Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Forced Induction/Nitrous
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C4 Forced Induction/Nitrous C4 Corvette Turbochargers, Superchargers, Centrifugal, Twin Screw & Roots Blowers, Pulley Upgrades, Twin Turbo Kits, Intercoolers, Wet & Dry Nitrous Injection
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-17-2005, 01:54 AM   #1
qwiketz
CF Senior Member
qwiketz's Avatar
Default Alky injection AFR's and o2 readings
what do you tuners shoot for when running a setup such as mine with 8-9 lbs of boost? What air to fuel ratio and what 02 readings?
Does it just come down to knock? In other words, as long as there's not knock, then lean it out?
Just curious. I ran my car with the o2's a little low after some changes so I think that I need to richen it up for a little more safety net. It ran a little richer in the mid rpms and a little lean up top, but up top it ran cleaner than the middle rpms. Knock was almost zero up top.
__________________
2004 Jaguar S type R. 4.2L V8 w/ Stiegemeier Snakebite Eaton M112 w/Alky Injection. H&R springs...
92 383, CNC'd LT4 top end, auto, custom vortech YSI trim, progressive alky kit, brembo 13.5's, magnesium speedline 18"'s with 275/335s, 7.30's@97 in the 1/8 (old combo)... The build up of an Low 10 second daily driver.
89 Saleen Clone with a 335" T trim'd blower motor. DFI, CNC'd victor jr's, vic 5.0. Was shooting for high 9's and 740 rwhp. Gone, but definately not forgotten...
qwiketz is offline   Reply With Quote
Old 10-23-2005, 02:21 AM   #2
Mo_Bandy
CF Senior Member
Mo_Bandy's Avatar
My understanding is that if you use alky or methanol it will cause the readings to look a little different .... I was running around 880's to 890's if you are too lean the power will flatten out which kind of leads me to believe that is where you are at now...
What are your injector times at WOT ?
You may need to just see where the engine seems to pull the best... and of course look for knock...
Mo
__________________
96 Black Coupe, Electric, Netgain 11HV electric motor 300v 2000A Zilla controller, 300v 2400a XS Power Batteries, ZF6 6 speed, QA1 Coil Overs,www.ndneyes.com/or for non electric www.ndneyes.com/mo
Mo_Bandy is offline   Reply With Quote
Reload this Page Alky injection AFR's and o2 readings
Tags
afr, alky, injection
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
