Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-21-2006, 08:26 PM   #1
red L98
CF Senior Member
red L98's Avatar
Send a message via AIM to red L98
Default they have a turbo kit for C4..
i called the guys a HP performance and they sid they do have a kit for the c4 , the base kit is 4800$ with injectors and fuel pump and you can get the kit with the t76mm turbo for 5300$ . it takes 45 working days to have a kit shipped. i think im going for it
http://www.hpturbos.com/
red L98 is offline   Reply With Quote
Old 03-21-2006, 08:34 PM   #2
mn_vette
CF Senior Member
mn_vette's Avatar
There was a blue L98 that had their first kit. he posted numbers here somewhere. Pretty impressive.
mn_vette is offline   Reply With Quote
Old 03-21-2006, 09:35 PM   #3
Upstate
CF Senior Member
Upstate's Avatar
Glad to see someone finally stepped up.
Upstate is offline   Reply With Quote
Old 03-22-2006, 04:09 AM   #4
drochau
CF Senior Member
drochau's Avatar
BUYER BEWARE!!!
I live in New Mexico and have heard NOTHING but horrible things about these guys.
This is our local car club/forum. 3k members and growing.
http://racingsouthwest.com/forums/in...HP+Performance
Use your discretion...they suck my .02
drochau is offline   Reply With Quote
Old 03-22-2006, 11:36 PM   #5
gsdave
CF Senior Member
gsdave's Avatar
Quote:
Was it here? I'd be interested to see the 'kit'. I did a search, but did not find anything.
__________________
'96 Grand Sport 016
'95 Corvette undergoing 383 transplant
'03 F150 SuperCrew 4wd
'70 LeMans Sport
gsdave is offline   Reply With Quote
Old 03-23-2006, 12:58 AM   #6
Baldturbofreak
CF Senior Member
Baldturbofreak's Avatar
Send a message via AIM to Baldturbofreak
Quote:
Originally Posted by drochau
BUYER BEWARE!!!
HOLY MOLY!!!!! What a read!
Baldturbofreak is offline   Reply With Quote
Old 03-23-2006, 12:26 PM   #7
mn_vette
CF Senior Member
mn_vette's Avatar
The guys name is EVLTWIN. I can't find any posts that he started, but let me see if I can compile a list of comments.
The turbo on my '85 is from HP performance in Roswell New Mexico. I don't know if they have developed it as a kit yet.
1985 L98, single turbo, stock internals, 364 RWHP, 497 lbs/ft RW torque. I have never had it to a track, so I don't know times. I know it is fun!
I have a single turbo system from HP Performance. Air conditioning is still there and functioning. Works great.
They told me the kit would be available 2 months after mine was done. I got mine back in beginning to mid June. So as far as I know they should be available. The website you refer to is a distributor not the guys at HP. Jimmy and Nathan at HP were always helpful. You can reach them at 505-623-2555.
Pictures were posted in a thread called Turbo Project Updates?? that was on here earlier. It is still up. It runs great. You can really feel the torque. The engine gets into the boost real quick. RWHP 361 and torque is RW 497. The engine is essentially stock. The exhaust is Borla. With the turbo there were a number of mods including a new computer, MSD ignition, Msd wires, custom headers, Spal fan with a switch that turns it on at 180, 160 thermostat, K&N filter, boost and fuel pressure guages, adjustable fuel pressure regulater, performance MAF, 42lb injectors and probably other stuff I am forgetting.
The motor is stock. It is on an '85 L98. It runs 9lbs of boost which can be adjusted. I spent about 6k on everything including labor.
Originally Posted by TONYDEE64
You can put a really large one in front of the radiator if you stand it up and move it back toward to engine, but air flow/coolant heat will likely be a problem.
That is where mine is. It is the same size as the radiator. I did have some cooling problems initially but then I cleaned out the area around the radiator (bunch of leaves and stuff) and installed a 3000cfm dual Spal fan. Now it runs between 178 and 183 degrees consistantly.
My engine is essentially stock. Prior to taking it the HP I had a chip, adjustable fuel pressure regulator, high performance MAF, optima battery, borla exhaust, high performance headers from Corvette Central, K&N air filter system, a chip and maybe some other "bolt-on" stuff. It had all made some difference. The car was rated from the factory at 230 (not RWHP). As I said before it dynoed at 231 RWHP in 2003. I talked to HP today. They had been trying to tune with Tuner Cat. Apparently they got little or no assistance from that company with the air/fuel ratio problem. They are now moving to the Tuner Pro software to try to figure it out. If anyone has suggestions I will relay them to HP. The problem is an air/fuel ratio too lean above 4000 rpms. I am in daily contact with HP and will certainly update as new info becomes available.
With some tuning it was 351 hp at 4700 rpm and 445 torque at 3700 rpm. I asked them to dial down the torque since I am simply looking to have unique driver, not a race car. I also wanted to have my transmission last for a least a while. They are continuing to tune and are going to do one more pull.
Those numbers were made with a max boost of 9.3 and an average of 8.8. They completed everything yesterday. There was an issue with the intake tube rubbing on the hood. It is now modified but they need to refinish the tube with jet hot or powder coating. Once that is done they will deliver it. They have driven it on the street. They said it is very responsive. It gets into the boost right away and stays there. I will probably have it this weekend.
I have the car! During normal driving it is the same as before, except the gas mileage is better. It has great accleration when you get into the boost. A 30mph jump seems instantaneous. The turbo sound is wicked. Its like a warning to whoever is next to me. Overall I am very happy. It looks cool, sounds cool and kicks butt.
You are correct. The turbo is where the battery was. The battery is in the driver's side compartment in the hatch area (two storage compartments, one driver and one passenger side). I am still able to use the removeable storage bin, and the battery is underneath. It remains very accessible. I have had it back about a month now. The only problem I have noticed is that the stock cooling system is not sufficent. It is running about 215 -217 F. Prior it ran about 180. HP ordered me a 3000 CFM Spal (?) dual fan and wiring harness. It will be wired to kick on at a certain temp and when more than 2lbs of boost are generated. I have noticed no difference in normal driving conditions. It runs as good as ever. There is one difference, I am getting 8 -9 MPG better than before.
I can't seem to find the pictures, but read through this page and you should be able to email some of the people there to get them.
http://forums.corvetteforum.com/show...1097483&page=2
Old 03-24-2006, 12:14 PM   #8
Demonic85
CF Senior Member
Demonic85's Avatar
i'd love to have a turbo on my '85, but it is a lot of money. That sucks that the guy with the stang got ripped off. I would think maybe it was miscommunication or something, but an engine is a pretty big thing to screw up.
Demonic85 is offline   Reply With Quote
Old 03-24-2006, 12:38 PM   #9
neat
CF Senior Member
Send a message via AIM to neat Send a message via MSN to neat
I didn't really see anything that would deter me from using HP turbo's. One guy went in on the day were closed, and the other guys said he got a bad motor, but never could really prove anything.
Did I miss something?
__________________
1991 Coupe - 6 Speed - Black on black - 11.37 @ 122.88 -
neat is offline   Reply With Quote
Old 03-24-2006, 12:48 PM   #10
neat
CF Senior Member
http://www.turbochargedpower.com/
Are these the same guys?
Old 03-24-2006, 01:32 PM   #11
redbullapril23
CF Senior Member
redbullapril23's Avatar
Send a message via AIM to redbullapril23
will the kit fit a 96 c4?
and what exactly does the kit include?
thanks your friend
Sean
redbullapril23 is offline   Reply With Quote
Old 03-24-2006, 01:42 PM   #12
drochau
CF Senior Member
drochau's Avatar
Yeah same guys. Give it a shot if you want. Just telling you what I know.
Old 03-24-2006, 02:55 PM   #13
gsdave
CF Senior Member
gsdave's Avatar
Thanks MN Vette!
Old 03-28-2006, 08:06 PM   #14
bill mcdonald
CF Senior Member
I have the pics here
Hope he does not mind me posting them
bill mcdonald is online now   Reply With Quote
Old 03-28-2006, 08:34 PM   #15
evltwin
CF Senior Member
evltwin's Avatar
That is my car. I am glad you posted the pics because I have still not made the effort to figure out how to get it done. I have had the car back for a year now. No problems with the performance. Initially I did have alot of problems with HP and the time frame in which they promised to get it done. Like alot of cars here my is 21 years old. I have had others things not related to the turbo go like the battery or a melted spark plug wire, but overall I am happy with the power and performance. Stock was 231 and as someone posted it is now 361 or 364. More than a 50% increase is not too bad. I paid less than that because they took money off for the delay. In the end I think it cost 3800 to 4000.
evltwin is offline   Reply With Quote
Old 04-02-2006, 06:57 PM   #16
red L98
CF Senior Member
red L98's Avatar
not bad for the price
Old 04-04-2006, 08:09 AM   #17
ncChris
CF Senior Member
Hmmm... 45 working days ?? Drochau's post??
That would make me a tad nervous. These guys must have a tremendous number of orders if they are 45 working days behind. I would look for several more postitive posts before investing hard earned dollars. My .02 cents
__________________
ncChris...96 Polo Green Lt4
4.10 gears
58 mm & ram air...solid cam
AFR Heads by...Lcvette
Best Run:: 11.51 @ 121.6mph w 1.64 60 foot
..95 red Lt1
3.75 gears...head work..lingenfelt cam..procharger
Tuning and set up by......Lcvette
Dynoed 512 rwhp
..91 ZR1 best run (pure stock) 13.12 @ 108
tturbos in design stage
ncChris is offline   Reply With Quote
Old 04-04-2006, 06:00 PM   #18
BrianCunningham
CF Senior Member
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Sweet setup, I was wondering if that was a good location.
__________________
Polo Green 95 LT1 6-spd
383 LT1/Vortech Supercharger/AFR heads/Rod end suspension/Penske-Hardbar dual rate coilovers/Wilwood 6pot brakes
NCCC Governor/Membership/WebMaster: www.baystatecorvetteclub.com
BrianCunningham is offline   Reply With Quote
Old 04-14-2006, 03:01 PM   #19
evltwin
CF Senior Member
evltwin's Avatar
I have not had any trouble with the location. I have had it out more since the weather is better. It is running great.
Old 04-15-2006, 09:54 PM   #20
BigTexas
CF Senior Member
BigTexas's Avatar
Is that kit for the LT1 also?
B.
BigTexas is offline   Reply With Quote
Reload this Page they have a turbo kit for C4..
Tags
1984, 85, c4, chip, corvette, corvettes, hp, jet, kit, kits, l98, manifold, single, turbo, twin, wwwhpturboscom
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 turbo kits Red91Vette C4 Forced Induction/Nitrous 46 01-07-2004 02:44 PM
Banks Twin Turbo Kit for L98 and LT1 Vettes available... Nate@CorvetteGarage C4 Tech/Performance 64 12-22-2003 02:34 AM
Banks New Twin Turbo system for the C4......possibly mn_vette C4 Forced Induction/Nitrous 24 12-18-2003 07:34 PM
Twin Turbo kit for L98 C4s? TheCorvetteKid C4 Forced Induction/Nitrous 125 08-15-2003 12:49 AM
if you have a C4 with a single turbo... '79ProwlerOrange C4 Forced Induction/Nitrous 14 01-23-2003 07:54 PM
StingrayCrazy, Monty, Twin_Turbo... i have a quick question. '79ProwlerOrange C3 Tech/Performance 103 01-13-2003 01:35 PM
Solutions to Cerra Turbo Kit Problems MelloYellow C5 Forced Induction/Nitrous 44 01-07-2003 01:46 PM
Turbo Kits for LT1 Vettes Trizney C4 Tech/Performance 19 12-28-2001 11:57 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
