Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-09-2006, 12:18 AM   #1
89b2k
Junior Member
Default 427 tt sbc on dyno
Tw finally did some pulls on the dyno after wiring the accel gen 7 . Problem was, at 3200 it blew the tires off. Tom said it made 475hp and 535 ft lb of torque at that rpm. Hope to get better numbers if he can get some weight on the back of the car. Boost was 15.5 and no knock .
89b2k is offline   Reply With Quote
Old 03-09-2006, 09:32 AM   #2
mn_vette
CF Senior Member
mn_vette's Avatar
wow nice numbers
mn_vette is offline   Reply With Quote
Old 03-09-2006, 05:02 PM   #3
Bruce
CF Senior Member
Bruce's Avatar
Send a message via AIM to Bruce
that kind number at 3200rpm, it gonna be a insanely sick on the street. What size turbo are you using? Some information onthe turbo please. Damn, at 3200rpm, mine turbo is just start to spool.
Bruce is offline   Reply With Quote
Old 03-09-2006, 07:10 PM   #4
Upstate
CF Senior Member
Upstate's Avatar
Very nice
I assume this is a small block?. Would you mind sharing the specifics of your build? I am getting ready to assemble a 427 and planned on building for boost, but was talked out of it due to supposed durability and longevity factors. Specifically, the compression height of the piston with a 6" rod and the giant dish (-36cc) scared me away from the boost and I'll only have enough money to build it once .
Upstate is offline   Reply With Quote
Old 03-12-2006, 02:55 PM   #5
bill mcdonald
CF Senior Member
Nice! That thing is going to make some big power!
bill mcdonald is offline   Reply With Quote
Old 03-12-2006, 05:05 PM   #6
BAM92
CF Senior Member
BAM92's Avatar
I saw a tt427 over at MTI put down 722 rwhp. They had to have a couple of guys lay on the back to keep it on the rollers. It was a c5 though. You are definetly going to make some big power.
BAM92 is offline   Reply With Quote
Old 03-12-2006, 10:46 PM   #7
tjwong
CF Senior Member
Support Corvetteforum!
tjwong's Avatar
Send a message via AIM to tjwong
Well, so far I have got about 550hp and 600 ft/lbs at less than 8 PSI or just at 8. I have some issues with a wastegate that is giving me fits. And for some reason the wastegates are releiving more than they should even though I have them calibrated to lift at 9 psi, I can't seem to get any more boost. I am going to take a short break from this car and get Glens engine installed in the morning, then once the wastegate diagphram arrives I will move back to the TT car. There is more power in it, I know there is. It is just taking a bit longer than I had anticipated to convince the engine to give it up
tjwong is offline   Reply With Quote
Old 03-13-2006, 10:21 PM   #8
89b2k
Junior Member
Quote:
Originally Posted by Upstate
Very nice
It's a dart aluminum tall deck block with 6.125 rods. I think the pistons were -20 cc dish (I don't remember) with a compression of 8.5 . 227 afr heads o-ringed with T and D shaft rockers.
Old 03-18-2006, 09:40 PM   #9
Gold1986Vette420
CF Senior Member
Gold1986Vette420's Avatar
Quote:
Not to try to insult anyone on here but hp is computed by torque.
Torque * rpm / 5252 = HP
535 * 3200 / 5252 = ~326 HP
Gold1986Vette420 is offline   Reply With Quote
Old 03-20-2006, 12:46 AM   #10
89b2k
Junior Member
You are correct about the math,I'm sorry I didn't notice the error. Pretty sure the torque was correct but not the hp. Anyway, I will post the new numbers when Tom turns up the boost.
Old 04-15-2006, 03:06 AM   #11
89b2k
Junior Member
Ok. Tom just called tonite and gave me the new numbers. 680 rwhp and 710 lbft tq at 14.5 lb boost 91 octane. He said he would post the dyno-graph soon but I couldn't wait! Tom said that it still was spinning the tires and he thought it had over 700 rwhp in it . Since this is a mustang dyno, I was really happy with the numbers.I didn't know if my engine would make very much hp because the turbos are small t3/to4e60's. I can't go bigger because there is no room down by engine to fit them. I could possibly enlarge the compressor wheels to gain 100 to 150 more hp though.
Old 04-15-2006, 04:36 AM   #12
comp
CF Senior Member
comp's Avatar
comp is offline   Reply With Quote
Old 04-16-2006, 07:30 PM   #13
TONYDEE64
CF Senior Member
TONYDEE64's Avatar
Those numbers sound more like it!!!!! Awesome!!
TONYDEE64 is offline   Reply With Quote
Old 04-17-2006, 11:11 AM   #14
neat
CF Senior Member
Send a message via AIM to neat Send a message via MSN to neat
Got any pics of the set-up?
__________________
1991 Coupe - 6 Speed - Black on black - 11.37 @ 122.88 -
neat is offline   Reply With Quote
Old 04-17-2006, 11:43 AM   #15
tjwong
CF Senior Member
tjwong's Avatar
Here is Chucks dyno curve from the other night.
This curve was made at about 14 PSI it did bump 15 at one point, but even if I turned it up, measuring it was hard because the tires would break loose. I was alone tuning this beast and there was no one around to push down on the rear end to help traction. I know there is 700+ in it but on my dyno it would be hard to measure especially with this kind of torque! This curve is a filtered curve, another test sheet shows 676 and 731, but jeez at this rate a couple here and there isn't going to make a bit of a difference
Old 04-18-2006, 05:10 AM   #16
chuntington101
CF Senior Member
sounds like a really nice setup but do oyu have any pics????
Chris.
chuntington101 is offline   Reply With Quote
Old 04-18-2006, 02:31 PM   #17
bill mcdonald
CF Senior Member
here are his pics.
Old 05-08-2006, 11:19 PM   #18
89b2k
Junior Member
update... I went to get the car from Tom but I was not happy about the loud exhaust or the idle (It idled like Warren Johnson's pro stocker) .Tom did a great job and none of the problems are his fault, and he agreed to make changes for me. The cam was a 248/256 at .05 solid roller. Since I made max power before 5800,it was decided that a hydraulic cam of 238/236 would be better for driveability. Also, the 3" B and B exhaust is being changed to a lt1 2.75 " with boost actuated cutouts .
Old 05-09-2006, 01:25 PM   #19
red L98
CF Senior Member
red L98's Avatar
Send a message via AIM to red L98
nice , that’s what I would do , there is no need for big cams with boost car. small cam lots off boost and still drive it all over and make over 800 hp …. That’s what I always wanted but its hard when your trying to go fast on motor … good luck man car looks great
red L98 is offline   Reply With Quote
Old 05-09-2006, 02:19 PM   #20
86VX1
CF Senior Member
86VX1's Avatar
the car is an absolute beast of a machine, very
how about some pics of the turbo location?
86VX1 is offline   Reply With Quote
Reload this Page 427 tt sbc on dyno
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
"Asphault Crayons" - SBC 427 TT driving impressions Monty Engine Mods 19 04-15-2003 03:28 PM
"Asphault Crayons" - SBC 427 TT driving impressions. Monty C3 Tech/Performance 40 04-04-2003 12:37 PM
StingrayCrazy, Monty, Twin_Turbo... i have a quick question. '79ProwlerOrange C3 Tech/Performance 103 01-13-2003 01:35 PM
Still waiting for a TT but still not willing to pay $20K! MARK'S_C5TT C5 Forced Induction/Nitrous 77 07-12-2002 11:40 PM
Twin Turbo SBC 427 Dyno Session Results Monty Engine Mods 32 06-25-2002 02:00 PM
Steeroids rack/pinion for C3s - anybody got one? lyonsh C3 Tech/Performance 42 06-17-2002 11:44 AM
A little more progress - I should be dyno testing the TT SBC 427 next weekend Monty Engine Mods 36 06-17-2002 07:01 AM
Drove my TT Vett on the highway today. WashingtonRacer Engine Mods 22 06-11-2002 10:39 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
