In the hunt for new tires...need recommendations
Right now I have Goodyear Eagle ST's on the car...I dont want the originals...just want a decent tire that looks good. One guy recommended the BF Goodrich equivalent to the Eagle ST.
What do you all think?
C2 of Year Finalist (performance mods) 2019
St. Jude Donor 03-'04-'05-'06-'07-'08-'09-10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I just bought Kumho MX; a performance tire that is only going to last 12-15K, so probably not what you are looking for.
I assume you want the 255-60-15 tires ? I have the BFGoodrich T/A Radials and I'm happy with them, I don't think there is a big difference between the BFGs, Goodyears or Firestones or Dunlops- these four are available with raised white letters, not sure if you want the white letters or all black sidewall....
You cannot expect much performance from this tire size, it will be a lot better than 225-70-15 tires (if you currently have those), but any el cheapo low profile 17" tire will probably perform better due to the smaller sidewall.
2 words...Fire Hawk, oh wait is that one word, lemme look...
1 word...FireHawk. I really do love them. I have 255/60/15's up front and 275'60 15's under the flares in the rear. They perform great wet or dry. I like them much better than my old BFG radial's. Looks, handling, wear patterns, wet or dry, I think they're the superior tire.
I know people get emotionally wrapped up in 'brands' and fail to look at or understand basic tire specifications or sidewall data - but to those folks - show me any tire that has worse performance characteristics than either of these dynamic duds.
At a BARE MINIMUM on ANY car beit your family van or econobox grocery getter - an all-season H rated tire w/ A temperature. Heck that's what your average cheapo sub $20K econobox comes w/ new off the lot these days. Shouldn't a vintage GT be treated to at least that much?
On your '68 you have (had?) 15X7" rally rims - the F70 OE size tire equates to 215/70R15 - in this size there are a couple few *extremely* good tires avail w/ V or W speed ratings. That's a smallish tire for 8" but works well on a 7" rims. COnsider one of those Z or W rated all-season performance tires if keeping your 68 original. Pirelli comes to mind but there may be others...
If you have 8" rims the 225/70R15 offers better choices in tires contrary to what was posted above and is considered the std tire on all C3s by current tire stds. Look at the Ford Crown Victoria interceptor tires from Firestone (PV41) or General (XP2K V). There's also the Goodyear Eagle RSAs... These are all V rated tires w/ A temperature ratings and treadwear in the 300s - any would make an excellent choice.
IF you want to squeeze 255/60R15s on 8" rims on that car (warning they may not fit pre '78s w/o fiberglass trim some do some don't) the ONLY tire left that is decent in this size is the Pirelli Scorpion Zero.
Otherwise the broad selection of decent tires is all up in the 17" diameter I'm afraid.
There's also a potential 'bargain' performer tire out there as well. Check out the Cooper Cobra H rated tires in 225/70R15 for example.
And finally there's a SUmitomo HTR200 and Michelin Pilot XGT both are H rated and in 225/70R15.
After everyone posts the usual antecdotes about BFGs and Eagle fare - look at their UTQGs for the dirt truth. Understand that a tire w/ an A temp and H or V or higher speed rating (vs S or T low speed ratings) is a stronger tire that thus offers both better performance and safety margin. It rejects heat better. And a lower treadwear rating (say in the 300s...) implies a softer compound that will offer much better dry lateral adhesion yet last for many years (esp on a vintage car that is probably not going to receive a lot of miles anyway where time and UV is the real enemy).
Originally Posted by Larry82
Top rated tire in your size is the Firestone Indy 500. Have had Dunlops & BFG's. Indy 500 best so far.
I realy do like the Firehawk Indy 500's once I got them on the car. Might not be the highest performance tire out there but for what I am asking these tires to do for me, they do very well. You have to decide for yourself what you demand from a tire. These do the job for me and I would buy them again.
-Mark.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10
Originally Posted by joe73vette
Pirelli Scorpion Zero is the only V-rated tire that comes in 255-60-15. It's a blackwall only.
Joe
Joe
They are great in the rain and aren't noisy. Great cornering too. I had Dunlops on before and the only comparison between the two is that they both were round. The V rating is good for sustained 149 mph ( like I could do that with 4.11s )
I got mine at www.tirerack.com
Jeff
C6 the C5 of tomorrow
Originally Posted by pgtr
The Eagle ST and the BFG Radial TA are pretty much neck and neck for the most bottom of the line entry level tire one could put on a 3k lb performance car.
Snip---
Snip---
pure crap tires. Not worthy of a Vette
I agree.... but I want to keep the original aluminum wheels, so I am limited to 15" tires. I probably buy the Pirellis the next time I need tires (it's the only V-rated tire in this size) ... like I said above, any no name brand 17" tire is better ... I wish they made the aluminum wheels in 17".
"Top rated". Impressive claim but do tell us by who, their testing procedures and criteria and which competitors tires were by definition less than top rated. I'll give you this - these tires and others like them would likely be an excellent choice for the 'drifting' craze.
Originally Posted by stingr69
I don't read too much about tire ratings but I do read the other buyers comments where they get high marks.
Unfortunately this raises a valid point - good objective analytical tire tests and data are indeed hard to come by. That's why I recommend folks understand not only the basic UTQG info stamped on a tire but consider what exactly an H rated tire or an A temp tire or treadwear means, the tradeoffs and underlying construction, quality, strength and safety - not just some claims of 'performance'.
Originally Posted by JRD77VET
That's what I have on my '77. They do have a small yellow scorpion on one side of the tire. They are actually listed as a sport truck tire which will give you a slightly stiffer sidewall for better handling.
If you hurled $2K in suspension mods etc at an identical C3 but shod it w/ the non-performance cosmetic performers - it still could not touch a C3 w/ your tires and a good stock suspension in a performance handling comparison. (unless it was a 'judged' drifting contest - then we might be in trouble! )
