Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-26-2005, 10:20 AM   #1
rkubara
CF Member
rkubara's Avatar
Default Vortech Supercharged 1994 C4 tuning help
Anyone with a Vortech Supercharger on a C4 than can offer tuning advise? Mine is runing rich and I am not certain how I can lean up the mixture.
Anyone know of a supercharger forum?
rkubara is offline   Reply With Quote
Old 10-26-2005, 11:19 AM   #2
AGENT 86
CF Senior Member
AGENT 86's Avatar
Quote:
Originally Posted by rkubara
.Anyone know of a supercharger forum?
http://forums.corvetteforum.com/forumdisplay.php?f=87
AGENT 86 is offline   Reply With Quote
Old 10-27-2005, 03:36 AM   #3
Mo_Bandy
CF Senior Member
Mo_Bandy's Avatar
Are you running an FMU ? what size injectors? how much boost are you running? How rich is too rich? What is your O2's reading ...
Give us as much info as you can there are many here that will try to help you...
Regards, and welcome...
Mo
__________________
96 Black Coupe, Electric, Netgain 11HV electric motor 300v 2000A Zilla controller, 300v 2400a XS Power Batteries, ZF6 6 speed, QA1 Coil Overs,www.ndneyes.com/or for non electric www.ndneyes.com/mo
Mo_Bandy is offline   Reply With Quote
Old 10-28-2005, 02:21 AM   #4
rkubara
CF Member
rkubara's Avatar
I just bought the car last week, not on the road yet. Never owned a Vette or supercharger. I am mechanically strong, but weak in these two areas.
Yes it has an FMU. Do not know anything about the injectors. It is running 40 lbs of fuel pressure at an idle, 50 at 2500 RPM. Do not know the O2 readings.
The car smells up the garage as soon as it is started. The bumper goes black above the resonators in very little time. My gut feeling, very rich when cold, but as I have not had it on the road yet, I am not certain of anything except a strong gut feeling.
I would like to know the ohm values for the O2 sensors and I will tests them?
Once on the road, I plan to take it to a muffler shop and have the cats tested, I think they are toast, the car has 96,000 and they look original. Thinking of putting on universal Magnalows, anyone have input on them?
Old 10-28-2005, 11:05 PM   #5
Mo_Bandy
CF Senior Member
Mo_Bandy's Avatar
rkubara,
One of the best investments you can make would be some logging software...
With it you can monitor your O2's at WOT as well as around town... At WOT they should be in the 890-900 mv if you aren't running an intercooler... Also it will give you an indicaton of how much advance you are running and whether you are seeing any spark knock as well.
For the 94 Tunercat is probably the most popular.... Also PLX has a wide Band O2 that would be helpful getting you Air Fuel mixture correct.
Hopefully this helps some...
Mo
__________________
Old 10-29-2005, 04:05 AM   #6
qwiketz
CF Senior Member
qwiketz's Avatar
Also since you are using a fmu, you can change the step up ratio disc or buy the bleed off valve from vortech. Those will help you adjust you rate of gain under boost.
Datalogging software is a must. I've come a long way since I got some. I previously had a coolant temp sensor that was bad that gave me a rich condition. It was easily diagnosed once I hooked up the laptop.
For tuning I use tts datamaster. It's pretty easy to use. Heck, I started knowing nothing about this stuff and now I at least know the basics.
__________________
2004 Jaguar S type R. 4.2L V8 w/ Stiegemeier Snakebite Eaton M112 w/Alky Injection. H&R springs...
92 383, CNC'd LT4 top end, auto, custom vortech YSI trim, progressive alky kit, brembo 13.5's, magnesium speedline 18"'s with 275/335s, 7.30's@97 in the 1/8 (old combo)... The build up of an Low 10 second daily driver.
89 Saleen Clone with a 335" T trim'd blower motor. DFI, CNC'd victor jr's, vic 5.0. Was shooting for high 9's and 740 rwhp. Gone, but definately not forgotten...
qwiketz is offline   Reply With Quote
Reload this Page Vortech Supercharged 1994 C4 tuning help
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
