Quote:
Originally Posted by lcvette
Hey tom,
yeah we have a innovative setup and I can also throw her on the dyno locally and check everything out while scanning and pull a log.. do you have a tuning program recommendation? tunercat? lt1edit? is there anything else out there more user friendly? haven't looked at tuning software in a LONG time so going through the maps will have a bit of a learning curve, but a solid base tune would be very helpful!
Chris
Get TunerCat for less than $100 which is the tuner software and the $EE PCM definition you will have all you need. Also the Tuner software will allow you to tune various chip cars and trucks as well. You will also need a cable to talk to the PCM, that can be purchased from
www.akmcables.com or from
www.wotelectronics.com
