03-23-2006, 09:39 PM
CF Senior Member
I ran a dedicated circuit for my N2O system on my '87. I ran a single -6AN (3/8") fuel line from the top of the tank all the way to the front of the car. A single factory pump feeds the fuel side of the N2O system. In the front, the line terminates into a factory L-98 FPR. I drilled and tapped the side inlets for -6AN fittings. One side is the entry, the other side feeds through flex line to the gas solenoid. The single discharge returns to the tank through the -8AN return that also returns for the motor.
This system worked fine for me on a 3-stage system, but I was running only 145hp top shot (55/90/145). Never had an issue with it, but have not used it in many years.
Aaron
