Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-26-2004, 04:55 AM   #1
exdrag77
CF Senior Member
exdrag77's Avatar
Default Need TH400 Governor Spring Part Numbers...
I'm in the process of adjusting my TH400 shift points to better match my HP curve but need some parts. I've taken several governors apart and ground the weights to several sizes for testing. The 5 governors I had lying around were all stock and most of them had various strengths of springs installed. What I need is the factory GM part numbers for the various colored springs so I can go buy more for testing. The chevy dealer here can't find that info since he only goes back to '78 and the local trans shops are of no help either since they only have stock components. If anyone has GM part numbers or other sources, they are appreciated! Also, I don't want the $30 B&M kit just to get 3 sets of springs so count out that option. Once I'm done with my testing, I'll post what I've concluded and show how I modified the stock weights and assembled the unit!
exdrag77 is offline   Reply With Quote
Old 10-26-2004, 12:39 PM   #2
exdrag77
CF Senior Member
exdrag77's Avatar
No parts guys around today?
Old 10-26-2004, 03:54 PM   #3
exdrag77
CF Senior Member
exdrag77's Avatar
Anyone with parts manuals around today?
Old 10-26-2004, 07:40 PM   #4
Matt Gruber
CF Senior Member
buy those spring grab bags, 2-$4 for up to 200 springs
Matt Gruber is offline   Reply With Quote
Old 10-26-2004, 08:21 PM   #5
exdrag77
CF Senior Member
exdrag77's Avatar
Quote:
Thanks for that suggestion but I tried that and still haven't come up with right size and strength. Seems like it shouldn't be hard to find 1/4" dia x 1" springs, but have had no luck so far!
Old 10-27-2004, 08:08 AM   #6
Matt Gruber
CF Senior Member
it's easy to mod springs if they are close.
post WOT shift points with what you have now, and what you want.
Old 10-27-2004, 11:20 AM   #7
exdrag77
CF Senior Member
exdrag77's Avatar
The springs in the grab bag weren't close! I figure it should be easy to get the GM part numbers from a parts manual or trans rebuild book, but I have neither.
With the stock governor, my car was 1-2 shifting at 4800 and 2-3 at 3600 with kickdown in proper working order. I've ground down the small weights a bit and have been changing springs with several diffferent colors to try to get both shift points at around 5500. My peak hp is at 5100 according to G-Tech Pro RR and have read where I need to shift a bit above that due to the large range in gears in a 3 speed. I've read where it's trial and error so need a selection of different strength springs to try to get it right. From what I have found so far, there is no exact formula for getting shift points right. You need to take weight off to get the 2-3 shifts up and if you take weight off, you then have to also change springs to keep 1-2 from getting too high.
I'm going to the library in the next day or so to see if I can find a trans rebuild book that may have the spring numbers so I'll let you know if I get it worked out!
Old 10-27-2004, 12:13 PM   #8
Matt Gruber
CF Senior Member
how do u know for sure the kickdown circuit is working? Test: compare shifts with it disconnected(they should be much earlier)
Old 10-27-2004, 04:22 PM   #9
exdrag77
CF Senior Member
exdrag77's Avatar
It's in proper working condition.
Old 10-28-2004, 09:22 AM   #10
Matt Gruber
CF Senior Member
did u know line pressure also determines shifts?
(is yours low?)
Old 10-28-2004, 12:34 PM   #11
exdrag77
CF Senior Member
exdrag77's Avatar
The trans is rebuilt with mods inc. pump improvement, heavy duty sprag and shift kit. The weights and springs primarily determine when the TH400 shifts and I need to adjust that. Been doing it with some success but can't get it exactly where I want it without those GM springs. Thanks for the comments so far!
Old 10-28-2004, 01:04 PM   #12
Matt Gruber
CF Senior Member
the kit is worth the $30
Old 10-28-2004, 01:16 PM   #13
exdrag77
CF Senior Member
exdrag77's Avatar
Not for 3 sets of springs, two of which I already have! There are about 8 different strengths from what I've found. I also want a source for them so once I post my testing results on the forum, I can give GM part numbers so others can easily tune their shift points as well.
Old 10-28-2004, 08:59 PM   #14
exdrag77
CF Senior Member
exdrag77's Avatar
No one have a source for the colored gov springs?
Old 10-28-2004, 09:01 PM   #15
exdrag77
CF Senior Member
exdrag77's Avatar
No one have a source for the colored springs found in GM governors? I believe the TH350, TH400 and 4 speed all use the same type.
Old 10-28-2004, 10:55 PM   #16
shoptek
CF Senior Member
shoptek's Avatar
exdrag77,
For what it is worth.....I am thumbing through my TH400 book by Ron Sessions. He states:
"Although GM doesn't sell governor springs seperately, they are included in shift kits (as you well know).........Any transmission shop should be able to dig up a few of these springs for you."
I checked with a parts guy buddy at a GM dealer, and he too claims that the springs aren't sold seperately.
shoptek is offline   Reply With Quote
Old 10-29-2004, 07:45 AM   #17
Matt Gruber
CF Senior Member
springs are easy to mod so why bother?
Reload this Page Need TH400 Governor Spring Part Numbers...
Tags
350, buick, color, gm, govener, governor, govner, kit, kits, modification, numbers, part, points, rebuild, shift, springs, th400, trans
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
