Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-03-2005, 08:46 AM   #1
HJV11
CF Senior Member
HJV11's Avatar
Send a message via AIM to HJV11
Default New cam is a nice addition on my single system.
Well I finally got away from the stock LT1 cam which I was able to get 585RWHP/628RWTQ Sae corrected at 15PSI. I went with a 232/232 .540(1.5)lift 114LSA+6. I stopped by the dyno to pull some data with the new cam (no tuning) and the results are encourging. I made 650RWHP/652RWTQ at 15PSI. I believe there is a fair amount left in it as it sits, but I need to upgrade the fuel supply prior to pushing harder. I gained alot under the curve which I did not expect in areas (IE: gainig 90hp/70tq at 3600RPM) due to the new cam helping spool the turbo alot faster. But all in all I am pleased. All runs are on 93 octane.
HJV11 is offline   Reply With Quote
Old 11-03-2005, 10:21 AM   #2
mn_vette
CF Senior Member
mn_vette's Avatar
Sweetness!!!
mn_vette is offline   Reply With Quote
Old 11-03-2005, 02:34 PM   #3
lcvette
CF Senior Member
lcvette's Avatar
Send a message via AIM to lcvette
outstanding, now you have me wondering if I should up my cam selection before I plunk the motor in.. although, you are running moe cubes then I am so my LT4 cam may still be alright for my displacement.. ah.... decisions decisions.. think I will start with the stocker.. but that is phenominal gains with just a cam swap! now go upgrade your fuel system and turn up the boost!
Chris
lcvette is offline   Reply With Quote
Old 11-03-2005, 08:53 PM   #4
HJV11
CF Senior Member
HJV11's Avatar
Yea Chris, I think my advice is stick with the LT4 cam for now. It is a "known good item" and should be pretty easy to tune for, then once you have worked the bugs out then go bigger. I am looking at the mega squirt stuff right now. I am tired of all the baggage that comes with using the stock PCM and a 2 bar MAP. I may try to affix a Ford EDIS 36-1 sheel to my balancer and go that route.
Old 11-03-2005, 09:21 PM   #5
ANTI VENOM
CF Senior Member
ANTI VENOM's Avatar
I'm thinking twice about my 224/224 cam in my 383 now. I think it will be a nice little "starter" cam. lol
Great numbers, what is your turbo and how are you piped?
__________________
91 (383 LT1 turbo, under construction)
92 (Heads, Cam, Exhaust)
ANTI VENOM is offline   Reply With Quote
Old 11-03-2005, 10:53 PM   #6
HJV11
CF Senior Member
HJV11's Avatar
I am running aa Schwitzer HT400 that I got through AEBS (the race shop I part time with works with them sometimes). It is a T6 based turbo similar to a large frame T88.
As for piping I am set up very similar to Chris.
And thank you all for the nice comments.
Old 11-03-2005, 11:34 PM   #7
lcvette
CF Senior Member
lcvette's Avatar
yeah I think I will stick with the stocker for now.. can't be all that bad and I am not feeding a 383 either.. my loley 355 doesn't need as much time to let the hair dryer to its job.. however, Antivenom.. what are the specs of your cam? may be interested in it if ya decide to upgrade down the road!
Chris
Reload this Page New cam is a nice addition on my single system.
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 Technical Summary and FAQ - Please Read on a Regular Basis. bogus C4 Tech/Performance 82 09-15-2011 12:07 PM
C6 Z06 Frequently Asked Questions(FAQ) LTC Z06 C6 Z06 Discussion 56 08-02-2011 03:23 PM
NEW DYNO #'S!! 427Hotrod C3 Tech/Performance 15 06-30-2003 10:22 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
