Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-11-2006, 03:33 PM   #1
SHINOBI-X
CF Senior Member
SHINOBI-X's Avatar
Send a message via Yahoo to SHINOBI-X
Default hi-compression with turbo
curious as to what is the highest compression any of you run with boost via a turbo or supercharger. This doesn't have to be a street application either. just seeing if anyone runnin 10.1 or better using race fuel?
SHINOBI-X is offline   Reply With Quote
Old 03-11-2006, 05:21 PM   #2
divette
CF Senior Member
divette's Avatar
Quote:
It will be possible to work, BUT ONLY at presence good intercooler.
There there will be a direct dependence - than acting air is better cooled,
The it will be possible to lift pressure of boost on your high degree more.
Example (for compression 10.2:1)
No intrcooler = 5-6 psi
Small intercooler = 7-8 psi
Average intercooler = 9-10 psi
Large intercooler = 12-14 psi
Also depends on a corner of ignition very much. But it already other theme....
But it is better to lower a compression down to 8:1 - then all easier
I on my TwinTurboVette have made in general 7.8:1 JE forged - I of problems I do not test even on 16 psi
Good luck
divette is offline   Reply With Quote
Old 03-11-2006, 08:28 PM   #3
Baldturbofreak
CF Senior Member
Baldturbofreak's Avatar
Send a message via AIM to Baldturbofreak
http://www.hotrod.com/techarticles/e...13_0312_turbo/
look halfway down.
"This 358ci small-block Chevy is about as rad as it can get and still use conventional 23-degree-valve-angle heads. Electronically managed by ACCEL Gen 7 DFI, the 10.0:1 engine runs a single large-frame Innovative GTB88 turbo and makes over 1,400 hp on C-16 race gas. Big race turbos are typically identified by the inducer orifice size--in this case 88 mm. "
Baldturbofreak is offline   Reply With Quote
Old 03-13-2006, 02:18 AM   #4
SHINOBI-X
CF Senior Member
SHINOBI-X's Avatar
thanks guys. Im trying to figure out my final compression ratio with all my specs. anyone have a site they can refer me too to figure it out so i can be sure what compression im actually running?
Old 03-13-2006, 11:33 AM   #5
Baldturbofreak
CF Senior Member
No but the math is 7th grade.
swept volume (bore area times stroke) divided by ending volume.(chamber volume + head gasket volume+piston dish volume)
That is assuming zero deck, if they are down the hole .010" then you will have to add that volume in as well.
Area of a circle= 3.1415 x (radius)^2 (squared)
To get cubic inches from cc's divide cc's by 16.3871
Should be easy for you to figure out from there. If you wanna get more advanced and figure out dynamic compression, let me know.
Old 03-13-2006, 12:54 PM   #6
neat
CF Senior Member
Send a message via AIM to neat Send a message via MSN to neat
Your dynamic compression ratio will play as large a role, if not larger than your static CR when determining if you can safely run some sort of FI.
Do some research on cam selection and dynmaic compression ratio. You could have an 11:1 static ratio and still run moderate boost (10 psi or so) if the combo was set-up properly.
Good luck, let us know what you decide.
__________________
1991 Coupe - 6 Speed - Black on black - 11.37 @ 122.88 -
neat is offline   Reply With Quote
Old 03-13-2006, 06:37 PM   #7
yedister
CF Senior Member
http://www.turbofast.com.au/TFcompB.html
http://www.rbracing-rsr.com/compression.htm
yedi
yedister is offline   Reply With Quote
Reload this Page hi-compression with turbo
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
A&A Corvette Performance:Forced Induction Q&A thread Andy@AandACorvette C5 Forced Induction/Nitrous 825 07-02-2010 01:23 PM
Turbo vs Supercharger (why are the turbos not at higher HP #s given similar boost/motor) QuickSilver2002 C5 Forced Induction/Nitrous 47 12-27-2003 02:39 PM
Banks Twin Turbo Kit for L98 and LT1 Vettes available... Nate@CorvetteGarage C4 Tech/Performance 64 12-22-2003 02:34 AM
Twin Turbo kit for L98 C4s? TheCorvetteKid C4 Forced Induction/Nitrous 125 08-15-2003 12:49 AM
~~[TURBO] L98 vs LT1, which ones better?~~ Light84vette C4 Forced Induction/Nitrous 40 06-29-2003 01:54 PM
Turbo concerns Hokie C5 Forced Induction/Nitrous 22 04-11-2003 11:47 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
