Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-19-2006, 12:23 PM   #1
Schurters Blowen LT
CF Senior Member
Schurters Blowen LT's Avatar
Default Gen 7 HELP
I have a 95 T/A installing Gen 7 with the fasttrack kit..and the dual sync, i have the Accel Y cam/crank wire plug & play..
I am lost on what to do with the wires from the GEN 7 box, to the 8 pin Y plug (accel) and then with the wires coming out of the dual sync...
Any help would be great
thanks
Schurters Blowen LT is offline   Reply With Quote
Old 03-19-2006, 07:36 PM   #2
tjwong
CF Senior Member
Support Corvetteforum!
tjwong's Avatar
Send a message via AIM to tjwong
thanks
If you are using the Accel dual sync distributor, you need the Dual Sync adapter harness part number 74101 (it maybe a 77101) which will connect to the distributor and direct to the Accel G7 ignition harness 8 pin connector. It then will be plug and play.
tjwong is online now   Reply With Quote
Old 03-19-2006, 07:56 PM   #3
Schurters Blowen LT
CF Senior Member
thanks TJ,
Where i am lost is what wires do i need for the 8 pin,(gen 7 side) to make the 8 pin, to plug into the Accel Dual Sync adapter harness
Old 03-19-2006, 07:59 PM   #4
Schurters Blowen LT
CF Senior Member
i have the fast track harness, so i have to make the 8 pin up.........
Do you no off hand what the wires are for the dual sync?
the is
red -? red says 12 volt switched
black -ground
white -? i think this is the sig for the cam & crank
white with blue..says sheild
Old 03-19-2006, 08:57 PM   #5
tjwong
CF Senior Member
tjwong's Avatar
the is
black -ground
Go into your CalMap program, click on help and then go to drawings. There are circuit diagrams of the harness and that adapter harness.
Old 03-19-2006, 09:17 PM   #6
Schurters Blowen LT
CF Senior Member
So it would be Universal sefi ingation harness....? i should us that ..
Old 03-19-2006, 09:53 PM   #7
Schurters Blowen LT
CF Senior Member
ok looked over it and ...the only thing is it shows the cam & crank as a 2 wire when mine is 3 ?...BUT it shows red and black, the 3rd is a clear wire..matbe that is a sheild ?
Old 03-19-2006, 10:19 PM   #8
mn_vette
CF Senior Member
mn_vette's Avatar
You should check where the wires come into the DFI box itself. The middle wire should be the unused sheild
The crank signals should be the white, black, and purple.
The cam signals should be black and white.
There should be two blank wires on the 8pin connector.
The orange wire on the crank was not use, just shielding I guess. I've got it setup on my car with the fast track harness and dual sync. If you have any specific questions I can get the exact pin outs for you if you need them.
Cavity
C & G - Ground
D - orange crank to purple
E - black cam wire
F - white cam wire
H - crank white to white
mn_vette is offline   Reply With Quote
Old 03-19-2006, 10:32 PM   #9
Schurters Blowen LT
CF Senior Member
Cavity
C & G - Ground
E - black cam wire
F - white cam wire
Thank you thank you......yes if you could get me the pin outs on the 8 pin and if you could where they go at the Gen 7 box .. that would be great....
i don't have a purple wire ?...
thanks
Jeremy
Old 03-19-2006, 10:37 PM   #10
Schurters Blowen LT
CF Senior Member
the wires i have for cam and crank (fast track)
orange - i don't think this is anything for cam & crank, will have to ck
white cam & crank +
black cam & crank -
open wire sheild ?
and these wires goto (at gen box) a3,b3,c3,d3...
thanks for your help
Jeremy
Old 03-21-2006, 12:37 AM   #11
Schurters Blowen LT
CF Senior Member
anyone ?
Old 03-21-2006, 10:36 AM   #12
mn_vette
CF Senior Member
mn_vette's Avatar
I've got the stuff, but I forgot the note pad in my car. I'll go grab it today before lunch sometime.
Old 03-21-2006, 02:06 PM   #13
mn_vette
CF Senior Member
mn_vette's Avatar
Here's the answers to everything you need.
Dist Connector
HGFE
ABCD
Dist
A - Pink wire goes to Ignition voltage(power on key)
B - Blank
C - Black Crank wire - B3 on DFI
D - Purple Crank wire - A3 on DFI
E - Black Cam wire - D3 on DFI
F - White Cam wire - C3 on DFI
G - Black Crank wire - B3 on DFI (spliced together with C)
H - White Crank wire - J2 on DFI
NOTE TO SELF: When in the calmap software if you hit Ctrl + F1 you will bring up a wiring schematic of just about anything. It defaults to the wiring harness, but has a pull down menu for everything you could need.
I hope this helps. Good luck
Old 03-21-2006, 06:24 PM   #14
Schurters Blowen LT
CF Senior Member
thanks, i will look at everything wed and see ..thanks for your time
Reload this Page Gen 7 HELP
Tags
accel, diagram, dual, sync
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Gremlins attacked my car last night, help! mn_vette C4 Tech/Performance 29 06-24-2004 07:21 PM
Anyone Tune with Accel Gen 7.... mn_vette C4 Forced Induction/Nitrous 23 04-22-2004 01:32 PM
Accel Gen7 Tuning Help mn_vette C4 Scan & Tune 11 04-17-2004 01:12 AM
Nitrous Help Needed!!! mn_vette C4 Forced Induction/Nitrous 10 10-20-2003 07:53 PM
NEED HELP !! WHat aftermarket pcm system to go with for LT4???????? DieL C4 Scan & Tune 10 08-29-2003 11:48 PM
F.A.S.T vs. DFI GEN 7 WashingtonRacer Engine Mods 18 03-03-2003 08:42 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
