Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-29-2005, 10:27 AM   #1
rkubara
CF Member
rkubara's Avatar
Default lowering the boost for a Vorthech
I just bought a 1994 Corvette C4 with a Vortech supercharger on an LT1 with 95,000 miles on it. It is running 14 lbs of boost and I would like to lower it. I gather the only way to do this is change the pulley? Is there any other way? Does anyone know what size pulley I need or how I determine it? Where do I get these pulleys? Vortech? Are there generic brands?
rkubara is offline   Reply With Quote
Old 10-29-2005, 12:00 PM   #2
lead foot 85 vet
CF Senior Member
Quote:
first you'll need to know which supercharger head unit you have . then the O.D. size of the superchargerg pulley on it now....shop on the internet for a larger O.D. pulley....they are rated by psi boost per size. some of the guys on here like greg at blowerworks for vortech products........also some of the guys here would give there left nut to get 14 psi on a lt1....very impressive
lead foot 85 vet is offline   Reply With Quote
Old 10-29-2005, 12:25 PM   #3
tjwong
CF Senior Member
Support Corvetteforum!
tjwong's Avatar
Send a message via AIM to tjwong
Quote:
Ya that is so true, them old systems had a hard time making what they claimed (6 PSI) let alone 14 without doing a lot of expensive modifications to there kits.
tjwong is offline   Reply With Quote
Old 10-29-2005, 07:36 PM   #4
TM-Z06
CF Senior Member
Send a message via Yahoo to TM-Z06
To lower boost:
1 - smaller s/c and/or crank pulley
2 - Create a restriction on the inlet side of the blower
3 - Lower your RPM limit (boost is relative to rpm)
I recommend #1
TM-Z06 is offline   Reply With Quote
Old 10-29-2005, 10:39 PM   #5
POLOVETTE 94
CF Senior Member
I would like to know more details on your "14 pounds of boost". At what RPM are you seeing this? Is there a possibility of gauge inaccuracy here? If not, I'd say you may have come across a car with more "modifications" than you thought. Many have to make more than a pulley change to see that much actual boost.
POLOVETTE 94 is offline   Reply With Quote
Old 10-30-2005, 01:49 AM   #6
rkubara
CF Member
rkubara's Avatar
It actually reads 16 lbs at about 1800 RPM. The gauge reads 1 lb when the car is off. Yes there are other things done to the engine but I don't think they would impact boost? Isn't that strickly the supercharger?
The thing is too snakey, can't keep the traction control from kicking in and when it is off, can't keep the 285x30x18's gripping at any speed lower than 30 MPH.
Old 10-30-2005, 02:46 AM   #7
zelement
CF Senior Member
Send a message via AIM to zelement
i think you got a broken boost guage.
zelement is offline   Reply With Quote
Old 10-30-2005, 10:42 AM   #8
POLOVETTE 94
CF Senior Member
Old 10-30-2005, 12:34 PM   #9
tjwong
CF Senior Member
tjwong's Avatar
Quote:
I think you need to get another gauge and verify the boost that you "think" you are getting. A simple vacuum/fuel pressure gauge from any auto parts store will do the job. Just "T" it into the gauge port that your gauge is connected to now. Get enough small vacuum hose to get the gauge into the car and drive it. Get it into third gear if you got a M6 car, and at about 35 MPH mat the throttle. You won't be frying the tires in third at that speed and the gauge should show you what boost you are really getting.
Old 10-30-2005, 12:50 PM   #10
Alvin
CF Senior Member
St. Jude Donor '05
Alvin's Avatar
I think this guy is meaning vaccum.. I had a kid get in my car one day and said.. whoa you got 20 pounds of boost at idle? I said no.. I got 20 inches of vaccum
Alvin is offline   Reply With Quote
Old 10-30-2005, 05:05 PM   #11
zelement
CF Senior Member
I hope that's not the case with him.
Old 10-30-2005, 07:12 PM   #12
rkubara
CF Member
rkubara's Avatar
It's not the case, the gauge reads "Boost PSI". But I will try to get another to check against it.
Old 10-30-2005, 07:26 PM   #13
Bruce
CF Senior Member
Bruce's Avatar
Send a message via AIM to Bruce
NO way you are getting 16psi of boost. Unless the drive system is modified and your motor is built to hold that much boost and your fuel system is heavily modified. Have you ever ride in a car with a V8 with 16psi? Trust me and every one here is telling you some thing is wrong with guage or whatever. Because few people here answering your post including me are all own a supercharged ranging from Zelement 377ci supercharged to my 383LT1 and TJ 396LT4 Vortech charged.
ps. 16psi at only 1800rpm? yeah right. I am willing to bet, Even a SY trim cannot even do that.
Bruce is offline   Reply With Quote
Old 10-31-2005, 02:18 AM   #14
rkubara
CF Member
rkubara's Avatar
My idle has been stuck at 1800 RPM since I got the car last week and I have been trying to fix it at the same time I posted this note asking how to turn the boost down. I didn't think the two were related, but I just learned today that the IAC motor has failed and the valve it slightly open. I have no idea if this is affecting the boost or not but I will be putting in a new IAC and will try to get another gauge to check. However I am leaving on a two-week road trip and won't be posting the results for a while.
Considering all the comments, and I am new to superchargers, I gather something isn't right with my readings. Regardless, the car is way to wild and I still want to reduce the boost regardless what it is now.
Old 10-31-2005, 03:28 AM   #15
Mo_Bandy
CF Senior Member
Mo_Bandy's Avatar
If you are running the stock balancer which is 7 inches... if you have a 3.125 pulley on the S/C thet would put you at the "stock" settings that Vortech was selling to give 6-8 pounds of boost on a LT1....
I also agree with the above posts, I was running a 8 rib up to 6000 rpm and was only tapping 12-13 pounds of boost.... I'd guess your boost guage is bad, the IAC will effect the vac reading...
16 pounds without intercooling or forged top and bottom end mmmm dun think so... I don't think a stock engine would handle it...
Mo
__________________
96 Black Coupe, Electric, Netgain 11HV electric motor 300v 2000A Zilla controller, 300v 2400a XS Power Batteries, ZF6 6 speed, QA1 Coil Overs,www.ndneyes.com/or for non electric www.ndneyes.com/mo
Mo_Bandy is offline   Reply With Quote
Old 10-31-2005, 10:53 PM   #16
qwiketz
CF Senior Member
qwiketz's Avatar
sounds about 10 lbs high for a box stock vortech kit. I've done almost everything (short of an 8 rib conversion) short of upgrading to a t trim and I'm getting 9lbs at the very most. With 9 lbs, I can light up the 335 p zero's anywhere under 70mph... with an auto.. it's probably a bad guage or wired backward somehow.
__________________
2004 Jaguar S type R. 4.2L V8 w/ Stiegemeier Snakebite Eaton M112 w/Alky Injection. H&R springs...
92 383, CNC'd LT4 top end, auto, custom vortech YSI trim, progressive alky kit, brembo 13.5's, magnesium speedline 18"'s with 275/335s, 7.30's@97 in the 1/8 (old combo)... The build up of an Low 10 second daily driver.
89 Saleen Clone with a 335" T trim'd blower motor. DFI, CNC'd victor jr's, vic 5.0. Was shooting for high 9's and 740 rwhp. Gone, but definately not forgotten...
qwiketz is offline   Reply With Quote
Old 11-01-2005, 02:45 PM   #17
rkubara
CF Member
rkubara's Avatar
OK, I'm convinced I have a bad gauge. I haven't found the exact one yet to simply replace it (matches the fuel pressure gauge) and if I buy a different one to check and compare I can't return it (no returns). I am out of town on a road trip for 2 weeks, but will post my findings once I check it with another gauge.
Thanks for everyones input.
Old 11-01-2005, 03:00 PM   #18
neat
CF Senior Member
Send a message via AIM to neat Send a message via MSN to neat
A generic vacuum gauge should be available at your local autoparts store for less than $20. It won't fit in the hole obviously, but you could tape it to the windshield for a quick run around the block.
__________________
1991 Coupe - 6 Speed - Black on black - 11.37 @ 122.88 -
neat is offline   Reply With Quote
Old 11-03-2005, 05:04 PM   #19
drochau
CF Senior Member
drochau's Avatar
Uh, wiring? I don't know about you guys, but I have a analog gauge for boost. I just have a small tube going to the cockpit gauge. It's always been spot on too with my vacuum tool.
This is the first time I've heard of a boost gauge going south itself. Is the tube crimped or kinked at some point?
drochau is offline   Reply With Quote
Old 11-26-2005, 08:53 PM   #20
rkubara
CF Member
rkubara's Avatar
You all were right, bad gauge. It has about 6-7 lbs of boost with a new gauge. I was worried that it was too much for the high miles engine with the high boost the old gauge was showing. For only 6-7 lbs, sure hard to keep these tires from spinning.
Reload this Page lowering the boost for a Vorthech
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
