Does anyone have both installed? My car is in TX and I am in NJ, but supposedly both have been installed with no problems. Can anyone confirm that they don't interfere with each other?
I need a pic of the R&D Camber Brace, then I could probably tell you if it is possible. I have installed all of the different blowers (even some that the manufacturers say will not fit) in the C4 chassis, and based on the routing of the camber brace should be able to make a judgement call.
Aaron
I actually purchased the camber brace from Exotic Muscle along with a bunch of other suspension components.
I would imagine that most of the braces fit the same way... so it is possible without major modifications?!?!
Well, I tried rotating both pics to the same angle & side by side it is still VERY hard to tell if the air tubes will clear the camber brace. Looks like the return might but the pressure line going down off the charger is huge!!
Please, if anyone else has this unit, post a pic that shows that area.
