What hp/tq does your boosted car put out and what does it run in the 1/8 and 1/4?
I saw an awesome thread like this with over 500 posts on a different forum. Try to list specifics on your combo so that we can get an idea of what stuff is capable. That question pops up on this forum once a month, so if we all list our stuff, then we can refer them back to this thread...
"red dragon" , 1992 383, approx 9.75 compression, LT4 intake and heads, auto, vortech s trim, 6 rib, gregs inlet pipe, 2.85" pulley, 3.73 gears. Unknown spec cam(bought the car used), alky injection with progressive flow of 60% alky/40% distilled h20, 15 gph.
1/8 mile times to come tonight.
__________________
2004 Jaguar S type R. 4.2L V8 w/ Stiegemeier Snakebite Eaton M112 w/Alky Injection. H&R springs...
92 383, CNC'd LT4 top end, auto, custom vortech YSI trim, progressive alky kit, brembo 13.5's, magnesium speedline 18"'s with 275/335s, 7.30's@97 in the 1/8 (old combo)... The build up of an Low 10 second daily driver.
89 Saleen Clone with a 335" T trim'd blower motor. DFI, CNC'd victor jr's, vic 5.0. Was shooting for high 9's and 740 rwhp. Gone, but definately not forgotten...
L98, 9.2:1 scr, AFR215CPs w/massive porting (1206FP) and shaft rockers, very large solid roller, MRII (massively ported, cut apart and rewelded) w/ MB (fixing to change to converted 4 BBL intake), Procharger on custom brackets and pullies, custom I/C, ZF6 w/ McCleod aluminum Twin, custom braced 3.45D44. Fast tuned. ZR1 wheels with 275/315s, drag radials for the street.
I run 10.5 ET Drags and skinnies at the track.
__________________
1987 Roadster (Yellow), 30K miles, ZF, D44, FI, a tad bit of engine work, yada, yada, yada ... Kinda quick (maybe a tic faster than stock)!
1989 Coupe (Red), 40K miles. Apart for now, deciding future path.
1988 Callaway TT #48. Has 7.5:1 comp. ratio, large Wonderbar and ported wastegates upgrades, and large runners with stock extrude honed intake base. Car made 420rwhp and 586rwtq in 12lbs of boost and 93 octane.
Have not been to the track in this car (don't really plan to, because knowing my luck, something major would break... ), so no timeslips to speak of.
Looking forward to reading about the big number cars lurking out there!
easycreeper,
My brother has a pair of Callaways, the '88 Aerobody is really nice (totally stock), but the '87 std body uses the smaller turbos and is not nearly as nice (really just a decent driver). He has asked me to begin to look at modifying a spare MRII to use on the '87 motor with some other upgrades (i.e. turbos, heads, cam), but no changes to the I/Cs. Was there a reason that you stuck with the original base and added large tube runners? Was this due to all of the fab work required to step to one of the better intakes (MR, Stealthram, etc.).
I have a miniram setup for a Callaway . It has 16 injectors and the front of the manifold is machined to bolt up to the Callaway ramshorn. Let me know if you are interested .
Best 60' was a 1.72
Best 1/8 et was 7.38 (I backed it up with a 7.41)
Best mph was 97.3
my best run as a 1.76', 7.389 @ 97.27 which I don't think is too bad for the first time out. I have a stock converter which is taking a tenth or two away from me. With the only change of the converter, I should be able to run with the 10 second cars now. Runs were on a 17" drag radial.
motor was a tad lean. I need to go up one nozzle size on the alky injection. Knock was pretty low but was still present (.8 or so).
It was fun to pull away from very loud, intimidating sounding cars and see them in my rearview.
Let's see some more times guys...
__________________
easycreeper,
Thanks,
Aaron
Actually, the previous owner of the car had the large runners and extrude honed base put on the car as part of the negotiated purchase price. The new intake helped the car make power levels comparable to the original intake (435rwhp/575rwtq), but with less boost and lower octane.
Personally, I would love to have a MiniRam on the car. Unfortunately, there is quite a bit of modification that has to take place in order to have it mate up with the ram's horn. There is a beam of light, though. Callaway has been considering remanufacturing the 100+ intake package for those of us that did not have the opportunity to purchase one of the few cars that left Callaway with that modification. I would like to see 89b2k's MR, though.
__________________
my 94 convert. 383 * s-trim*gasesous intercooling from blowerworks* auto*354rear
dyno'd 496 hp and 543 tq
best times:
60ft 1.52
8th 7.01 97.89 mph
1/4 10.98 124 mph
I sure do wish I had your 60' times. I used to run in the 1.6 sec range when I was spraying and running high 11s - low 12s. I now pretty consistently run in the 1.8 sec range, with an occasional very high 1.7 or low 1.8 sec.
What's your secret? Care to elaborate on the suspension or other tricks?
aks, what converter and gears are you running. What tires?
__________________
I run a ZF6 with a McLeod twin disk with Aluminum flywheel.
Quote:
Originally Posted by qwiketz
What tires?
For the strip, I run ET drags, with front Skinnies on Welds. For the street, I run BFG DRs on 11" wheels, with BFG Comp TAs up front.
It just used to hook so much better when I was about 2 secs slower. It spins on the bottom end and will skate on the top end if you really have the tune spot on. But boy does this thing charge and MPH on the top.
Thanks,
Aaron
no real secrets here.. front sway bar diconnected ,factory tires inflated to 40lbs rear 26x10.5x16 et streets at 15lbs stocks billstein shocks all around (may change them) gm heavy duty rear spring it thinks its for the z51. launch the car at 1800rmp and go.
