Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-15-2006, 06:24 PM   #1
jsavoy
CF Senior Member
jsavoy's Avatar
Default Supercharger Owners, lend me your ears...
I have a 96 LT1 S/C Coupe (ATI Procharger) that sounds a bit "odd". I've already sent it back to ATI for service but wanted to solicit some of your thoughts. Since I'm new to S/Cing, I wanted to get some "outside" opinions. The clips are at (http://www.sgacorvetteclub.com/sound.html). I converted these to flash files to reduce the size, but please give them a chance to load. I look forward to your thoughts...JS
jsavoy is offline   Reply With Quote
Old 03-15-2006, 07:02 PM   #2
blown87
CF Senior Member
blown87's Avatar
For some reason i could not hear them, i am sure it is a setting on my end.
blown87 is offline   Reply With Quote
Old 03-15-2006, 09:05 PM   #3
jsavoy
CF Senior Member
jsavoy's Avatar
You may have to download the current Macromedia Flash Player. (http://www.macromedia.com/shockwave/...ShockwaveFlash) Try this and let me know.
Old 03-15-2006, 09:18 PM   #4
AKS Racing
CF Senior Member
AKS Racing's Avatar
It wouldn't load for me either. I do have the latest FP.
Aaron
AKS Racing is offline   Reply With Quote
Old 03-15-2006, 09:26 PM   #5
jsavoy
CF Senior Member
jsavoy's Avatar
I don't know what's wrong. The right click function is enabled...you can save them then view them...JS
Old 03-17-2006, 02:11 PM   #6
Mo_Bandy
CF Senior Member
Mo_Bandy's Avatar
Are you sure is is getting oil?
Aside from that it pretty much sounds like it should.. they do sound like a "thrashing maching" at times especially when you rev and let up on it...
Mo
__________________
96 Black Coupe, Electric, Netgain 11HV electric motor 300v 2000A Zilla controller, 300v 2400a XS Power Batteries, ZF6 6 speed, QA1 Coil Overs,www.ndneyes.com/or for non electric www.ndneyes.com/mo
Mo_Bandy is offline   Reply With Quote
Old 03-17-2006, 07:14 PM   #7
jsavoy
CF Senior Member
jsavoy's Avatar
This S/C is self-contained, one of the reasons I went with Procharger. I serviced the unit after the 500 mi break in per the instructions/warranty information. I've put @ 2k on it and the rattle was progressively becoming louder. If you listen to the second file, the noise is consistent even when increasing the throttle. I'm new to S/C'ing and when tech support told me initially that it would make some noise and lessen as time went on. Should I expect this to be the normal sound when it returns from Procharger?
Old 03-17-2006, 08:11 PM   #8
Mo_Bandy
CF Senior Member
Mo_Bandy's Avatar
The best I could hear is sounded normal to me...
Mine makes various noises as well.. as I mentioned when you say rev and let up fast there wil be some noises form the pressure of the air hiting the throttle plates etc. You are using a bypass valve as well correct?
I would say you are good too go...
Mo
__________________
Old 03-17-2006, 08:55 PM   #9
jsavoy
CF Senior Member
jsavoy's Avatar
Yes, I'm using a bypass valve. I guess I'll wait to see what Procharger comes up with. Thanks for listening...JS
Old 03-19-2006, 02:40 AM   #10
Trog
CF Senior Member
Trog's Avatar
Mine is a D1 & today was my first real "trip" a two hour run out to the coast. Mine makes noise but more of a whine & gear noise, nothing like what I'm hearing in your vids. Yours is really loud... IMHO of course based on my also limited experience.
Trog is offline   Reply With Quote
Old 03-21-2006, 08:47 AM   #11
ncChris
CF Senior Member
My son just finished installing a p1sc in my 95 and it sounds much differently than yours. I'm sure the folks at Procharger will figure yours out quickly. My son goes by lcvette in these forums. I'm sure he'd be happy to share some thoughts with you.
__________________
ncChris...96 Polo Green Lt4
4.10 gears
58 mm & ram air...solid cam
AFR Heads by...Lcvette
Best Run:: 11.51 @ 121.6mph w 1.64 60 foot
..95 red Lt1
3.75 gears...head work..lingenfelt cam..procharger
Tuning and set up by......Lcvette
Dynoed 512 rwhp
..91 ZR1 best run (pure stock) 13.12 @ 108
tturbos in design stage
ncChris is offline   Reply With Quote
Old 03-21-2006, 08:29 PM   #12
gcrouse
CF Senior Member
gcrouse's Avatar
Quote:
I've got a P600b and it doesn't make anywhere near the racket yours does! Are you sure all the bearings didn't fall out of their races and are being digested in the gearbox????
Or maybe that's just how the SC models sound? Like the D1 above, my non-SC is mostly just gear whine...
gcrouse is offline   Reply With Quote
Old 03-28-2006, 08:46 AM   #13
djxib
CF Senior Member
djxib's Avatar
Yours sounds identical to my Vortech. I had the unit overhauled by Vortech in California a year ago with new gears and it is now extremely noisy at idle. However - above about 1500-2000 rpm the gears become quiet and it just makes a great wooshing noise.
If you are ever up Atlanta way give me a shout and we can compare supercharger noises!
Andy,
djxib is offline   Reply With Quote
Old 04-06-2006, 10:52 PM   #14
jsavoy
CF Senior Member
jsavoy's Avatar
Default Update/Thanks
First, THANK YOU to all of who responded to this thread and/or provided me your thoughts via PM. I spoke to James from ATI today (our second conversation). Initially he told me that the service tech's notes indicated that everything was within specs. I asked that he listen to the sound clips and his response was to disassemble the unit himself and "take a peek". He informed me that the "input shaft and gear didn't look right" so he replaced them and noted a definitive drop in the noise on the bench. I should receive the S/C tomorrow with any luck and will post the new sound clips for comparison.
Old 04-07-2006, 12:00 AM   #15
lcvette
CF Senior Member
lcvette's Avatar
Send a message via AIM to lcvette
excellent! I am glad he put his personal attention to it.. I have heard horrow stories of dealing with ATI, but so far being even a second time owner of one of their blower kits, I have been pleased with the respectful and helpful service they have given me. now their product finish leaves a little bit to be desired as far as fitment but my head unit has been running like a top..knock on wood!
Chris
lcvette is offline   Reply With Quote
Old 04-07-2006, 12:01 AM   #16
ncChris
CF Senior Member
Way to JS,
the squeeking wheel gets grease.. keep us posted
__________________
4.10 gears
..95 red Lt1
Dynoed 512 rwhp
Old 04-11-2006, 10:17 PM   #17
jsavoy
CF Senior Member
jsavoy's Avatar
Default New Sound Clip
The sound file has been posted (http://www.sgacorvetteclub.com/sound.html). The comparison files to use would be video clip 2 (pre-service) and video clip 4 (post-service). I'm going to drive it for a few weeks to see if it diminishes more. IMHO, the sound has dampened. Again, thanks and I appreciate your thoughts. JS
Old 04-12-2006, 10:33 AM   #18
MrNuke
CF Senior Member
MrNuke's Avatar
That head unit is FUGGED..
You can hear the added friction inside the unit.. It should NOT sound like that at idle.. Any head unit that does = going bad, or no oil in it..
I had a vortech and a paxton and have looked at cars with ATI's, none of them ever sounded like that..
I'd demand another unit, NOT a service of the same unit if it's within warranty. I've heard some companies like to keep 'servicing' units just so they eventually get out of warranty and then they can tell the customer to have to buy a new one..
MrNuke is offline   Reply With Quote
Reload this Page Supercharger Owners, lend me your ears...
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
