NE1 know if the brake proportioning valve for a 73 was discontinued recently?
Is this a hard part to find?
Just had a shop replace it on the Vette (my ongoing brake issue but apparently all is well now) and they quoted me a price for the part as 350. When I checked Paragon the part is listed at 175...Whoa a 100% mark-up. So I call the guy back and he tells me the reason it is so high is that part was discontinued and the part cost is skyrocketing.
Any truth to this? Sound right or should I call shenanigans? Any alternate sources for them? Rebuild kits? Etc?
Shane
Shane
It's $115 after core at Ecklers
http://www.ecklers.com/product.asp?p...3TJGED4HSC5MNE
And it's also not entirely necessary. They're meant to keep the rears from locking up under heavy braking, but a lot of guys here have bypassed them as they can be troublesome.
Just look at The Last Detail (www.tld-corvette.com) and they only show a rebuilt one for the '73, it is $95 exchange. Do not list a new one.
Here is the pic they show for it. Is this it?
tom...
tom...
It's also highly unlikely that anyone would need a new one. The old one is probably serviceable as-is or can easily be rebuilt.
Originally Posted by Mike Ward
This has been beaten to death, but the valve on a '73 is NOT A PROPORTIONING VALVE.
Originally Posted by joe73vette
They added the proportioning valve to the block starting in 1974. Joe
Also I believe 67-69 (or maybe just 69?) used a manually adjustable prop. valve instead of the fixed adjustment valves that were employed later on.
When a car has a distribution block, the CAN be bypassed but it is not a very wise thing to do, especially for street machines, because you then reduce your braking system to one in which a single point of failure causes malfunction of the entire system. When you have either the front OR the back functional (which is the purpose of the distribution block), you at least have a fighting chance of stopping - unlike the practically ZERO chance of stopping with the so-called "Emergency Brake"....
Originally Posted by pws69
When a car has a porportioning valve, it is usually VERY necessary. They are used to compensate when there is a large disparity in the size (= hydraulic pressure) of the slave cylinders front to back.
