, I am in Columbia. I am going to have a local shop do the installation and he mentioned he would have to take it up to Charllote to get it tuned, so the car is NC bound somehow in this process. Thanks for the shops.
greg
