Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-10-2004, 10:58 AM   #1
mvftw
CF Senior Member
mvftw's Avatar
Default Valve Seals?
What are the best valve seals for a stock '78 L82? This will be a springtime project...
__________________
We do not stop playing because we grow old;
we grow old because we stop playing
mvftw is offline   Reply With Quote
Old 12-10-2004, 02:27 PM   #2
page62
CF Senior Member
page62's Avatar
I decided these valve seals were the best swap I could do on my L82
Click the image to open in full size.
"Summit"-brand Dart Iron Eagle S/S heads. Big valves, 67cc vortec-style chambers. And relatively inexpensive
__________________
Gone but not forgotten: '79 L-82 with Summit/Dart Iron Eagle SS "fuelie" heads, 64K miles, Steeroids, 200-4R 4-spd auto OD tranny, QJet (tuned by Lars!), true duals with Dynomax Super Turbo mufflers, red leather interior, Blaupunkt CD player ... and crackle-finish paint.
Official Survivor of Lars' Tuning for Beer World Tour
page62 is offline   Reply With Quote
Old 12-10-2004, 02:34 PM   #3
isosceles
CF Senior Member
isosceles's Avatar
WIAI disease!!!!!
isosceles is offline   Reply With Quote
Old 12-10-2004, 02:36 PM   #4
SteveG75
CF Senior Member
SteveG75's Avatar
For stock I would go to NAPA and get some stock umbrella seals.
I ended up replacing the Crane teflons seals that my shop put on with the Edelbrock viton ones and stopped my oil burning problem. This was on my RPM heads with Crane dual valve springs.
__________________
Steve G.
1975 convertible 496 Tripower/T-56 Magnum/ Ramadie-built 3.73 12 bolt/FE-7/Hooker sidepipes/Wilwood brakes
SteveG75 is offline   Reply With Quote
Old 12-10-2004, 02:36 PM   #5
isosceles
CF Senior Member
isosceles's Avatar
I used Felpro "Umbrella" seals. Got em from Autozone. Don't remember the part number.
Old 12-10-2004, 02:53 PM   #6
page62
CF Senior Member
page62's Avatar
Quote:
Originally Posted by isosceles
WIAI disease!!!!!
It takes one to know one!!!
Old 12-10-2004, 02:58 PM   #7
Crash80
CF Senior Member
Crash80's Avatar
I did this a while back with the NAPA positive stop seals. They are sort of white in color and have little springs on them. These cured all of my smoky start ups. Any positive stop seal should work for you.
Crash80 is offline   Reply With Quote
Old 12-10-2004, 06:56 PM   #8
diablo kid
CF Senior Member
diablo kid's Avatar
Question - to replace these seals do the heads have to come off the block?
__________________
76 - red - L48, low speed - 4 speed
diablo kid is offline   Reply With Quote
Old 12-10-2004, 07:08 PM   #9
SteveG75
CF Senior Member
SteveG75's Avatar
Quote:
Nope. Some people use compressed air or rope to keep the valves up. I just rotated each cylinder to TDC in turn (firing order) and then did the seal swap.
With the piston at TDC, there is no way that the valve could drop far enough to fall into the cylinder.
Old 12-10-2004, 09:24 PM   #10
Cali,68,L-79
CF Senior Member
Cali,68,L-79's Avatar
__________________
View CALI'S Homepage http://temp.corvetteforum.net/c3/cali77l82
Cali,68,L-79 is offline   Reply With Quote
Old 12-10-2004, 09:30 PM   #11
Crash80
CF Senior Member
Crash80's Avatar
If you have it done, it will run you about $400.00 or so. At least it did for me down here in TX. I don't have a compressor to do the air trick, so I had it done. I have not had a plug foul since I had the seals replaced, which was a good 8-10 months ago and my Vette is my daily driver for the most part. I took the seals to the guy that did my car and told him that I wanted to use them instead of the usual GM 'O' rings. The positive stop seals are light years better.
Old 12-10-2004, 11:38 PM   #12
jacobsed
CF Senior Member
jacobsed's Avatar
Send a message via AIM to jacobsed
Can somebody post a picture of these positive stop seals?
jacobsed is offline   Reply With Quote
Old 12-11-2004, 09:11 AM   #13
Ybnormal
CF Senior Member
Send a message via Yahoo to Ybnormal
Here ya go, I posted a picture here www.angelfire.com/al/swhite7/temp.html
YBnormal...drive a vette
Ybnormal is offline   Reply With Quote
Old 12-11-2004, 09:34 AM   #14
GTR1999
CF Senior Member
Will the positive stop seals fit on the guides without any modification/machining?
Gary
GTR1999 is offline   Reply With Quote
Old 12-11-2004, 09:48 AM   #15
jacobsed
CF Senior Member
jacobsed's Avatar
Ok, based on the picture posted, can somebody explain how they work? I pulled a chewed up set of these out of my heads and replaced them with the Felpro umbrella style. The engine has not been started yet as I've got one of those big body off restos going on.
Old 12-11-2004, 09:56 AM   #16
paul 74
Ontario, Canada
Support Corvetteforum!
paul 74's Avatar
Here's a pic. They snap on the guide and don't move. With these, no machining was required. We put them on the 1979 L-82 last September using a compressor. Oil consumption problem solved.
paul 74 is offline   Reply With Quote
Old 12-11-2004, 09:58 AM   #17
jacobsed
CF Senior Member
jacobsed's Avatar
So how do they snap onto the valve guide? Have to have a sepcial guide machined with a groove or something?
Old 12-11-2004, 10:21 AM   #18
SteveG75
CF Senior Member
SteveG75's Avatar
Quote:
The valve guides should be machined and the seals just push down over them and are held in place by the spring wires. After I slid mine down the valves, I put a 1/2" deep socket over it, couple of taps with a hammer to seat it and good to go.
I originally had the Crane white teflons seals and was burning oil. My new viton seals from Edelbrock look exactly like the ones that Paul67 posted above.
Old 12-11-2004, 10:24 AM   #19
jacobsed
CF Senior Member
jacobsed's Avatar
So all valve guides have the feature needed for them to snap on already?
I don't think mine do.
Old 12-11-2004, 10:31 AM   #20
GTR1999
CF Senior Member
Interesting that Paul used the Crane seals and didn't need to machine the guide? I thought the opposite,that positive seals required the guide to be machined?
The WP heads have came with the umbrella type of seal. I do have an oil usage problem that i haven't been able to track. Plugs are not fouled,some are running lean(white), no major oil leaks, but the engine uses 1 qt/600 miles. No heavy smoke unless shifting at 5500 RPM. I didn't to do a leak down or compression test yet.
Gary
Reload this Page Valve Seals?
Tags
78, 9981916, crane, dart, eagle, fit, heads, iron, l48, l82, seal, seals, size, ss, valve
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
1986 vette engine smoking critter C4 Tech/Performance 21 05-22-2012 12:38 AM
Valve Seals on a Drag race engine vetteman9368 Engine Mods 15 05-21-2005 07:17 AM
What is involved in Replacing the Valve Seals? RED-85-Z51 C4 General Discussion 10 07-22-2004 03:48 PM
L98 Valve Seals ?? AGENT 86 C4 Tech/Performance 21 01-28-2004 11:40 PM
Valve seals - umbrella vs. teflon john73bb C3 Tech/Performance 19 02-09-2002 11:24 PM
valve seals GlockLT4 C4 Tech/Performance 20 12-31-2001 03:51 PM
Why do I lose 1qt oil every 250 miles??? Is it easy to change the valve seals? fireball C3 Tech/Performance 10 09-04-2001 08:56 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
