Center Console Install Results
Old 11-02-2004, 07:51 AM
Karfever
Support Corvetteforum!
Karfever's Avatar
Default Center Console Install Results
I just finished installing a reproduction Center console in my 69. The manufacturer/supplier was Corvette Central, bought through Wilcox. I had heard alot about poor fit and other issues with these reporduction interior parts, but in my case the fit/finish was very good, almost as good as the original part. I also notice some extra reinforcement at various points in the substructure.
I hope this helps those of you who are unsure which way to go with these type of parts.
Old 11-02-2004, 08:00 AM
comp
comp's Avatar
need pic's
Old 11-02-2004, 09:03 AM
79ls1
79ls1's Avatar
Yes, pic's please
Old 11-02-2004, 01:34 PM
Thumper76
Thumper76's Avatar
The Corvette Central interior pieces I've bought don't seem to fit very well. The center console shift plate opening was a good 1/2" too narrow for the shift plate to fit. The windshield surround pieces fit terrible too. I also got mine from Wilcox. Maybe I got factory seconds, I don't know. Glad to hear that everything worked out well for you.
Old 11-02-2004, 07:20 PM
Karfever
Karfever's Avatar
I will try to post photos tonite...between election results!
Old 11-02-2004, 07:53 PM
Karfever
Karfever's Avatar
I cant get the process right to post photos on a response. If someone can do this, this is the lionk to the photo!
http://forums.corvetteforum.com/phot...4963&password=
Old 11-02-2004, 08:18 PM
redwingvette
redwingvette's Avatar
"This category does not contain any images."
is all I got
Old 11-02-2004, 08:57 PM
Karfever
Karfever's Avatar
When I went back to it, it said "image under review' I will email to anyone who can post it!
Old 11-03-2004, 03:48 AM
standup
standup's Avatar
Originally Posted by Thumper76
......The center console shift plate opening was a good 1/2" too narrow for the shift plate to fit........
.....you have to heat this up with a blow dryer to soften the vinyl and foam.......once it's softened, it will fit perfectly and harden around the shift plate.....
Old 11-03-2004, 07:14 AM
Karfever
Karfever's Avatar
That is what I did, I used a heat gun and SLOWLY heated the console while I tightened the console plate down. After it cooled, the fit is perfect as the console formed its'self around the plate.
Still cant get the DA** pictures to post.
Old 11-03-2004, 08:14 AM
Edzred72
Edzred72's Avatar
The interior restorers favorite tool!!! Both of my Corvette America door panels needed the heat gun treatment also.
Eddie
Old 11-04-2004, 06:42 PM
Karfever
Karfever's Avatar
[IMG]http://[/IMG]forums.corvetteforum.com/photopost/showphoto.php?photo=22591
Old 11-05-2004, 08:00 AM
vettfixr
vettfixr's Avatar
I'll just jump in here with a side note. When I replaced the parking brake console on my 74 I got the replacement console that had the storage compartment in the rear. It seemed like a good idea at the time and is very useful for holding things like sunglasses, garage door openers, cigs, etc. The only problem is that because it's higher than the original console in the rear your elbow tends to hit the cover on top when you do a 1 - 2 or a 3 - 4 shift. I guess if you had an automatic it wouldn't matter but it's a little annoying with a 4 speed. I usually drive with the cover off and then replace it when parked. Just a heads up to anyone considering this mod.
Old 11-05-2004, 08:07 AM
ICEMAN59
ICEMAN59's Avatar
I got the pic from the link, nice interior, looks great!
Old 11-05-2004, 08:11 AM
FormerPacifist
FormerPacifist's Avatar
here it is
Old 11-05-2004, 06:49 PM
majic1984
majic1984's Avatar
Very nice!! Is that Plush or 80/20 loop carpet?
Old 11-05-2004, 06:52 PM
olouieo
olouieo's Avatar
looks great!
To Center Console Install Results
Quick Reply: Center Console Install Results
