Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-18-2005, 08:03 PM   #1
Trog
CF Senior Member
Trog's Avatar
Default more boost questions
So... where are you installing sending "units" for vacum/boost gauges, fuel pressure gauges?
Any thoughts on just installing a good fuel pump & upgrading to that nice pump wiring kit I've saved the link to already instead of installing the procharger "auxillary" pump.
thanks for the continued input & advice!
Trog is offline   Reply With Quote
Old 11-18-2005, 09:18 PM   #2
Mo_Bandy
CF Senior Member
Mo_Bandy's Avatar
Trog,
I can probably speak for most of us. We generally mount our fuel pressure and boost gauges in the A-pillar, you can get them through Summit or other places.
In terms of fuel pumps, I for one have upgraded my in-tank unit and also upgraded my accesory pump as well see my signature). Greg @ Blower works greg@blowerworks.net has done some great work on different pumps and the flow and current draw.
hope this helps!
Mo
__________________
96 Black Coupe, Electric, Netgain 11HV electric motor 300v 2000A Zilla controller, 300v 2400a XS Power Batteries, ZF6 6 speed, QA1 Coil Overs,www.ndneyes.com/or for non electric www.ndneyes.com/mo
Mo_Bandy is offline   Reply With Quote
Old 11-18-2005, 11:53 PM   #3
lcvette
CF Senior Member
lcvette's Avatar
Send a message via AIM to lcvette
dual gauge pod, wide band O2 and boost gauges.
for fuel, i am expecting a little more power then perhaps you are but decided on parallel dual intank walbro GS340S's, according to Gregs data they should support around a 1000 HP. another good way to go is a single intank replacement with racetronix kit and if you want more you can add a boost-a-pump I think with the stock line and rails it is good to about 600 at the wheels. or you could add gregs inline and it made some nice power support as well, do a search for his post on fuel pump test data to decide which setup with meet the fuel requirements for your power goals!
Chris
lcvette is offline   Reply With Quote
Old 11-19-2005, 02:47 AM   #4
Trog
CF Senior Member
Trog's Avatar
Gauge pod is pretty obvious. Actually wasn't what I was asking...
Where are you installing the sending units under the hood?
Fuel pressure from the fuel rail schrader valve or?? Boost/vacum, on the upper plenum or???
Racetronix kit w/ high vol pump & wiring kit was what I was looking at installing. Seems to be enough fuel for the amount of HP I am looking at.
Thanks!
Old 11-19-2005, 02:49 AM   #5
lcvette
CF Senior Member
lcvette's Avatar
yes on both counts! shrader and upper manifold..
Old 11-19-2005, 02:53 AM   #6
Trog
CF Senior Member
Trog's Avatar
Okay, a little more detail on the vacum. I'm pretty familiar w/ my curr. setup but a pic is always helpful.
Thanks!
Old 11-19-2005, 06:03 AM   #7
Mo_Bandy
CF Senior Member
Mo_Bandy's Avatar
Hi TRog,
Ah ok... sorry.... The schrader is the easiest... I run mine inline from the fuel line, but have AN 6's on my fuel rail ( electronic pressure switch). Also in the boost guage I'm using a Autometer with the boost log, so I have the map on the passengerside manifold as close to the vacuum fittings as possible, also you want to use rigid hose where ever possible...
Mo
__________________
Old 11-19-2005, 12:36 PM   #8
lisoundsvette
CF Senior Member
lisoundsvette's Avatar
if have an autometer fuel presure gauge..i mounted the sending unit behind the license plate after the inline pump i am using a walbro system intank and inline along with a racetronics fuel pump power harness all from blowerworks . my auto meter boost/vacum gauge is "t"d off the map sensor wich is mounted on my fire wall right behind the intake manifold. then both gauges are on the a pillar
lisoundsvette is offline   Reply With Quote
Old 11-19-2005, 02:48 PM   #9
Trog
CF Senior Member
Trog's Avatar
Thanks, I have some ideas now. I'll also take a look at the boost log gauge versions.
Reload this Page more boost questions
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
D1sc vs. p1sc questions for 2000 c5 TT_Vert C5 Forced Induction/Nitrous 17 05-04-2004 04:41 PM
About to order an ATI Procharger P600B HO - Questions... Blueyednd C4 Forced Induction/Nitrous 37 12-27-2003 12:22 PM
ATI and N20 on 383 lots of questions inside... Nitro-C5 C5 Forced Induction/Nitrous 14 10-08-2003 06:07 PM
Vortech Questions - bugs, etc? JakeL C5 Forced Induction/Nitrous 21 08-18-2003 01:22 AM
L98 supercharger questions faj C4 Forced Induction/Nitrous 17 03-11-2003 05:26 PM
Twin Turbo questions vader86 Engine Mods 22 01-29-2002 12:02 PM
More L48 questions CF6873 C3 Tech/Performance 9 08-29-2001 09:54 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
