Engine/tranny install update and transmission mount question...
Finally attached the engine to the transmission... It was a learning experience.. I had them together earlier, but the holes on the flexplate didn't line up with the holes on the converter
Re-did everything and it's fine now.. Now I'll only have to drop in the engine/transmission
Here's a pic of the current status...
Now here's my question: How do you assembly the transmission mount?
Here's a pic and I wonder what the right order of the bolt, washers and locking nuts is..
Here's the way that I think it has to be installed on the tranny:
bolt, washer, transmission mount, washer, plate, transmission.
Is this correct??
Another question: Should I install the tranny mount first to the tranny and then install it or should I install the tranny mount first to the crossmember and then drop the tranny on it?
Is this correct??
i put the 700r4 and engine in as one, then put a jack under trans pan and picked it up to get the crossmember in....do not tighten motor mounts until the trans is aligned and remember the front drivers side top motor mount bolt holds the Pwr steering pump bracket
Can't answer your question Oliver, but the motor/tranny looks SWEET See you at CI-VI in May
I have a fixed crossmember.. so I'll probably have the transmission mount afterwards...
I might end up installing the tranny mount afterwards because I've got the fixed crossmember..
Originally Posted by Redshark6974
Leave out the washer between the tranny mount and the plate. Lookin good!
I have that same poly mount, and it seemed really tall and i was scared it was going to throw off the geometry of the driveshaft..and i recall people having vibration problems with it, so i put in a new rubber mount. I actually used the plate supplied by the poly mount with the rubber mount, because i took off the stock undercar exhaust shield plate that came on it..it was the same thickness, so i used the poly mount plate. Anyways, i installed it with no washers in between like and the motor mounts are the same way.
[QUOTE=GrandSportC3]
it was enough of a pain with out a crossmember....i would think it would be a real PITA with a fixed crossmember.....does your tilt front make this process easier or harder?
[QUOTE=bobs77vet]
I hope that it'll be easier... We will see...
Originally Posted by Robby79
wow! A Card Table. Don't see them much anymore.
Is that the same tranny mount talked about in an earlier thread? Is it the one the manufacturer said would not fit Corvettes because if the height? I put one on a truck with no problems. The instructions said the extra plate is for preload not spacing.
The instructions said to use washers 1 & 2 under the lockwashers for the trans bolts. Washers 3 & 4 go on the bolts to the crossmember if the crossmember bolts do not have heads with wide bases.
1 Post
That table was the only one that I fould that I could use to lay the tranny on when attaching it to the engine
it actually held up a 150 lb tranny?
