The only difference between the stock pulleys and the March power & amp pulleys is the crank size, stock 7 1/2" vs 6" on the March. (on my 86).
Is anyone using these with a supercharger?
Would you have to get a smaller supercharger pulley to keep your boost level the same? Thanks
Hmmm... so if I actually wanted a little less boost, I could use my march instead of going back to stock & accomplish the same thing as buying a larger compressor pully?
