Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-24-2005, 08:13 PM   #1
cjg454ss
CF Senior Member
cjg454ss's Avatar
Send a message via AIM to cjg454ss
Default upping boost
i have a 94 vette, catback and vortech, im running 6 lbs, what pulley would i need to go to 8 lbs. also how much more of a strain would it be. i run alky injection 50./50. also how much hp will it add u think add.
cjg454ss is offline   Reply With Quote
Old 10-25-2005, 03:58 AM   #2
Mo_Bandy
CF Senior Member
Mo_Bandy's Avatar
If you talk to Greg at Blowerworks greg@blowerworks.net he can modify your Vortech intake which will help.... I was running a 3.125 with a 7 inch crank pulley with a 7 rib belt and was "bumping 10 pounds...
I installed his 8 rib with better tensioning and was hitting 12 at 5500... with a ATI balancer that was 7.5 inches...
Hope this helps
MO
__________________
96 Black Coupe, Electric, Netgain 11HV electric motor 300v 2000A Zilla controller, 300v 2400a XS Power Batteries, ZF6 6 speed, QA1 Coil Overs,www.ndneyes.com/or for non electric www.ndneyes.com/mo
Mo_Bandy is offline   Reply With Quote
Old 10-25-2005, 01:31 PM   #3
cjg454ss
CF Senior Member
cjg454ss's Avatar
Hope this helps
MO
yeah i know about the intake, i might just redo the whole intake. it seems very restrictive. or i just may have the baffle welded in. whats the stock pulley sizes?
Old 10-25-2005, 01:38 PM   #4
Mo_Bandy
CF Senior Member
Mo_Bandy's Avatar
The stock pulley sizes are 7 inches on the crank and 3.125 on the S/C, which are supposed to give from 6-8 pounds. Generally it depends on how much belt slip you get... If you are running 6 ribs then it may be more difficult to get too much more.. I was running an older 7 rib setup... which did help some, but I still sufered belt slip on the top end.
Mo
__________________
Reload this Page upping boost
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
DYNO TIME from Kenne Bell Twin Screw c5_from_jc C5 Forced Induction/Nitrous 251 09-25-2005 03:23 PM
Ptk Project NICK YOSKIN C5 Forced Induction/Nitrous 275 07-26-2005 10:27 AM
Got a Magnuson on order, but I know I'll want more power. Thinking about heads\cam... Mr. Pepsi C5 Forced Induction/Nitrous 26 03-14-2003 06:51 PM
New power package for '02 Porsche 911 Turbo Dean McManis C5 Z06 Discussion 24 01-01-2002 03:42 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
