starter bolt pattern on 400 SBC?
Old 01-06-2005, 11:27 PM
GrandSportC3
GrandSportC3's Avatar
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default starter bolt pattern on 400 SBC?
I know that on 350 blocks - you can find the offset and straight bolt pattern for starter motors. Corvette blocks usually use offset bolt pattern.. I wonder if 400 blocks are available with both patterns or if they are always a certain pattern??
Old 01-06-2005, 11:33 PM
406shark
406shark's Avatar
I can't say for sure about all 400 blocks, but my 1972 400 block, casting number 3951511, uses the offset mounting bolts. The starter in mine is a NAPA #46-4795.
Good luck,
Jeff
Old 01-06-2005, 11:41 PM
GrandSportC3
Good luck,
Jeff
I'm going with a mini starter.. The starters for offset pattern are $50 - $60 more expensive
Old 01-06-2005, 11:44 PM
isosceles
isosceles's Avatar
how much weight does the mini starter save?
Old 01-06-2005, 11:47 PM
GrandSportC3
It's supposed to have 30% less weight...
Old 01-06-2005, 11:48 PM
406shark
406shark's Avatar
I just went out to my garage and checked my 400...it's sitting on my engine stand. Mine has a mounting hole with threads inline. It appears that either type of starter will work...at least on my particular block.
Do you have your engine handy? For $50.00 + dollars, I would check it for the dual mounts.
Good luck,
Jeff
Old 01-06-2005, 11:50 PM
GrandSportC3
Good luck,
Jeff
Don't have the engine yet.. I could've checked myself.. Will call the builder tomorrow anyway to check about the starter bolt pattern..
Old 01-07-2005, 12:21 AM
bobs77vet
bobs77vet's Avatar
Location: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
way more then 30%....i can easily move my ministarter around with one hand.... i would say like a 60% reduction over the big beast i had in there before....
Old 01-07-2005, 01:22 AM
Schmucker
Schmucker's Avatar
If you would have stayed with the manual trans you could have just push started it
Old 01-07-2005, 08:42 AM
7t2vette
The ORIGINAL and bestest
Support Corvetteforum!
7t2vette's Avatar
Toronto Events Coordinator
My '73 406 has an offset starter bolt pattern. I used a CVR starter part # 5323OS.
It is a Canadian made unit, very high quality, and it cost me $130 CAN or about $110 US
Their web site:
http://www.cvrproducts.com/main.html
Old 01-07-2005, 10:40 AM
69autoXr
69autoXr's Avatar
If the block doesn't have both patterns the extra hole can be drilled and tapped. That's what I had to do with my 350 when I went to the small flywheel. And with the engine out of the car it would be so much easier, I did mine from below while the car was on the hoist.
Old 01-07-2005, 11:48 AM
GrandSportC3
true.. but being competitive in bracket racing is more important to me than to be able to push start the car...
To starter bolt pattern on 400 SBC?
Quick Reply: starter bolt pattern on 400 SBC?
