Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-26-2005, 01:52 AM   #1
drochau
CF Senior Member
drochau's Avatar
Default NOS + Procharger Opinions
Allright, I just picked up a nice little NX kit for the vette. Here are the specs:
-Forged Block running 9.2:1 compression
-P-1 Procharger Head Unit w/ FM Intercooler running 11 ish lbs. of boost
Seeing 515 on the dyno (YAY cold weather)
I want to work my way up to an end shot of 200 on the nitrous. This is a street application for the vette, and I don't plan on launching with nitrous. I have a FAST ECU to control the nitrous tune.
What are your opinions for the nitrous setup? I'd like to avoid going to direct port, but so far this seems the safest route. If I go single nozzle wet shot, where should I place it? I'm thinking about 12-16 inches pre-intake manifold. Thoughts?
drochau is offline   Reply With Quote
Old 10-27-2005, 12:23 AM   #2
bmergner94vette
CF Member
single fogger nozzle would be fine.... i would place the nozzle anyplace before the throttle body but after the head unit. if you have the intercooler you need to be after that as well.
bmergner94vette is offline   Reply With Quote
Old 10-27-2005, 02:30 PM   #3
MrNuke
CF Senior Member
MrNuke's Avatar
You are treading on dangerous ground.. 11psi + 9.2:1 and nitrous on top of it, very close to bad news..
I'd use the nitrous on the intercooler or aftercooler if you have one, to lower the imtake charge and get maybe another 40-50hp, but not nitrous directly in the engine..
MrNuke is offline   Reply With Quote
Old 10-27-2005, 09:17 PM   #4
drochau
CF Senior Member
drochau's Avatar
What makes you think this is dangerous ground? Because of the stress on the crank? Just wondering what you think would be the main issue...
Old 10-27-2005, 11:52 PM   #5
MrNuke
CF Senior Member
MrNuke's Avatar
Pistons or Rods, Valves, backfire, intake.. Where do I start..
Usually Supercharging/Turbo or Nitrous, not both, unless it is a race engine that gets torn down after every few runs. Too much stress on the parts.. Being forged helps, but still...
Old 10-28-2005, 12:46 AM   #6
XtremeTuning
CF Senior Member
I have a 9.1:1 CR 396 running an ATI D-1 Procharger and a 200 shot of NOS (TNT System) run by a FAST management system. Ran on the dyno with just 5lbs-6lbs of boost and no NOS, but ran too to lean to continue (larger fuel pump on the way). Made 535rwhp in this condition. More numbers to come in the next week or so....
-JRW
XtremeTuning is offline   Reply With Quote
Old 10-28-2005, 12:47 AM   #7
drochau
CF Senior Member
drochau's Avatar
That's what I'm talking about Xtreme
Old 10-28-2005, 12:20 PM   #8
lead foot 85 vet
CF Senior Member
I did it and got away withit for about a year and 1 1/2 bottles of nos.....simular engine as you guys.....10 lbs boost...100 hp wet shot...I was just hitting the botton in 4th gear and enjoying the rush...then one day with my son in the car I decided to run it through the gears with the nos on.....half way thrugh third gear BOOM ....blew the top of the suuperram through the hood then eat a bolt (they don't stop running)........after it was al over about $7000.00 damage.....most think it detenated......I think it lifted the heads and one cylinder lite the oth er(I havecast iron. you have aluminum_less srenght)........but I'll never know.......pump gas has it's limitations...are manifolds are made for a dry charge.....your going to have lean cylinders with your intake system.....BOOM....10lbs boost and 200 hp wet shot.....BOOM....ruined my whole summer,
lead foot 85 vet is offline   Reply With Quote
Old 10-28-2005, 01:25 PM   #9
86VX1
CF Senior Member
86VX1's Avatar
Default lead foot 85 vet
You are an awsome dude, man that must have been a sight. how old was your son when this happened? My son is slowly getting into going fast. How did your boy react to this?
86VX1 is offline   Reply With Quote
Old 10-28-2005, 01:30 PM   #10
86VX1
CF Senior Member
86VX1's Avatar
drochau
run 100 ocatane or more to be on the safe side, the first time to stab it.
I can't wait to be where you guys are at. forged motor, then supercharger, then nitrous.
Old 10-28-2005, 03:04 PM   #11
zelement
CF Senior Member
Send a message via AIM to zelement
I got both but i have not touched my nitrous since the SC. i run a pretty safe system: NX Gemini twin with NX maximizer and DFI to control fuel and timing.
I will not touch my nitrous until everything is perfect. I have waaaayyy too much invested in my setup to just blow it up for a few seconds of thrills.
zelement is offline   Reply With Quote
Old 10-28-2005, 06:47 PM   #12
dr.juice
CF Senior Member
dr.juice's Avatar
Well...
I have a 377cid w/D1-SC plus a NX twin fogger wet system. Engine all forged, stock block, ARP all around, aluminum heads, lt-4 intake etc etc. Almost three running and NO PROBLEMO. With belt slip +/- 5 psi of boost and 250 shot, 641 rwhp and +/- 789 lbs of torque.
Ran it on 1/4 mile(leaving the line with the nitrous on) with alot of wheel spin: 10.66 @ 135mph.
Just make sure you're not running lean and watch your timing and everything will be ok.
dr.juice is offline   Reply With Quote
Old 10-28-2005, 06:47 PM   #13
dr.juice
CF Senior Member
dr.juice's Avatar
Well...
I have a 377cid w/D1-SC plus a NX twin fogger wet system. Engine all forged, stock block, ARP all around, aluminum heads, lt-4 intake etc etc. Almost three years running and NO PROBLEMO. With belt slip +/- 5 psi of boost and 250 shot, 641 rwhp and +/- 789 lbs of torque.
Old 10-30-2005, 11:55 AM   #14
AKS Racing
CF Senior Member
AKS Racing's Avatar
Quote:
Originally Posted by dr.juice
Well...
Dr. Juice,
Didn't you buy Bruce's SC system at the start of 2005? Or were you SCed before that event that allowed you to have 3 yrs with no problems?
AKS Racing is offline   Reply With Quote
Old 10-31-2005, 01:02 PM   #15
dr.juice
CF Senior Member
dr.juice's Avatar
Quote:
Originally Posted by AKS Racing
Dr. Juice,
No...i just bought the cog system. The car was already sc.
With the cog i made it to 20 psi of boost @5500rpm(if i'm not mistaken) and around 610rwhp without n2o.
Old 10-31-2005, 05:32 PM   #16
drochau
CF Senior Member
drochau's Avatar
Thanks for the opinions guys
Ran the N20 and fuel lines yesterday. Up for tomorrow is baseline dyno tune, messing with FAST (dry control first until I get low on injector) then prob sat. for the wet if I get confident that the rear end will hold (N20 is for rolling start only)
Reload this Page NOS + Procharger Opinions
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Supercharging vs. Nitrous cheemsaf C5 Forced Induction/Nitrous 27 02-11-2003 10:23 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
