Just got a new toy in the mail a FJO progressive mini controller. This thing is way to cool and I now can't wait to get the darn nitrous installed (waiting on my solenoids to get back). It was only $200, about the cost of a TPS and Window switch.
Check out some of features
TPS controlled window switch, (no need for a mechanical switch here)
First gear lock out
RPM cut off
RPM trigger
Two stage progressive control (I will only be using stage one for the moment)
Time based or RPM based progressive curve so you can bring the nitrous on progressively and you can use software to adjust the curve with. The software allows you to smooth and raise progression lines with in the curve to adjust the nitrous progression instead of a straight curve selection.
__________________
Built Not Bought 414RWHP 412 RWTQ
383 Stroker, Forged Scat rotating assy & SRP pistons, AFR 195 More performance comp Ported heads,Comp 306 Cam, Comp Pro Mag 1.6 R/R, LT4 port matched and 58mm bored intake, Holley 58mm TB, Stainless LT headers, Magna Flow cat back (No cats), DELTEQ ignition, FMS 36# injectors Meziere W/P, BeCool Radiator
