Door Vapor Barrier
Old 12-10-2004, 03:22 PM
chucks
chucks's Avatar
C3 of Year Finalist (stock) 2019
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Oldtimer
Default Door Vapor Barrier
I was wondering what to use to hold the plastic vapor barrier on the door. It fits between the door panel and the door. I would like to use something that if I would have to work on anything inside the door at a later date I could get it off without ruining it. Thanks for any info. Chuck
Old 12-10-2004, 03:25 PM
Fevre
Fevre's Avatar
Been a while but I think I used 2 sided tape.
Old 12-10-2004, 03:42 PM
bs82vette
bs82vette's Avatar
Factory used caulk strip .Go to Lowes and buy the roll.Its sticky on both sides
Old 12-10-2004, 03:44 PM
Frankenvette
Frankenvette's Avatar
I need to make a vapor barrier. Does anyone sell precut oem replica or are you guys just making one from stuff at Home Depot?
Old 12-10-2004, 03:46 PM
ZD75blue
ZD75blue's Avatar
Just get some 3 mil plastic sheeting... duct tape, or silicone it in place...
The sticky roll the fella above me talks about works too... just dont get it on anything!
Old 12-10-2004, 03:49 PM
'77BABE
'77BABE's Avatar
I use duct tape
Old 12-10-2004, 04:01 PM
75 Hot One
75 Hot One's Avatar
I did a search a few years ago and couldn't find any aftermarket product so I used about 6 or 8 thou polyethylene sheet- seems to work O.K.
Old 12-10-2004, 04:59 PM
Bullshark
Bullshark's Avatar
CI 5 & 8 Veteran
Do you even need to replace the vapor barrier plastic if you have aftermarket door panels that have the newer ABS plastic core? The old stock door panels had a cardboard frame back so I can see why it was needed for that.
Bullshark
OMF (02-11-2023)
Old 12-10-2004, 05:04 PM
Gordonm
Gordonm's Avatar
I have been driving mine for a bunch of years with no vapor barrier. I do have the newer ABS panels. I don't drive it much when it is cold so I never even noticed a difference.
Old 12-10-2004, 05:06 PM
codestar7
codestar7's Avatar
Default Vapor Barrier
Use "Monkey Sh t" We used it on everything in the Navy..LOL It's called "Dum Dum on the outside, Walmart calles it Moldable weather caulk...LOL Its just this gray stuff that comes on a roll and its simi hard but moldable.
Old 12-10-2004, 06:12 PM
CA-Legal-Vette
CA-Legal-Vette's Avatar
Originally Posted by '77BABE
I use duct tape
Although I think this is slightly bubba, I must admit to doing the same. I used the new clear duct tape to pretend that it is more appropriate, but it probably is more important to seal it that what you use to seal it. It its, after all, covered by the door panel.
Old 12-10-2004, 06:14 PM
Twin_Turbo
Twin_Turbo's Avatar
weatherstrip adhesive, the caulk rope gets brittle and catches a lot of sand and seems to come loose after time
Old 12-10-2004, 09:40 PM
chucks
chucks's Avatar
Oldtimer
Here you go
ebay
Old 12-10-2004, 10:15 PM
Frankenvette
Chucks,
Thanks for the link. That's pretty neat stuff, insulation and moisture proof. I'll have to look into this after a few other projects.
Old 12-11-2004, 08:19 AM
chucks
chucks's Avatar
Oldtimer
Chucks,
He will sell you just the door panel insulation if that's all you want. I think it's about $22.00. I bought some off of him but it's to cold here in Ohio for me to get out in my cold garage and do the work. I'm 62 and just can't work out in a cold garage like I used to. Chuck
Old 12-11-2004, 11:04 AM
Frankenvette
I'm 37 and I don't like to work in a cold garage.
Old 12-11-2004, 02:33 PM
75 Hot One
75 Hot One's Avatar
I suppose it depends on what type of caulking. I use a gray type similar to what they have at Home Depot and it stays flexible. Have also used a butyl caulking in rope form- super sticky and stays soft.
To Door Vapor Barrier
Old 12-11-2004, 06:31 PM
rollavette71
rollavette71's Avatar
I use contact cement... has worked well for me so far.
Hank
Old 07-17-2018, 09:13 PM
Cavu2u
Cavu2u's Avatar
Has anyone ever use this product for attaching the vapor barrier to the door?
https://www.homedepot.com/p/Fabral-1...u%3A%7Btape%7D
Thanks.
Steve
The following 2 users liked this post by Cavu2u:
KENS80V (02-11-2023), LenWoodruff (07-19-2018)
Old 07-17-2018, 10:55 PM
BLUE1972
BLUE1972's Avatar
Received 1,149 Likes on 737 Posts
used it on my truck, it worked
Cavu2u (07-18-2018)
Quick Reply: Door Vapor Barrier
