Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-17-2005, 02:30 PM   #1
Guitarguy
CF Senior Member
Guitarguy's Avatar
Default a few ?'s for you guy's
i bought a used vortech supercharger on here a few years ago. the guy said this kit came with injectors but he never needed them because his car was a 94 or newer. now my car is a 92, the kit has everything including the ( fmu ), but the injectors that he spoke of are not . do i need to up my injector size? also i have to pull the gas tank and i want to know if there is a pump i can put in there so i don't need the booster pump? now this kit was the 1 that says 125 horsepower increace and it has the origanal pullys, and i dont plan on changing them anytime soon, do i need to beef up the lower end? i don't plan on taking it to the track, just as a daily driver with a little boost. i know that engine timing is key to keeping it all together the kit does have a crane ign with the remote timing retard control. but i like the moates ostrich. and i like the idea of less wiring and more control of things. does anyone have a bin that could get me started? thank so much and keep up the great work. this site RULES!!
Guitarguy is offline   Reply With Quote
Old 10-17-2005, 02:47 PM   #2
gsdave
CF Senior Member
gsdave's Avatar
I'm not sure what injectors your 92 came with, but I just had to post because I noticed you are from Marianna, FL where I grew up! My family still lives there and I visit regularly. Nice to see some 'local' people on the forum.
__________________
'96 Grand Sport 016
'95 Corvette undergoing 383 transplant
'03 F150 SuperCrew 4wd
'70 LeMans Sport
gsdave is offline   Reply With Quote
Old 10-17-2005, 03:33 PM   #3
mn_vette
CF Senior Member
mn_vette's Avatar
The '92-'93 had 22# injectors and the '94 and on had 24# injectors. If you are using the FMU that came with the setup you shouldn't need to do anything with the injectors. However, calling Vortech would answer all of your questions.
Why are you pulling your fuel tank?? You can change the pump without pulling the tank, took me less than an hour the first time I did it, I could do it now in under 30 minutes. Get a Walbro 255LPH pump. Get the high pressure version. You can pick these up for about $100. Then you don't have to use the booster pump.
The timing is a big thing. Vortech has an ignition that retards timing depending on how much boost you have. I think this is the way to go with a stock setup. I'm not sure what the ostrich thing is but if it does the same thing it should be ok, if it just retards a set amount of timing you'll be better off with the other box. You can pick the vortech ones up for under $100 off of ebay.
If you keep it at 6 psi and retard the timing you can get away with the stock bottom end. But keeping a couple of grand in the bank "just in case" wouldn't be a bad idea.
What are you going to do with the bin file? If you are using the FMU then you don't need to mess with the computer at all. If you want to do it all computer controlled then you need to get some bigger injectors as well, I'd say ship it out to the pro's for something like that, or if you'd like to do it yourself, pick up a portable wideband setup like an Innovative. then you can get it tuned right. Having the wideband might not hurt to make sure the FMU is setup correctly too if you go that route.
Just some words of advice from a guy that hangs out here a lot.
mn_vette is offline   Reply With Quote
Old 10-18-2005, 01:48 AM   #4
qwiketz
CF Senior Member
qwiketz's Avatar
tts datamaster is a nice tool to monitor knock. Knock will kill your stock bottom end. It will also let you peak at the 02 readings.
qwiketz is offline   Reply With Quote
Reload this Page a few ?'s for you guy's
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
BFGoodrich g-Force T/A KD'S for sale! HotRodC5 C5 Parts for Sale/Wanted 11 04-25-2004 09:13 PM
C6 Z06 info that'll make you mad, but a few other goodies too lampedusa C6 Corvette General Discussion 52 11-27-2003 04:29 AM
Sorry Guy's..WE Have to WAIT Z06GMAN C5 Forced Induction/Nitrous 127 10-28-2002 07:38 PM
A few BPU++ Supra kills (videos) johnso26 C5 Tech 100 02-08-2002 09:12 PM
You guy's think I can beat this guy in the 1/8th? Budman68 C3 Tech/Performance 19 01-14-2002 01:31 AM
I'd like to clear up a few things regarding the HMS situation JWSchmidt3 C5 Tech 52 10-29-2001 03:45 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
