Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-06-2005, 07:44 PM   #1
lisoundsvette
CF Senior Member
lisoundsvette's Avatar
Default just got into the 10's 383/vortech
with the professional help from greg at blowerworks i was able to get my 1994 convertible into the 10's. *** 10.98 @ 124mph ***
the car has a 383 cu. in, 11 lb. vortech s-trim ,gaseous intercolling,2600 stall,354 rear. et streets/slicks enabled a 1.52 60foot.
lisoundsvette is offline   Reply With Quote
Old 11-06-2005, 08:07 PM   #2
zelement
CF Senior Member
Send a message via AIM to zelement
Very NICE! that's what I like to see
zelement is offline   Reply With Quote
Old 11-06-2005, 11:14 PM   #3
Mo_Bandy
CF Senior Member
Mo_Bandy's Avatar
Way to go!
Congrats!
Mo
__________________
96 Black Coupe, Electric, Netgain 11HV electric motor 300v 2000A Zilla controller, 300v 2400a XS Power Batteries, ZF6 6 speed, QA1 Coil Overs,www.ndneyes.com/or for non electric www.ndneyes.com/mo
Mo_Bandy is offline   Reply With Quote
Old 11-06-2005, 11:45 PM   #4
qwiketz
CF Senior Member
qwiketz's Avatar
awesome!! What kind of rwhp did it take to make that trap speed? Did it take much work to get that 1.54 60 foot? Do you have qa1's?
__________________
2004 Jaguar S type R. 4.2L V8 w/ Stiegemeier Snakebite Eaton M112 w/Alky Injection. H&R springs...
92 383, CNC'd LT4 top end, auto, custom vortech YSI trim, progressive alky kit, brembo 13.5's, magnesium speedline 18"'s with 275/335s, 7.30's@97 in the 1/8 (old combo)... The build up of an Low 10 second daily driver.
89 Saleen Clone with a 335" T trim'd blower motor. DFI, CNC'd victor jr's, vic 5.0. Was shooting for high 9's and 740 rwhp. Gone, but definately not forgotten...
qwiketz is offline   Reply With Quote
Old 11-07-2005, 03:20 AM   #5
Bruce
CF Senior Member
Bruce's Avatar
Send a message via AIM to Bruce
Very nice. Congr on the 10s. I am curious why your mile are kinda low? should in the 127+ mph. Just a thought.
Bruce is offline   Reply With Quote
Old 11-07-2005, 09:11 AM   #6
lisoundsvette
CF Senior Member
on the dyno the car makes 497 hp. and 542 tq. those ofcourse where the best readings i got back in august.
as far as my 60ft times my suspension is factory stock all i did was disconnect the front sway bar put on the street slicks with about 15lbs pressure and launched the car at about 1800 rpm.
my mph should be a bit higher but my 2nd to 3rd shift needs to be reprogramed.. i bounced off the rev-limiter about 4 times till it shifted into 3rd.
Old 11-07-2005, 10:02 AM   #7
Alvin
CF Senior Member
St. Jude Donor '05
Alvin's Avatar
What was your 1/8th mle times?
Alvin is offline   Reply With Quote
Old 11-07-2005, 11:16 AM   #8
mn_vette
CF Senior Member
mn_vette's Avatar
Congrats on the times. Seeing that give me great expectatoins for my setup for next year, Keep up the good work!
mn_vette is offline   Reply With Quote
Old 11-07-2005, 10:29 PM   #9
qwiketz
CF Senior Member
qwiketz's Avatar
great job. I love hearing about the drag racing of these cars knowing all the hard work that goes into them.
__________________
Old 11-08-2005, 12:02 PM   #10
lisoundsvette
CF Senior Member
my 1/8 mile times were 7.07 @ 97.11 mph and 7.01 @ 97.89 mph
Old 11-08-2005, 02:04 PM   #11
86VX1
CF Senior Member
86VX1's Avatar
hey is that a dana 36 with 3.54's or dana 44?
86VX1 is offline   Reply With Quote
Old 11-08-2005, 02:09 PM   #12
lisoundsvette
CF Senior Member
Quote:
after breaking 3 dana 36's with 3.73 i switched to a dana 44 w/3.54 and so far so good. the only way to stay together.
Old 11-11-2005, 12:37 AM   #13
qwiketz
CF Senior Member
qwiketz's Avatar
can you post more details on your engine? Our setups seem pretty similar other than your stall converter.
__________________
Old 11-11-2005, 04:58 PM   #14
lisoundsvette
CF Senior Member
Quote:
1994 CORVETTE CONVERTIBLE
COMPETITION YELLOW 1 OF 834
OWNER JOHN KOHRONAS
MOTOR CHEVROLET LT-1 STROKED TO 383 cu.in
POWER ADDER VORTECH S-TRIM V-1 SUPERCHARGER W/ 2.87 6 RIB PULLEY
AIR INTAKE TUBE MODIFIED BY BLOWER WORKS
INTERCOOLING BLOWERWORKS GASESOUS INTERCOOLING 50% METHONOL
CRANKSHAFT EAGLE 4340 FORGED STEEL. 3.75 STROKE
RODS EAGLE 6 inch ESP 4340 FORGED STEEL W/ FLOATING PINS
PISTONS JE FORGED / DISHED .030 OVER BORE SPEED PRO RINGS
COMPRESSION RATIO 9.5:1
CAMSHAFT COMP CAM LT-1 276 HR 14 220/230 @ . 050 540 LIFT
LOBE SEPARATION 114.0 GM 1.6 ROLLER ROCKERS
SPRINGS COMP CAM SPRINGS #94116
HEADS GM LT-1 PORT MATCHED & POLISHED BLEND IN SHORT
TURNS & BOWLS FLOWED 237.3 / 159 @ .550 LIFT
VALVES MANLEY 1.94 /1.50 STAINLESS RACE FLOW HP VALVES
THOTTLEBODY BBK/EDELBROCK 52 MM
INTAKE LT-4 INTAKE PORTED & GASKET MATCHED
IGNITION CRANE HI-6TR MSD IGNITION COIL MSD 8.5 MM WIRES
PLUGS CHAMPION 7401 DOULBLE PLATINUM GAP@ .040
FUEL SYSTEM WALBRO GSS340M 255L/HR @ 43.5 LBS FEEDING
WALBRO IN-LINE BOOSTER PUMP
INJECTORS FMS 42 LBS/HR
EXHAUST TPIS 1 ¾ LONG TUBE HEADER, 3inch EXHAUST W/ X PIPE
DYNAFLOW MUFFLERS
TRANSMISSION 4L60E PTS SYSTEM BY LEVEL 10
2600 RPM STALL SPEED CONVERTOR
REAR DANA 44 W/ 3:54 RATIO
SUSPENSION BILSTEIN Z-51 GAS SHOCKS UPGRADED REAR SPRING
Reload this Page just got into the 10's 383/vortech
Tags
10s, 29, 383, c4, corvette, hr, lt4, spring, strim, supercharger, ttrim, vortech, vs, ysi, zz383
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
procharger vs. vortech EVIL C5 Forced Induction/Nitrous 32 09-07-2003 01:59 AM
Cam for Blower and 383?? Need help choosing! krivera C4 Forced Induction/Nitrous 23 04-15-2003 12:29 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
