Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-05-2006, 04:49 PM   #1
silver86
CF Senior Member
silver86's Avatar
Default Intake question
I have a TPIS BM lower, ported plenum and edelbrock runners. I'm adding a Carroll blower system, and was wondering if it would be better to stay with the stock intake.
silver86 is offline   Reply With Quote
Old 03-05-2006, 08:07 PM   #2
AKS Racing
CF Senior Member
AKS Racing's Avatar
To see more indicated boost , go back to the stock intake. To see lower indicated boost, but more power go with the aftermarket components.
Bottom line, stay with what you have.
Aaron
AKS Racing is offline   Reply With Quote
Old 03-07-2006, 04:39 PM   #3
TPI
CF Senior Member
Some one posted recently that a L98 with blower & accel super ram intake produced too much low end tork to be practicle. Your set up should produce more low end tork than the super ram. A friend has a 434 cu in L98 with super ram, & makes the same complaint & plans on a TPIS mini ram (similar to LT1/LT4 intake) I have heard of using a modified LT1 manifolde on L98, & there is a web site about this. Hopefully, others with experience will post about this.
TPI is offline   Reply With Quote
Old 03-07-2006, 04:58 PM   #4
mn_vette
CF Senior Member
mn_vette's Avatar
Quote:
HA HA HA HA HA too much torque HA HA HA HA
mn_vette is offline   Reply With Quote
Old 03-07-2006, 06:08 PM   #5
86VX1
CF Senior Member
86VX1's Avatar
too much torque?
thats like saying having too big a penis is a bad thing
86VX1 is offline   Reply With Quote
Old 03-07-2006, 06:21 PM   #6
TPI
CF Senior Member
Quote:
Dont laugh untill you have tried it. I didn't say "too much tork" I said two others with experience with plenum & long runners complained "too much tork" , "cant put on big enough tires to hook up". What is your experience?
Old 03-07-2006, 06:22 PM   #7
TPI
CF Senior Member
Quote:
Originally Posted by 86VX1
too much torque?
Ditto above. What is your experience?
Old 03-07-2006, 09:51 PM   #8
AKS Racing
CF Senior Member
AKS Racing's Avatar
I recently posted on here that with my motor and the large blower with the SR, the combo made too much torque. Following that conclusion, I switched to a MRII, but found that it did not make much difference, though I picked up some RWHP on the top.
I do believe that there is such thing as too much torque. I have run 147+MPH on the far end of the 1/4 mile, with a 2.7 sec '60' (11.0 time) on slicks. These are nasty times, and I needed to do something about that (though people think smoke down the track is cool). I modified the suspension, moved to the MR, played with the cam advance, then messed with the tuning. My 60' are better (in the 1.55 - 1.85 sec) depending on tires and track conditiond. But unfortunately, I can not assess much of that from the switch from the SR to the MRII.
Keep in mind, this is for a large motor with a big blower.
Aaron
Old 03-08-2006, 09:17 AM   #9
silver86
CF Senior Member
silver86's Avatar
Well....I already have a hell of a time breakin' em loose now with the factory size rims and tires and only minor mods so far. I bought some ZR1 size rims and tires, more for coolness than any possible chance of helping me hook this thing up.
My cam choice increases low end torque as well (in part to help offset the large parasitic drag of the older blower while cruising around town, I'll post specs when I can find them) and maxes out at around 5200rpm, about where I figure things will start to go bad with the runner setup and the older SN60 blower.
I've resigned myself to most likely sticking with the 2.59 ratio in the rear (anything more and, given the amount of rain we have down here, it might get down right scary {not that I ever drive it in the rain} so I guess I need to sell these 3.56's, huh?) and probably a 2500-3000 stall. The motor, outside of new springs and increased rocker ratio and cam, will be all stock, save for the intake swap and long-tube headers.
Old 03-08-2006, 07:20 PM   #10
TPI
CF Senior Member
My 86 with super ram & 1.6:1 rollers, otherwise stock, will rev to about 5200 RPM as well. I had a mini ram & same RPM's. Was 4400 before the manifold change. TPIS, maker of the mini ram, claims 6500 RPm "pulling strong all the way" with their custom tune. Accel says no tune needed with their super ram. My question is, will our modified L98's rev to 6500 RPM, pulling all the way, with a custom tune, or is TPIS passing gas? Does your motor max out at 5200 RPM due to characteristics of your motor, or is it tunning? Anyone have experience on this?
Old 03-08-2006, 11:27 PM   #11
AKS Racing
CF Senior Member
AKS Racing's Avatar
The SR seems to perform well to 5600 - 5800, while the MRII seems to be fine to 6000 - 6200. With FI, the MRII has no issue with 6600 (RWHP continued to climb).
There must have been something wrong in your combo if the MRII would not pull past 5200. Was this still the stock cam?
Aaron
Old 03-09-2006, 03:17 PM   #12
TPI
CF Senior Member
Aaron
They both would rev past 5200, but would go slower. The mini ram would pop & sputter like it was lean. The SR will keep reving higher, but slower & sounds strained & slower speed at the end of my approximate 1/4 mi. test strip. Yes, stock cam. I also found that it runs better & more low end tork with the stock throttle body compared to a 58mm TB with the SR. Only used 58mm with MR. Also with stock prom on both. Is it the tunning, or something else? Am I getting what you would expect, or should it pull strongly to 5600-5800 RPM? Same question for the thred starter "silver 86"?
Old 03-09-2006, 11:14 PM   #13
AKS Racing
CF Senior Member
AKS Racing's Avatar
Neither of these intakes will perform well if the car is not tuned to match the intake. Stock ECM with aftermarket intake yields low performance.
TPI, are you the guy that had issues with a '96 and a blower? And now you are having issues with mod parts on an '86? I might be throwing the match about now.
Aaron
Old 03-10-2006, 09:36 AM   #14
silver86
CF Senior Member
silver86's Avatar
I haven't thrashed this 86 out yet (only put 400 miles on it so far), but I will answer with what I saw on a previous 85 that I built. I actually pulled a motor from a 1990 Greenwood that had been bored .030, with fully ported heads with 2.02/1.6, ported factory lower intake, large runners, ported plenum and 52mm TB. I also ran LT stainless headers, gutted cat, and borla's, but never got the chance to change the diff from the 2.56's. I installed a custom grind Crane cam (I'll see if I can find the spec card), 1.5 RR, decked the heads .020 and stuffed it all into my 85 without changing the tune (I know, right?!).
If I remember correctly, my shift points at the strip were between 5700-5800 and ran 13.09@109 with a 2.02/60, a bad valve body locking me out of first gear (at least I didn't have to worry about tirespin) and on GS-C's. Maximum power seemed to hit in the low 5000 range and didn't drop until the high 5700's, but incredible torque throughout the rpm range. Sorry this is kinda vague, but this was 10 years ago. The main point is that I was seeing hefty power still in the mid to upper 5000 rpm's. Mid 4000 power peeks would send me looking for fuel pressure problems, clogged exhaust (if the cat was still on), or spark issues.
On the clogged exhaust note, I had a 93 Formula with these mods: headers, 3.73's, CAI, chip (speed density), Borla tunable exhaust, and pulley...I was still only pulling 13.9's@98 on streets. I took the car back to the header installer, and we found the cat had basically melted. We gutted and promptly went to 13.4's@103 still on the streets.
Old 03-10-2006, 03:56 PM   #15
TPI
CF Senior Member
Aaron
Yes, but the 86 runs much stronger with the super ram, 5 mph faster in 1/4 mi. I will get a custom tune after I put on my new headers. The 96 LT4 is a longer story explained in other posts. Currently I am awaiting delivery of a 383 short block which I will run NA untill I can get the parts and info to run without an FMU. See my other posts for why.
Reload this Page Intake question
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
LS6 Intake Question USARMYTTT C5 Tech 18 03-15-2005 05:55 AM
Need Your Opinions On Some Air Intake Systems..... FrankMark C5 General 42 01-12-2005 01:18 AM
don't be angry...intake question chris_garey C5 General 21 07-30-2004 08:17 PM
Intake Question Tolofou C4 Tech/Performance 27 05-22-2003 07:57 PM
Air intake question... Doughan C5 Tech 18 05-02-2002 03:48 PM
Holley / Lingenfelter intake question.... Nitro-C5 C5 Tech 13 04-13-2002 01:24 PM
intake question. please don't throw rocks... kewlbrz C5 Tech 11 11-27-2001 10:38 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
