Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-24-2006, 06:32 PM   #1
bigjack
CF Senior Member
Default Fuel Pump Configuration
I'd like an arrangement that would provide for direct port NO2. What effect would
an after-mkt.,additional(to stock, in-tank) pump placed IN LINE with the stock pump have? If not sufficient/recommended, how can the out-of-tank pump be connected to the tank? Thanks, Jack
bigjack is offline   Reply With Quote
Old 03-25-2006, 03:06 AM   #2
REDC4CORVETTE
CF Senior Member
REDC4CORVETTE's Avatar
I use the Barry Grant EFI pump external,that puts out 125 psi ,that is not necessary then you have to get an Aeromotive regulator that reduces the 125 psi to 4 to 7 lbs.You will have to remove the in tank pump and cut a hole on the other side of the return line and run another line and braze in the line to do it right.
You can't run an external pump in line with the in tank pump been their done that.Be careful when brazing you could burn your wire for the gas gauge sending unit.
REDC4CORVETTE is offline   Reply With Quote
Reload this Page Fuel Pump Configuration
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Lets revisit the in-line fuel filter debate ettev C3 Tech/Performance 19 04-16-2004 04:16 PM
HELP!!! Fuel system problems 18 the Bear C5 Tech 10 04-04-2004 03:15 AM
84 fuel pump replacement Brimis C4 Tech/Performance 13 01-05-2004 12:51 AM
Could use a recommendation on Fuel System parts. Jaxian C4 Forced Induction/Nitrous 18 12-13-2003 08:56 AM
Dual 255lph Fuel Pump ????'s Earl H C5 Forced Induction/Nitrous 19 01-15-2003 02:48 PM
160deg thermo and fuel efficiency? KorbenDallas C3 Tech/Performance 21 06-07-2002 04:41 PM
Fuel Filters DO make a difference!!! Smokehouse69 C3 Tech/Performance 24 08-20-2001 10:41 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
