Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-17-2005, 02:04 AM   #1
qwiketz
CF Senior Member
qwiketz's Avatar
Default How come my power curve doesn't keep climbing?
Do your vortech power curves(hp) keep climbing toward redline? Mine looks like the power curve of a n/a car on datamaster.
My 02's drop down slightly from being slightly rich to almost slightly on the lean side for a f/i combo, and the power level still doesn't climb. I'm seeing a pretty consistent level of boost toward the top end, about 7-8.5 psi. My hp peak on datamaster is at about 4700 rpm.
I have a super free flowing exhaust, lt4 intake and cnc'd heads. Do I need to do a cam swap at some point? I have a circa 1998 cam in there. I think it's a "hot cam". It was installed in the car at the same time the heads and intake were done.
When I'm running the car through the gears it sounds fine. It just doesn't pull at the redline like I'm used to with a vortech on there. How do your curves turn out when you use that program with you're blown setup? Or am I reading this thing wrong or have the wrong filter setup?
__________________
2004 Jaguar S type R. 4.2L V8 w/ Stiegemeier Snakebite Eaton M112 w/Alky Injection. H&R springs...
92 383, CNC'd LT4 top end, auto, custom vortech YSI trim, progressive alky kit, brembo 13.5's, magnesium speedline 18"'s with 275/335s, 7.30's@97 in the 1/8 (old combo)... The build up of an Low 10 second daily driver.
89 Saleen Clone with a 335" T trim'd blower motor. DFI, CNC'd victor jr's, vic 5.0. Was shooting for high 9's and 740 rwhp. Gone, but definately not forgotten...
qwiketz is offline   Reply With Quote
Old 10-17-2005, 03:00 AM   #2
drochau
CF Senior Member
drochau's Avatar
Yikes! That looks to be all wrong for your blower.
Starting from the motor my observation would be:
-Cam:You mentiond it's a 1998 hot cam? Are you sure it's appropriate for a F/I setup?
-Heads:CNC'd so I would "assume" you are getting adequate flow
-Retard: Any KR involved at that rpm?
From there, you mentioned a free-flowing exhaust and you have an LT motor correct? So that would mean you have the factory "headers" which should provide enough flow for this to work properly.
I know this sounds "duh" but are you getting consistent boost throughout the pull? Check for belt slip.
drochau is offline   Reply With Quote
Old 10-17-2005, 08:56 AM   #3
SupaVette
CF Senior Member
SupaVette's Avatar
Send a message via AIM to SupaVette
Mine keeps pulling right up to the 5500 red line. Is your belt maybe slipping at high rpm's?
SupaVette is offline   Reply With Quote
Old 10-18-2005, 12:52 AM   #4
qwiketz
CF Senior Member
qwiketz's Avatar
I don't know what the cam is, but it pulls just slightly less vacuum then the stock cam pulls. It pulls about 16-18" As for the exhaust question, it has hooker long tubes, custom 3" dual cat h pipe, 3" b&b exhaust. No, there was no knock above 4500 rpm.
Slip, I'm sure I'm getting some because boost doesn't continue to climb nearly as agressively. It levels out at about 8 psi.
What I'm getting at, is with boost being fairly level, wouldn't the motor be injesting increasing amounts of air with increasing rpm causing the hp to still climb?
or
Is it just how I have the datamaster program filter for the dyno section setup. I'm running filter "2".
As for the cam, if I were to swap it out I'm 100% sure I'd see big gains. i know with my mustang, my cam now is light years ahead of the one I bought in 1999 and it's the same with these cars. Also, the hp peak is pretty low. I'd imagine that it would be more toward the 5500 shift point.
__________________
Old 10-22-2005, 11:15 AM   #5
Brand-X
CF Senior Member
Belt slip??
Brand-X is offline   Reply With Quote
Old 10-23-2005, 02:11 AM   #6
Mo_Bandy
CF Senior Member
Mo_Bandy's Avatar
I'd say belt slip or cam... you cam is a touch on the radical side... it should be almost a stock profile with maybe higher lift...
Mine would keep pulling up to the redline as well...
Mo
__________________
96 Black Coupe, Electric, Netgain 11HV electric motor 300v 2000A Zilla controller, 300v 2400a XS Power Batteries, ZF6 6 speed, QA1 Coil Overs,www.ndneyes.com/or for non electric www.ndneyes.com/mo
Mo_Bandy is offline   Reply With Quote
Reload this Page How come my power curve doesn't keep climbing?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Horsepower vs. Torque 03LingenfelterC5 C5 Tech 11 03-03-2005 09:31 PM
I used to know... but I'll ask again, HP vs TQ ruby76 C3 Tech/Performance 31 01-30-2005 12:35 PM
LS2/LS7 Engines not very efficient? djhartm C6 Corvette General Discussion 37 01-29-2005 01:37 PM
RWHP vs RWT Fastbasser Performance Results 33 12-23-2004 04:49 PM
HP vs Torque curtowens C5 Tech 10 12-27-2001 08:48 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
