Need Ideas
Need Ideas
I need some Ideas about my stero in my 75 I am wanting to put 2 6x9's in the back and a 8 in sub and still be able to fit the tops. If any one has any Ideas and pics that would be great. Thanks.
Anyone My Idea is to put the 6x9s in the sides of the box facing the passender and driver seat then put the 8in sub in the center. I want the sub in a vented box with the 6x9s so it will have to be sectioned. will this work or not.
You could make your own boxes to fit the rear speakers in. I made some that will fit 6 inch round speakers and they dont interfere with anything back there. You could build them larger if you wanted to. I was limited to 6 inch to keep them as small as possible so I could still get my rear window tray up and down.
I built a hanger (if you want to call it that) that wedges between the rear fender hump and the back of the compartment and hung speakers and fire extinguisher from it.
Hope this helps.
Terry
Hope this helps.
Terry
