Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-24-2005, 12:56 PM   #1
JMoney454
CF Member
JMoney454's Avatar
Default Mighty Demon Vs. Holley 4150, Opinions Wanted
I'm replacing the carb in my 71, and I was considering getting a Mighty Demon instead of the tried and true Holley 4150. Has anyone had any experience with them? Any opinions on which would be better?
JMoney454 is offline   Reply With Quote
Old 01-24-2005, 01:17 PM   #2
lars
CF Senior Member
lars's Avatar
Location: At my Bar drinking and wrenching in Lafayette Colorado
There is quite a range of Holley 4150 series carbs. The HP series 4150s have pretty much the same features as the Demon, and the two carbs will perform virtually identically. They both have 4-corner idle systems and replaceable bleeds. If you compare the Demon to the entry-level 4150, the Demon will have more tunable features, but that's comparing apples to oranges.
lars is offline   Reply With Quote
Old 01-24-2005, 01:23 PM   #3
Witz
CF Senior Member
Witz's Avatar
I have used both on my 430hp 355 in a 69' convertible - in both 650 and 750 sizes. My favorite so far has been the 650 Mighty Demon. Far superior idle quality and amazing high rpm performance. More expensivie, but much higher quality parts. I have spent less time messing with the Mightly Demon then the 4150. I used the Holley for years and had to rebuild it every year. I have been using the Mighty Demon for two years with no rebuilds (knock on wood).
Witz is offline   Reply With Quote
Old 01-24-2005, 02:22 PM   #4
JMoney454
CF Member
JMoney454's Avatar
I have a couple more questions I forgot to ask when I originally posted this. I've heard that Demon carbs flow better than the same rated Holley because Demon carbs are wet tested, and Holley carbs are dry tested. Is this true? What's the difference between wet and dry flow testing? What would a 750 cfm Demon carb rate if it were measured on the Holley scale?
Also, what does tuning an emulsion circuit do? I was reading that one of the main differences between the Mighty Demon and the Race Demon was that the Race Demon had adjustable emulsion circuits.
Old 01-24-2005, 03:05 PM   #5
SmokedTires
CF Senior Member
Cruise-In III Veteran
St. Jude Donor '05
SmokedTires's Avatar
Your correct on the differences in rating methods between BG and Holley. Basically, BG copied and improved upon the 4150 Holleys, then the originator Holley copied BG to come out with their pricey HP series. After doing some research between the 2, I'll be getting a Mighty Demon for my engine
Not sure about the emulsion circuits
__________________
Mike
Modified 1974 Corvette
388 big bore/ short stroke Dart SBC, TT II's, 4pt rollbar, Tremec TKO
Visit My Website
SmokedTires is offline   Reply With Quote
Old 01-24-2005, 03:36 PM   #6
redc3
CF Senior Member
redc3's Avatar
the holleys will come with cast metering block and base plate, the metering block is the piece between the bowls and the main body of the carb. they are well known to be porous and cause internal leaks. this is also where your emulsion circuits are. kinda like a bunch of little jets, that can be tweaked. you can purchase billet metering blocks, but why not spend the cash on something better to begin with. the holleys are tried and true, but i think the demons are a little more advanced
redc3 is offline   Reply With Quote
Old 01-24-2005, 04:32 PM   #7
JMoney454
CF Member
JMoney454's Avatar
I was already leaning towards the Mighty Demon, but you guys just talked me into it. I'm going to order it tonight. Thanks for the input!
Reload this Page Mighty Demon Vs. Holley 4150, Opinions Wanted
Tags
355, 4150, 650, demon, holley, holly, hp, mighty, opinion, rebuild
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
