Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-28-2006, 12:07 PM   #1
95BlueBomber
CF Senior Member
95BlueBomber's Avatar
Send a message via AIM to 95BlueBomber
Default Can I supercharge?
I have a 95 LT1 with P/P Heads,CC306 Cam my question is can I supercharge on my stock bottom end? The bottom end has just been freshened up but I didnt know if the rods could handle it or not. And does anyone have a supercharger kit for sale?
The Bomber
95BlueBomber is offline   Reply With Quote
Old 03-28-2006, 12:48 PM   #2
mn_vette
CF Senior Member
mn_vette's Avatar
Sure, you can supercharge, as long as you didn't raise the compression when you had the heads off. Did they shave the heads at all??
There are lots of stock supercharged LT1's around.
mn_vette is offline   Reply With Quote
Old 03-28-2006, 02:06 PM   #3
95BlueBomber
CF Senior Member
The heads were milled. How much I dont know. How do I figure my Compression and how much is too much?
Old 03-28-2006, 04:10 PM   #4
dgoodhue
CF Senior Member
dgoodhue's Avatar
That cam is probably not ideal for SC.
__________________
Dave
86 Vette Conv.
http://www.corvetteforum.net/c4/dgoodhue/
dgoodhue is offline   Reply With Quote
Old 03-28-2006, 04:18 PM   #5
95BlueBomber
CF Senior Member
I was afraid of that! Too much work to pull that cam... I will just have to wait until I pull for my next bottom end rebuild.
Old 03-28-2006, 07:04 PM   #6
mn_vette
CF Senior Member
mn_vette's Avatar
what are the specs on that cam again???
Old 03-29-2006, 11:12 AM   #7
95BlueBomber
CF Senior Member
Gross Valve Lift .510/.540
Duration at .006 Tappet Lift 290/307
Duration at .050 229/245
Lobe Lift .3400/.3610
Lobe Seperation 112.0
Old 03-29-2006, 12:24 PM   #8
mn_vette
CF Senior Member
mn_vette's Avatar
There's alot of valve overlap in that cam. You can still do it, but the ideal cam would be something smaller.
Old 03-29-2006, 01:37 PM   #9
95BlueBomber
CF Senior Member
what kind of problems could i incur with this cam and a supercharger?
Old 03-29-2006, 02:14 PM   #10
mn_vette
CF Senior Member
mn_vette's Avatar
You'll be lacking some power. You will get some blowthrough but it shouldn't hurt the car at all.
Old 03-29-2006, 03:45 PM   #11
ncChris
CF Senior Member
My son, lcvette, just finished blower install on our 95. Check out his posts. We discussed often with Greg from BLOWERWORKS and got some great input. I believe i would not install a blower with a CC306 cam. According to Greg and everything I read you need a cam with decent lift and 112-116 lobe seperation. Look for posts by Lcvette and you will get some good ideas.
ncChris is offline   Reply With Quote
Old 04-05-2006, 04:30 PM   #12
95BlueBomber
CF Senior Member
any other opinions?
Old 04-06-2006, 03:59 AM   #13
tjwong
CF Senior Member
Support Corvetteforum!
tjwong's Avatar
Send a message via AIM to tjwong
Quote:
Originally Posted by 95BlueBomber
any other opinions?
IMHO actually in his case with milled heads and stock compression. That CC306 cam would probably be an advantage. It will bleed off some boost and will help to save the engine. It will still allow peak boost to happen after 4500RPM when the overlap of the cam kicks in to make powerwhich would be fine. With his stock bottom end and about 10.4:1 figuring milled heads and if he has a .039 Felpro 1074 head gasket, it should work well.
If this was a 8.5:1 engine then I would say that 306 cam would not work well with stock heads. We are running a 234/242 with a 114 using large CNC ported heads and in a 383. With this combo we are pulling 600+ RWHP @6000 RPM in a M6 car with a T trim making 12 PSI.
tjwong is offline   Reply With Quote
Reload this Page Can I supercharge?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Atten: 400cid owners/builders - I need pointers darkman5001 C4 Tech/Performance 11 06-27-2005 11:22 AM
what other mods can i do? cplonner C4 Tech/Performance 10 05-21-2005 12:44 PM
Can I make 600rwhp with magnacharger? torchedz C5 Forced Induction/Nitrous 18 12-03-2003 12:04 PM
What would I need to do to get my '97 into the 11s? C5EVIL C5 Tech 9 07-01-2003 10:54 PM
too many miles to supercharge?? 99frc2xblack C5 Forced Induction/Nitrous 10 06-29-2003 12:56 AM
Can I turbocharge my LT1 milehighvette C4 Tech/Performance 20 01-09-2003 09:48 PM
Which way to go Supercharge or Heads and cam... Price, Reliability, Drivability? SFYellow C5 Tech 11 03-23-2002 01:49 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
