Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-25-2005, 02:35 AM   #1
lcvette
CF Senior Member
lcvette's Avatar
Send a message via AIM to lcvette
Default turbo update pics 10-25-05 :)
well, won't type much, but worked this weekend on assembling the rest of the motor, I like to take my time and make sure everyhting is cleaned and put together properly. anyways, I have decided to run the mockup plumbing for a few weeks once she is ready before building the Stainless set incase anything needs to be changed. but had to bolt up the turbo stuff and have been sitting in the garage grinnin like a school boy making swooooosh sounds imagining what she's gonna sound like when spooling.. Gotta love boys with big toys..lol enjoy the pics!
thanks for looking in!
Chris
lcvette is offline   Reply With Quote
Old 10-25-2005, 02:59 AM   #2
Zix
CF Senior Member
Zix's Avatar
Wow! That is exceptionally clean! Is that a GEN 1 block with an LT intake? Or is that an LT motor converted to use a standard distributer?
Zix is offline   Reply With Quote
Old 10-25-2005, 07:57 AM   #3
Rkreigh
CF Senior Member
nice work. really like how you angled the turbo to help with the plumbing.
details plz!! I have a 94 LT1 Auto begging for this conversion.
thanks for the pics.
Rkreigh is offline   Reply With Quote
Old 10-25-2005, 10:49 AM   #4
neat
CF Senior Member
Send a message via AIM to neat Send a message via MSN to neat
Damn, man. I was in Raleigh last weekend for the Fair, I should of gotten in touch with you.
I just noticed your location says Wilmington, but it seems like you told me you were in Raleigh.
I'm up in Raleigh quite a bit, so if you in that area I'll have to get ahold of you.
__________________
1991 Coupe - 6 Speed - Black on black - 11.37 @ 122.88 -
neat is offline   Reply With Quote
Old 10-25-2005, 09:38 PM   #5
StealDads67
CF Senior Member
StealDads67's Avatar
Send a message via AIM to StealDads67
If your remaking it in stainless.... I would say you should move the wastegate to the other side of the motor just before the turbo. Your gonna get reversion in the exhaust. It will help to control boost better also. You dont want to find out that you cant keep the boost down when its already installed and finished. Plus if you move it to the otherside, you can vent the wastegate into the exhaust so you can hear the turbo even more
...But other then that. Awsome work!!!
StealDads67 is offline   Reply With Quote
Old 10-26-2005, 03:05 AM   #6
Trizney
CF Senior Member
Trizney's Avatar
Send a message via AIM to Trizney Send a message via MSN to Trizney
With the turbo at that angle, is it going to push the plumbing into the radiator? Is this going to be intercooled?
Trizney is offline   Reply With Quote
Old 10-26-2005, 08:24 PM   #7
lcvette
CF Senior Member
lcvette's Avatar
Hey guys,
thanks for the replies,
as for the engine it is an LTx block fitted for the distributor, I am running the same setup MN_VETTE has, DFI Gen 7 with the dual sync in the rear.
regarding the wastegate, there is simply no room to mount it closer to the turbo, I have seen several setups running it like this with no Ill effect, the wastegate is 50mm, that should be plenty large enough to bleed pressure pre-turbine and maintain any boost level I want which will never be less then 10 pounds of the factory set spring.
the wastegate does plumb back into the exhaust system the same way the stock pipes meet under the car closer to the tail section of the tranny, I did not want it venting to atmosphere just so I could enjoy the sound of the turbo without the raspy open pipe sound of the wastegate interfering and making the car overly loud in an unpleasant way.. after all that is the entire reason I went turbo.. tired of a lopey cammed setup that was mainly to be used at the track.. this way I get stock idle/driveability around town and can unleash some violent power when I get heavy on the right pedal. so once she is fired up and tuned we will see if anything needs to be changed, but I am confident for now it will be all I hoped and possibly more. thanks again for looking in guys!
chris
Old 10-26-2005, 08:26 PM   #8
TONYDEE64
CF Senior Member
TONYDEE64's Avatar
It looks good to me Chris!
TONYDEE64 is offline   Reply With Quote
Old 10-26-2005, 09:45 PM   #9
ANTI VENOM
CF Senior Member
ANTI VENOM's Avatar
Sweeeeeet dude. I'm jealous. I didn't know that you were going with a conventional distributor. I am also doing a distributor in a LT1, but only because I am using the 7749 ecm and my car is a 91 to begin with. Loved the pics. Can't wait till you take her out for a spin. I haven't touched mine in months. I will live through you for now!!!
__________________
91 (383 LT1 turbo, under construction)
92 (Heads, Cam, Exhaust)
ANTI VENOM is offline   Reply With Quote
Old 10-27-2005, 08:54 AM   #10
HJV11
CF Senior Member
HJV11's Avatar
Send a message via AIM to HJV11
Looks great Chris! I cannot wait to see your results.
I am sure it has been talked about prior but what cam are you running?
HJV11 is offline   Reply With Quote
Old 10-27-2005, 09:06 AM   #11
lcvette
CF Senior Member
lcvette's Avatar
here is most of the rest of the combo..
as for the rest of the mods...
ENGINE
-355 forged bottom 8.7 : 1 CR shortblock
-Trickflow heads (unported) gonna wait before I go that route
-Stock LT4 camshaft - also gonna wait on this
-crane gold rockers/.083 extreme pushrods/ comp R lifters
-dual roller billet timing set
-K-motion double springs and Ti retainers, 10* locks
-ported LT1 intake manifold
-58mm throttle body
-Meziere electric waterpump
FUEL SYSTEM
-Twin intank walbro 255lph pumps
-(-10 AN) fuel line to barry grant filter to aeromotive regulator
-custom fabbed fuel rails
-83 lb/hr low Z injectors
-(-8 AN) return line
-racetronix wiring harness kits for both pumps wired independantly
ENGINE MANAGEMENT
-Accel DFI Gen 7 w/ dual synch distributor (opti delete)
-Accel DFI wide band O2
-Accel DFI knock module
-Fast track performance harness to retain ALL dash functionality
TURBO SYSTEM
-T 74 GTS turbocharger
-50mm Wastegate
-50mm Blow Off Valve
-Greddy Profec Spec 2 boost controller
-12" x 27" x 4" thick FMIC
-all 3" cold side aluminum plumbing
-custom self fabbed hot side parts (whats in the pics is mild from drivers side V-band on, but the final will be made of Stainless Steel once this system proves itself in design)
IGNITION
-MSD 6A
-MSD 8.5 super conductor wires
-MSD Blaster Coil
-NGK TR6 plugs
Old 10-27-2005, 03:10 PM   #12
LT4POWR
CF Senior Member
LT4POWR's Avatar
Quote:
Originally Posted by lcvette
Changing that #6 spark plug looks like it's gonna suck. Looks great though
__________________
1996 LT4 Corvette
416rwhp/375rwtq (SAE) - NA Stock Bottom End
2004 Cadillac CTS-V
Stock (for now) LS6
LT4POWR is offline   Reply With Quote
Old 10-27-2005, 06:16 PM   #13
redbullapril23
CF Senior Member
redbullapril23's Avatar
Send a message via AIM to redbullapril23
CHRIS THAT LOOKS AWESOME!!!!!
really that thing is a beauty!
whats youre wastegate set at?
I know what I am asking for.. for X mas... a forged bottom end.. well LC bottom end.
ive been looking at the Banks Turbo kits.. and i think I might go with their manifolds, wastegates(prob set for a max of 9 psi at first) and oil returns and use garret turbos.. just because they give their compressor maps.
the only thing im still having trouble with is the planning the ignition and FM.
1.where did you get the opti delete?
2. do you think the dynaspark would work ok?
3. is it possible to change my Map sensor to a 2 bar and run the stock LTX edit to change the fuel/spark maps?
i only plan on getting about 600rwhp.. not the 800 plus like you do hehehe!!! and i always have my N20. but until i can change or beef up my tranny ill just buy the parts. and do the 355 LC install.
thanks alot Chris
your friend
Sean
redbullapril23 is offline   Reply With Quote
Old 10-28-2005, 01:07 AM   #14
lcvette
CF Senior Member
lcvette's Avatar
LT4POWER,
the downpipe comes of in about 5 minutes and with it out all the plugs are very easy to access, actually easier then with the stock manifold or Long tubes. downpipe is only held on by 2 V-Band clamps that are very accessible...
chris
Old 10-28-2005, 06:58 PM   #15
SupaVette
CF Senior Member
SupaVette's Avatar
Send a message via AIM to SupaVette
WOW, looks really great. 1 question though, how do you fit the waterpipe onto the water neck above the stat? or does it just look so close in the pics. Bet you can't wait to get in and drive!
SupaVette is offline   Reply With Quote
Old 10-29-2005, 01:51 PM   #16
ncChris
CF Senior Member
Real Nice lcvette... just showed pics to Jeff.
ncChris is offline   Reply With Quote
Old 11-03-2005, 04:06 AM   #17
JoBy
CF Senior Member
JoBy's Avatar
That is the same turbo location that I am going to use on mine.
I am looking at different options to route the headers now.
It looks like you have to install the engine with the passenger side header mounted. What diameter piping did you use?
JoBy is offline   Reply With Quote
Old 11-03-2005, 11:05 AM   #18
lcvette
CF Senior Member
lcvette's Avatar
Joby,
nope.. with the front of the car raised to loosen the V-band flanges for the crossover pipe, the passenger side header will come off on about 5 minutes, while mocking up the car, I made sure that everything could come off easy for maintenance. I can put the entire system on or off the engine while in the bay in about 20 minutes.
chris
Old 11-03-2005, 01:24 PM   #19
JoBy
CF Senior Member
JoBy's Avatar
Ok, thanks!
I am going to try and put a flange on the passanger side header too. Then I can leave both headers on, remove the turbo, and connect a N/A exhaust. That would make it easy when I have to do the yearly emissions test.
Old 11-09-2005, 09:49 PM   #20
ghall
CF Senior Member
--nice bud
ghall is offline   Reply With Quote
Reload this Page turbo update pics 10-25-05 :)
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
